Question about Copystar Office Equipment & Supplies
I have a copystar CS 2050. We had a power failure and now I have an error 6400. I know that this is an error for the fuser, but there is nothing wrong with the fuser. I had this before and the service guy accessed the service mode and did a reset in a few seconds. How do I do this myself?
    Brigadier General:
  • 3,614 Answers
Do unplug the unit for at least an hour, this can help you reset the unit. Or you have to clear out the memory by accessing the fuse on the power board, you have to remove it to reset unit.
Make sure that your printer was not plug into elec outlet before doing this.
Hope this helps
Posted on Jul 31, 2009
PRINTS DIRTY
dose the toner rub off if so try replacing the fuser also check to see if the fuser is in good shape if it looks fine try the drum only two things that cause it
Jun 11, 2014 | Kyocera COPYSTAR CS-2050 Printer
E 6000
6000 error. Broken fuser heater lamp wire The fuser temperature does not rise after the fuser heater lamp has been turned on
Nov 12, 2013 | Kyocera Copystar CS-1820 Black and White...
I have a print mode error on my Kyocera Mita CS-2050 KX How do I reset the copier?
what the error code ?
if c6xxx you need to rest by program 163 just tell me the error code and i'll help you
thanks
Aug 10, 2010 | Copystar CS-2050 All-In-One Printer
Error code C4000 For a Copystar CS2050
it's mean's laser problem need to change it
May 07, 2010 | Copystar CS-2050 All-In-One Printer
Service code c 6000 comes up what do we do? 314 308 5296
fuser error..nothing you can do but replace the fuser unit..
Jan 25, 2010 | Kyocera Copystar CS-1820 Black and White...
Kyocera cs1820 error 6400
fuser unit problem try to reset it by using mode 163, if it doesnot work change the fuser unit
Jun 23, 2009 | Copystar CS-1820 Copier
KYOCERA copystar CS-1820 ERROR C6000
Your problem is heat related, or the lack of heating at least. one of 2 things went wrong here... either the fuser unit overheated causing the thermal fuse (aka the thermostat) to blow, or the heating lamp in the fuser unit is blown. Basically the 6000 code is displayed when your machine fails to reach the correct temparature at a specific time. Unfortunately you will have to call a service person to check which to of the mentioned components are at fault and to replace that component for you. After replacing, the component the code will still be displayed as a safety measure, so the service representative will need to clear the code via the machine's service mode
Sep 22, 2008 | Kyocera Copystar CS-1820 Black and White...
Unrecognizable error code
press 10871087 menu will appear then go to c codes list
Apr 09, 2008 | Copystar CS-2050 All-In-One Printer
27 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
Oloyede Monsuru
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
