SOURCE: password forgotten
What you need to do here is to get the Wireless security from your Linksys router by accessing its setup page, Just type http://192.168.1.1 on the address bar of your working computer then that should be asking you for a username and password, just leave the user name blank and type admin for password. If you're already on the router setup page you will see there Wireless tab just go to it and after that go to Wireless security sub tab under wireless and you can find there the wireless key that you need..
If that wont work contact me back for further help....
Don't forget to rate the solution FIXYA thank you...............
SOURCE: cannot connect ds to wireless router - Huawei Echolife 520s
Ensure that the B type is enabled in your router and that the security it set to WEP and that your passcode is correct.
HTH
SOURCE: about 108 mbps wireless router wgt624 netgear
HOW CAN I INSTALL MY NETGEARN 108Mbps WIRELESS FIREWALL ROUTER WGT624 v2.
SOURCE: downloading the HUAWEI FWT Wireless Modem Driver
http://webmomy.com/wp-content/uploads/2009/02/ptcl_wireless_modem_drivers_manuall.zip
SOURCE: Need settings for Huawei HG510 with Linksys wireless WRT54G
hey can you send me the settings for the router and how to configure it! [email protected]
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
Unfortunately, there is no way to recover a lost or forgotten password
from a router or access point; you will need to reset the device to
factory defaults. However, once the device is reset to factory defaults,
you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
