Question about Microsoft Xbox 360 Console
Wpa key on modem
How do i find a wpa key on my modem i need for xbox 360 wireless adapter.
  • 360 Answers
I have never seen a "modem" with a WPA key, so I am guessing you mean a "router".
Routers have a configuration menu that is accessible using a web browser. In those configs is where you can get your WPA key.
The documentation to your router will tell you the exact address to enter to open the configs. It is usually http://192.168.1.1
You will also need to know the routers password. If it is linksys, the default password is a blank username and "admin" for the password. But if someone setup the wireless to use a WPA key, they most likely also changes the default password. So you will need to talk to whoever set your router up for that password. If that person is non-existant, you can hard reset the router by pressing the pin sized button on back of it for a few seconds. If you do a hard reset like this, it will erase ALL settings.
Posted on Sep 14, 2009
  • 333 Answers
You need to log in to the modem itself. Type the following in your internet explorer bar:
linksys: 192.168.1.1
dlink: 192.168.0.1
any other models, you need to look at the instruction manual to find the correct address. Once in the setup menu, look for wireless settings.
Do u need a wireless adaptor to set up xbox live??
No, a Xbox 360 Wireless Adapter is not required to access, and set up Xbox Live, but you will need an internet connection. If you are close enough to a modem or router, you can buy an Ethernet cord, and plug it in to both the modem/router, and firmly into your Xbox 360 console. You will either need the Xbox 360 Wireless Adapter, or the Ethernet cord. Ethernet cords are very cheaper, much cheaper than a Wireless Adapter, but the Wireless Adapters are much or easier to reason with. So choose wisely with money.
Jul 06, 2011 | Microsoft Xbox 360 Console
Wpa pass phrase
Although the information you've left is very vague.
I'm assuming you want to know what the WPA passcode is so you can connect to your network to get online Xbox 360?
It will be the wireless password you use to get on the internet with a laptop of sorts. If you have a 2wire gateway/modem its on the bottom of the modem in brackets usually. I'd check to see who setup your wireless router and they'll be able to get you the passcode for your wireless.
Mar 01, 2011 | Microsoft Wireless Network Adapter Xbox...
How do i find wep key from desktop so i can set up wireless for xbox 360
The WEP encryprion key is in your router's wireless setting.
I suggest you use WPA or WPA2 encryption instead of WEP. WPA is a later and much stronger encryption.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions:-
http://www.fixya.com/support/r3559128-wireless_router_security
Sep 18, 2010 | Microsoft Wireless Network Adapter Xbox...
How do i set up the wireless connection for the xbox360. i need a WEP key or WPA passphrase
The WEP or WPA key for your local wireless router would be the same as the one you enter into your Xbox. If you don't know that, you should reset it to something you know on the router.
Dec 30, 2009 | Microsoft Wireless Network Adapter Xbox...
XBOX 360 WIRELESS ADAPTER
I assume the wireless router is configured correctly and the PC can connect to the wireless router and the Internet.
Follow these instructions to configure the XBox.
  1. In the Xbox Dashboard, go to My Xbox and open System Settings.
  2. Select Network Settings, Configure Network.
  3. On the Basic Settings tab, select your wireless settings.
  4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
  5. If your network has wireless security, enter your WEP or WPA key.
  6. Try to connect to Xbox LIVE again
Dec 23, 2009 | Microsoft Wireless Network Adapter Xbox...
I have plugged in a wireless adapter for the 360 but...
A red steady light on the adapter means it is ready to be connected to a wireless network. If it fails to connect then the WPA key is not correct.
WPA automatically changes keys on a frequent basis for security purposes. So you need to take note of the SSID (wireless network name) and the Wireless security settings (WPA and passphrase) from the wireless access point/router.
Once you have the wireless network settings on the access-point/router, go to the System area to enter those settings.
If all settings are correct, exit the System area. Your console should now be connected to your wireless network.
Hope this helps! Good luck!
Oct 01, 2009 | Microsoft Wireless Network Adapter Xbox...
My wireless has a WPA key and Abox is asking
  1. Plug in the Microsoft Xbox 360 Wireless Adapter to one of the USB ports on the back of your Xbox 360.
  2. Turn on your Xbox 360 and navigate to "My Xbox" and then "System Settings."
  3. Go to "Network Settings" and then "Configure Network."
  4. Select the appropriate settings for the wireless network you will be connecting to on the "Basic Settings" tab.
  5. Enter the name of the SSID of the wireless network you will be connecting to. If the SSID is not broadcast, select "Specify Unlisted Network" and enter in the SSID of the network manually.
  6. Enter in the wireless security key (WEP or WPA) so that your Xbox 360 can access the network.
  7. Select "Test Xbox Live Connection" back on the "Network Settings" screen to verify that your Xbox 360 is now connected to the wireless network and ready for use.
Should work for either WEP or WPA
Sep 24, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
What is a wpa?
wpa is secutiy of the wireless device protection you have to give same password in the xbox which is give in the wireless device
Dec 31, 2008 | Microsoft Wireless Network Adapter Xbox...
Cannot change wireless settings on XBOX 360
xbox only supports wpa or wpa key,
its possible that your wireless security is in wpa 2,
Nov 26, 2008 | NetGear WGR614 Router
Put the wpa key in for xbox360, says it's connected but green light not coming on my xbox wireless adapter. if i reset the belkin will it pick up my xbox?
maybe. do you have internet connection in your house? if so the wireless adapter should pick up the signal. i myself have xbox 360 live and use a wireless adapter. It also might just be your adapter. lots of people use the ethernet cables that came free with the xbox and plug them into a modem. connection is more fullproof then wireless.
Feb 11, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
561 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
