Question about Radio Communications
The batteries in my 2-way radios won't hold a charge and are old. Can I get regular rechargable batteries and use them?
    Scholar:
  • 146 Answers
You can easily find reasonably priced aftermarket batteries from a number of web retailers on the internet, go to Froogle.com and put in th ebattery description, it should return a number of places to buy thne correct batteries
Posted on Sep 17, 2009
  • Keith  Kalish
    Keith Kalish Sep 17, 2009
    You can easily find reasonably priced aftermarket batteries from a number of web retailers on the internet, go to Froogle.com and put in th ebattery description, it should return a number of places to buy the correct batteries
Motorolla walkie talkie shuts off when PTT button is pressed... Driving me INSANE. Please help
This is usually a low battery issue. If you are using the rechargeable battery pack, does your Motorola unit accept regular batteries in place of the rechargeable battery? If you can put in 3 or 4 AA batteries (depending on the model), try that. If the radio stays on when you press the PTT button, then continue using the regular batteries or get a replacement rechargeable battery, if you can find one for the model. If the radio still turns off when you press the PTT button with fresh batteries, then replace the two-way radio.
I hope this helps. When the rechargeable batteries fail, they will still charge but they won't hold a full charge for as long a period.
May 20, 2018 | Radio Communications
My walkie talky batterys won,t hold a charge. only couple tries and dies?
The battery has to be Ni-Cad, nickel metal hydride, or lead acid types to be rechargeable and you have to use the proper charger.If the batteries are new, get your $$ back; if they are old they might need replacing. If they are carbon zinc or regular alkaline they can't be recharged. Of course, read the manual.
Mar 01, 2015 | Radio Communications
Radio shack walkie talkie 21-1914 replaced batteries will not charge
Hi pearl,
A simple problem to solve at last!!!
Inside the battery compartment you should find a switch, which indicates Recharge/Normal, make sure you select recharge if your using these batteries, otherwise no charging occurs.
If this does not work, take out the recharchables and select normal on switch, place fully charged normal batteries into the compartment, making sure you put them in the right way around, close the flap and turn on the radio, if this works, then your battery switch is faulty, however, you can get lithium ion batteries, which will last longer than most other high duty batteries.
The cost of getting these radios is not worth the money, unless you are technically minded and buy the repacement switch and repair it yourself.
Otherwise try all of the above, and remember, when charging batteries that are rechargeable, never leave the radio on, as this can wear out your batteries quickly.
I hope this advice is helpful to you.
Best regards,
Peter
Jan 12, 2013 | Radio Communications
Battery will not hold charge
If the rechargable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 14, 2012 | Sony Nwz-w262 Water Resistant Mp3 Player...
Nwz-w262 battery will not hold charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 14, 2012 | Audio Players & Recorders
Will not hold charge
Nov 02, 2012 | Kodak EasyShare DX6440 Digital Camera
My eclipse cld 4gb mp3player wont hold a charge
Oct 17, 2012 | Mach Speed Trio Eclipse 4GB CLD MP3 Purple...
It worked for a while and I was able to recharge it, but now it won't hold a charge.
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Sep 01, 2011 | Cell Phones
Where can I get a new rechargable battery pack? Mine are 5 years old and no longer holding a charge.
See: http://www.batteryuniverse.com/Two-Way-Radio/Motorola?gclid=CO7npdfTyaUCFVB95QodeU98Zg
The batteries cost almost as much as a set of new radios
Nov 30, 2010 | Motorola TalkAbout T5530 2-Way Radio
How to charge battery in Motorola Talkabout Distance DPS
You can obtain a wall adapter style charger for your radio at your local Motorola dealer, or online at http://www.eradiostore.com/cart/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&epcode=Y&q=htn8232
Sidenote: The rechargeable battery is good for about 2 to 3 years. You can tell the age of your battery by looking at the date code on the back of the battery above the stop sign. The first number is the year, the next two numbers are the week of the year. 915 would be 2009 the 15th week. (Or if very old it could be 1999 the 15th week.) A good battery, when charged will go an 8-10 hour day.
Keep both of your charge trays, replacements for these are no longer available.
Apr 12, 2009 | Motorola Talkabout Distance DPS (10...
Radio Communications Logo
47 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
