Question about ASUS P5N-E SLI BULK PACK of 10, Quad,775 Motherboard
I have a p5n sli motherboard which refuses to boot
I have a p5n sli motherboard which sends no signal to the graphics card,even when i have change it to another i still get the same problem,what could be causing this?
    President:
  • 2,351 Answers
Go to page 2-30 section 2.4.5 in your manual.
If you are using the onboard graphics for your display set this to [PCI]. If you are using the PCI-E video card, set the bios to [PCI-E]. Save & exit the bios. You should have display after the system re-boots. If you still have no display & you are 100% sure your monitor functions than the video controller on the board is bad. This can not be repaired.
Mike
Posted on Aug 13, 2009
Fails to start up, fans go and lights turn on but no signal to screen (i have tried a new graphics card) i cant find anywhere to buy a new one of the same board so any ideas on how to fix this problem im...
Hello Sir,
I think you can better change your RAM and check it whether you get it working properly. This looks like a Problem in your RAM. Check it and let me know if the problem persists.
Aug 10, 2010 | ASUS P5N-E SLI nForce 650i SLI Socket 775...
Asus P5N-E SLI Motherboard and Ethernet Controller Problem
Had a similar problem with P5ne-sli motherboard, Intel Q6600 cpu, Nvidia GTS 8800 video card. One day the ethernet just stopped working, but it was working... It would connect to my network but would see "limited or no connectivity" in the taskbar. Went into BIOS and looked at the signals and for some reason only 4 of the 8 signals were getting a reading. Figured a power spike had fried my onboasrd ethenet card. Switched to an old PCI ethernet card... after two years I was doing a fresh install, of XP and for shits and giggles I just plugged the ethernet cord into the onboard with the PCI ethernet card removed. When windows went to validate it detected and installed my onboard ethernet...validated then proceeded to update windows. Over a year later it still works.
Never bothered to update BIOS until last month and that was only to fix the long boot time with ATI 5770 video card.
Willing to bet that resetting your BIOS will fix the problem for you. Just unplug computer, remove battery, attempt power up to clear any juice still in the system. Replace battery and boot up computer...
Also removed a DIMM that went bad around the same time. May have been a factor so try testing your RAM.
Jul 13, 2009 | Evga GeForce GTS 250,, PCI Express Video...
I need pl915GLM xpress graphic drivers of mercury
http://support.asus.com/download/download.aspx
-select the socket775 option and the motherboard P5N-E-SLI confirm your OS and download drivers as required.
Jun 17, 2009 | ASUS P5N-E SLI Motherboard
P5N-SLI
HI stukove2000,
What is the 5200 stand for?
Here is Asus approved CPU list link for the P5N-E SLI MB:
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5N-E%20SLI
The Corsair TWIN2X2048-6400 5-5-5-15, should work just fine on the Asus MB.
Here is an expanded approved Qualified Venders List from Asus.
http://www.asus.com/999/download/products/1474/1474_10.pdf
You can also see a smaller QVL list in the manual on page 1-18 & 1-19.
The QVL insures total compatibility with the motherboard.
The NVIDIA GeForce 9600 GT will run just fine on the Asus MB. Just make sure your power supply is no less than 500W. A 600W or 650W is preferred.
http://www.google.com/products/catalog?hl=en&q=600W+power+supply&um=1&ie=UTF-8&cid=1841721063482288764&sa=X&oi=product_catalog_result&resnum=1&ct=result#ps-tech-specs
Here is a write up of the Asus mother board: http://www.techspot.com/review/43-asus-p5n-e-sli/
Asus FAQ's of the P5N-E SLI. Good place to check questions about the board.
http://support.asus.com/faq/faq.aspx?model=P5N-E%20SLI&SLanguage=en-us
Good luck stukove2000!
Any more questions?
Mike
Oct 08, 2008 | ASUS P5N-E SLI Motherboard
Still didn't work
You have to ensure *********** board is having PCI Express slot or AGP slot for fitting graphics card. if *********** board does not have then you cant use it. normal slot is not supporting it.
connect your monitor video card cab le to newly fitted video output not on motherboard.
Jul 05, 2008 | ASUS P5N-E SLI Motherboard
No signal
try taking out a gig of ram and then start computer.
Jul 03, 2008 | ASUS P5N-E SLI Motherboard
ASUS P5N-E SLI AND A GF7600 ..BOOTING PROBLEMS ..CORRUPTS
Hi, trying to boot from your old drives is the problem.
The Boot sequence for your new board are different from the ol one. Your sequence to get your system going is to load the mobo drivers first, then run your XP disk again and at the second prompt select REPAIR this will run the same as a normal install but should save your existing data and settings.
One problem you may have is activating XP as Microsoft do not approve of multi installs and the new board will show as a different computer.
Regards mistyman
Nov 29, 2007 | Intel Motherboard
ASUS P5N-E SLI BULK PACK of 10, Quad,775 Motherboard Logo
176 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
