Question about HP Compaq Presario V2000 Notebook
Compaq Presario V2000 boot up problem
Hi, every time i turn on my computer, the Compaq logo shows up for 2 seconds, and then, it beeps twice and the screen displays: "press F1 to resume, F2 to setup. I pressed the buttons, but i dint work! help!
  • 13 more comments
  • mare2007 Dec 22, 2007
    Mine is doing the same thing, boots up, 2 beeps and then shows compaq screen where you can choose esc, f2 or f12, and then goes to the hit f1 , etc..only it says f10 on the second part. I touch keyboard keys and nothing. I took RAM out and tried it again, just to see if it beeped at me, and it does the beeps it is supposed to without the RAM. I have tested the hard drive with another pc and it works on that one. It shows that it finds it by the hard drive light on this compaq presario v2000 laptop.I am getting quite an ulcer. Help!!!
    Thanks.
    Mare
  • Theo D Jan 08, 2008
    I am having the exact same problem. I turn on the laptop first screen shows a white compaq logo with press esc, F10, F12 then goes streight to F1 to continue F1o set up (2 beeps) then nothing> checked ram and hard drive. no luck yet
  • voldennis Jan 08, 2008
    Press power button, COMPAQ logo shows up for 1/2 second wtih Press ESC to change boot order , Press F10 to enter Setup, Press F12 to boot from LAN on bottom left side of screen. It flashes on the screen so fast even with your finger on the button it doesn't respond. Then on top left side of screen Press F1 to resume, Press F10 to enter Setup.
    I checked for stuck keys. I removed and replaced the RAM. Check that the HD was seated.
    I will get the CD from home later but I already tried a bootable CD in the drive. It spun up but did not load. Also did not load when powered down then powered on again.
  • vathanak Jan 11, 2008
    my laptop is doing the same thing. there is nothing else that displays.
    could it be that something with the keyboard might have burned or
    sumthing? but all the problems that the others are having i am having
    also. what can i do?
  • kelvinl Jan 26, 2008
    I have the same problem, I've tried removing one of the memory madules, replaced them with known-working memory, my cd/dvd drive also spins, but the bootable XP disk doesn't load.
    I may try to take it apart to remove the motherboard cmaos battery, but that's a daunting task.
  • rockIII Feb 23, 2008
    I am having the exact same problem as described by previous users. I am guessing something is wrong with the BIOS. Need some expert help now!
  • kasiaa112 Feb 28, 2008
    has anyone found the solution yet?? I have the same problem
  • Anonymous Mar 02, 2008
    beeps twice and shows a page with buttons to hit but doest respond
  • Theo D Mar 02, 2008
    HP wants $300 to fix this problem on $450 laptop. I bought a Fujitsu instead and will never buy HP again after the customer support I received. To bad HP at one time was a good company.
  • Anonymous Mar 18, 2008
    Yes , it says to hit certain F's but does not recognize the keyboard at all.:)
    mare
  • tabby1976 Jan 12, 2009
    I have the exact same problem, hp chat support says it is the hardware does anyone have a real working soluton?
    Thanks in advance!!
  • bgt10 Feb 10, 2009
    2 beeps then COMPAQ logo, then ‘Press F1 to resume and F10 to Enter SETUP” on top, nothing happens. It also flashes on the bottom as others mentioned to fast to react. HP chat responded by saying it was a hardware problem and I should take it to BEST BUY or Radio Shack, but could not tell me what the problem really is. I read somewhere it could be a battery on the motherboard. Really need help.
  • tuoncan Mar 27, 2009
    I bought a new CMOS battery, replaced it and still getting the same problem.
    Other things I have done:
    removed CD driver, replaced with a new hard drive, removed the RAM
  • Anonymous Mar 29, 2009
    the compaq screen shows and beeps twice and then it says press f1 or f10 but it doesnt respond to anything.
  • bijatun May 11, 2010
    Solution link . . . www.Laptop-Problem-Sollution.com
    New Friend:
I have the same problem with mine, the compaqCompaq Presario V2000 boot up problem - 2_bing.gif screen shows and beeps twice and then it says press f1 or f10 but it doesnt respond to anything i press
Posted on Jan 19, 2010
    Problem Solver:
  • 10 Answers
Hi Friends,
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
Where is the bios chip located?
Posted on Oct 31, 2008
  • nunya Dec 27, 2008
    I figured it out; the bios needed to be reset, so I took out the bios battery, waited, and then put it back in, and it worked.
Responding to ikenfixit, F2 does not take me to BIOS. Neither can the optical drive boot to windows. Seems the computer is not responding to any key input whatsoever.
Posted on Mar 02, 2008
  • 2 more comments
  • rockIII Mar 02, 2008
    Some bad news to let everyone who experienced this problem know, it is most likely a problem with BIOS. There is no easy fix. The BIOS chip on the motherboard needs to be unsoldered and replaced. That's according to my online chat with Compaq tech support. I am just going to trash my compaq V2000 and go get a MAC.
    Just finish chating online with Compaq Tech support. The problem is most likely in the BIOS. Bad news is BIOS chip has to be removed/desoldered from the motherboard. That's not a easy fix. I am going to trash my V2000 and go get a MAC.
  • rockIII Mar 05, 2008
    Responding to tat4u, Thanks for trying. Unfortunately, the problem is much worse than you think. Upon power up, there is the 2 beep, and the screen only display Compaq logo with 2 lines of text at the bottom, I have tried hitting F10, F1, F2..., no matter what key you hit, it refuses to go into BIOS setup. It only proceeds to the next screen that says Press F1 to resume, F10 to setup. A hopeless situation. I have taken the HD out and it does the exact same thing. I reseated DRAM, no effect. The only logic conclusion is BIOS chip is bad, as HP rep suggested. If it costs $300 to replace the chip, I am just going to toss the computer out.
  • rockIII Jan 14, 2009
    It's the real time clock battery socket problem. Contact is loose. I soldered the socket in, the BIOS works and computer is back to life.
    Scholar:
  • 163 Answers
Does F2 take you to BIOS? If not post back... Also Esc will or should take you to boot options. Try booting from Optical drive here..
Posted on Feb 29, 2008
My laptop is doing the same thing. there is nothing else that displays. could it be that something with the keyboard might have burned or sumthing? but all the problems that the others are having i am having also. what can i do?
Posted on Jan 11, 2008
    Problem Solver:
  • 16 Answers
You need to provide more information.
Your computer must have displayed some other information on the screen, copy them and post back here for proper diagnosis and advise.
Posted on Nov 25, 2007
  • 520 Answers
When u turn on pc what do u see.usually have message bottom left hand screen indicating what key to press to enter setup.
this key is for bios setup .the f 2 key you are refering to is to setup os(windows)but if hd has error you cant setup or resume.
Its not too bad and easily fixed but I need to know what is on screen on power up.
the fault is in hd and only needs os reinstalling or repairing.
2 beeps means system cant find hd(os)
Posted on Mar 04, 2008
  • tat4u
    tat4u Mar 04, 2008
    who ever told u to desolder bios chip was taking the piss just tryin to fob u off..
    when u enter bios you can reset to default.
    to reset bios on mother board,find the rtc and remove battery for 5 mins then replace .this resets all bios(passwords,all settings factory set)battery is next to rtc and looks like a large watch battery
  • tat4u
    tat4u Mar 04, 2008
    I assume your online now.
    so press f 10 enter bios and as you probably know you have to be quick cos its only shown briefly.
    In bios check boot settings ,enable boot cd first...save settings and exit..
    reboot making sure have os in cd drive.top of screen say press any key to boot from cd so press a key ....again you dont have a lot of time to decide.windows will start to boot.system will ask install windows or repair ....chooose install windows..system will check drive and find existing os and ask install or repair..at this point you can choose repair if you have installed stuff you dont want to loose otherwise choose install.in next screen delete partition ...create new partition ...format and install
SOURCE:
What is wrong when my compaq v2000 beeps 2 times loud when I turn it on but no boot
Beep codes are unique to each brand of computer:
Compaq v2000
1 short with 1 long beep = bad bios. Must reload bios from disc.
2 short beeps = general bios failure
for more - do a google search for "v2000 Beep Codes" and go to the link for "bioscentral" - all are listed.
Jul 02, 2014 | HP Compaq Presario V2000 Notebook
Compaq V2000 "Press <F1> to resume, <F10> to Setup
re install the operating system.insert the recovery disk and follow the instructions.
Feb 20, 2010 | HP Compaq Presario V2000 Notebook
My Compaq V2000 beeps twice & freezes
It sounds like the RAM is either not compatable or is bad. Put the old RAM back in and try again. Also the V2000 and HP DV2000 is in recall for mother board problems.
Nov 12, 2009 | HP Compaq Presario V2000 Notebook
My V2000 won't boot. It starts to power up, beeps twice stops at the Compact sign in the middle and "press [esc] to change boot order, press [F10] to setup, press [F12] to boot from lan" at the bottom....
probably keyboard connector is loose so, no imput from keyboard is coming in so it halts bootup. please check the connector [opening of a computer is requied probably]
Oct 30, 2009 | HP Compaq Presario V2000 Notebook
Computer turns on, but won't work afterwords
Nev, the two loud beeping sound of the system when turning it on could be a problem with the memory or the system board.
Try disconnecting the power and take out the battery, then press and hold the power button for 5 seconds then look for the memory comparment and reseat it.
Keep me posted.
Thanks.
Nov 16, 2008 | HP Compaq Presario V2000 Notebook
2 beeps & nothing on the screen
Hi Tom,
Please verify the capacity and how many memory modules you have in the system?
If your system won't turn on and get 2 beeping sounds. It is an issue with your memory (RAM) you may need to reseat the memory card. After reseating the memory card (RAM) and the issue persist and i suggest to check also the warranty of your system from your coomputer manufacturer for part replacement.
keep me posted.
regards,
Jeff
Oct 11, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario
twice beep means either video card is disconnected or it's non-functional.
if it's a laptop under warranty, take it to an authorized dealer
if it's not under warranty and you are not comfortable in breaking down your laptop, then see if a local computer place can check it out
if not under warranty, and you are fairly computer savy, reseat the video board, memory, and cpu (if possible). somewhere there is a loose connection. if not working, the main board might be bad.
Jun 06, 2008 | HP Compaq Presario V2000 Notebook
Presario V2000 will not boot
When your computer starts press f10 to enter the bios ,there you will find the option to reset its setting to default.....
Was this solution helpful .Show your appreciation by rating it.
May 30, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 boots up, but
Getting into Windows Safe Mode Users who may not be able to boot into normal mode or are not able to ... "F8 Key.
Linux and UNIX pg command help |/pattern/, Start up at the first line containing the regular expression pattern. filename, A path name of a text file to be displayed.
LS-120 SuperDisk drive help Next, connect the power and boot the computer and install the software ... as the computer beeps or pressing and holding CTRL as the computer is booting up.
Theses site should get ya back on line. Read and follow instructions.
Merry Christmas, Good Luck...Please dont for get to Vote/Thank You.
Merry Christmas
Dec 22, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
6,080 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
