Question about Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN All-In-One InkJet Printer
Fax error message = TX cancelled:RX fax info mismatch???? Cannot send fax - How do I fix this error - Not all faxes return this message
  • 3 more comments
  •  Sharon Gallegos
    Sharon Gallegos Dec 03, 2012
    Bless you, aknz!! I am a new Farmers Insurance agent and agency owner... the training doesn't come with tech support!! I googled the error message, clicked on the link, did both of your recommendations (Canon MX420 All-In-One) and voila!! Lifesaver, thank you so very much!!
  • Anonymous Mar 12, 2014
    Recently, I cannot send faxes from my 426, but can receive them. "Tx cancelled: Rx fax info mismatch" is the message. It happens with different recipients
  • Anonymous Mar 14, 2014
    tx canceled: rx fax info mismatch
  • Anonymous Mar 28, 2014
    canon mx922
Two Issues:
1. The Transmission Speed of the MX860 may be too fast.
Solution: on FAX Menu go to Settings>Device Settings>FAX Settings>Transmission Settings >"TX start speed" and change to 14400 or lower (14400 worked for me).
2. The recipient FAX machine may be receiving by a different number than the one you dial. This may occur if you dial a free-calling no.
Solution: Go to Transmission Settings as above>"Check RX fax info" and turn it to OFF. This disables the mismatch issue.
Hope this helps. aknz
Posted on Sep 25, 2009
  • 6 more comments
  • bvillani Mar 19, 2011
    Turning off the Check RX fax info was the solution for me. I was trying to fax documents to a large mortgage company using an 800#. Apparently that number switches over to a number for the actual receiving fax machine. That swicth over caused a default and stopped transmitting. I imagine you don't need to disable this function if the number is a direct number. Anyway, thanks for the solution. It was not mentioned in the online manual for the MX340 but it worked like a charm.
  • arp1757 Sep 16, 2011
    This worked for me too, although I found another problem. In some cases, the receiving fax apparently would not pick up before my machine timed out. I fixed this by adding a 9-second pause after the number so the machine would sit on its hands for a brief spell before it attempted the handshaking bit.
    It worked for me!
  • cna7377
    cna7377 Sep 27, 2012
    Agreed....tried all of the above, same situation with mortgage info, turning off check RX did not work, but incresing pause time seemed to doo the trick.
  • Cotina Oct 09, 2012
    MXPixma340: decreasing the speed to below 14400 did not work for me. Turning off the RX completely did. Faxing IRS
  • Janet Golden
    Janet Golden Apr 24, 2014
    Decreased speed & turned off Rx = sucessful fax. Thank you!
  • Quamie Emmanuells (QEmmanuells)
    very helpful with my mx330. thanks
  • peter_gammon Sep 10, 2014
    #2 did it !!! Thanks very much!!
    ALSO...if you have ability to change ECM (error correcting mode), then turn this to *off* - since most calls are now via the Internet, ECM causes problems.
    Problem Solver:
  • 9 Answers
#2 above solved the problem thanks to aknz
Posted on Jul 30, 2010
  • Adam Szalay Oct 06, 2010
    Solution #2 took care of my issue as well.
    New Friend:
None fixed my issue.... still the same error message
Posted on Aug 21, 2013
Mx870 fax
first check if there is noise on your phoneline , that is one of the major causes of failures in fax transmissions
Aug 21, 2014 | Canon PIXMA MX870 Wireless Office...
Rx Fax info mismatch
Fax with Popfax with no more sending errors, busy signals, paper jam or faxes lost. So easy to setup Popfax service: no phone line installation or hardware purchasing required. Usually it takes only a few minutes to decide which package to choose and to subscribe to an internet fax service. The only things required are a device (Laptop, PC, Tablet or Smartphone) and an Internet connection. Try for free!
Jul 30, 2013 | Office Equipment & Supplies
On the fax machine it says rx error what does it mean
Hey!
A rx error is a error in reception on the fax!!Tx is a sending error!!It can be on the side that sends you the fax and not on your side!!
Hope it helps!
Sep 20, 2011 | Office Equipment & Supplies
Error #059 TX Fax Info Mismatch
From TechSupportForum.com --this worked for me -- change the settings: Settings>Device Settings>Fax Settings>Transmission Settings>Check RX Fax Information>OFF.
Jun 28, 2011 | Canon PIXMA MX870 Wireless Office...
Canon pixma mx 860, I try to fax and get msge NG #059 TX Canceled: RX Fax info mismatch What do I do?? Canon faxing has been one problem after another for me.
its a message from the modem in the fax
make sure the line is ok and he cable connected to the right place
if not helping than its better to send to service
Aug 23, 2010 | Office Equipment & Supplies
How do I change the Baud rate on a canon f80 fax
To set the receive speed
Change RX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (RX or send) speed if this message appears frequently on the LCD.
  1. On the operator panel, press <Menu>.
  2. Press the left '<' or right '>' arrow repeatedly until [USER DATA] appears.
  3. Press [Set].
  4. Press the right arrow repeatedly until [FAX SETTINGS] appears.
  5. Press [Set].
  6. Press the right arrow repeatedly until [RX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [RX START SPEED] appears.
  9. Press [Set].
    1. The factory default RX (send) Speed is 33600 bps.
    2. You can select from the following RX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable RX Speed.
  11. Press <Set>.
  12. Press <Stop> to return to standby mode.
To Set the Send Speed
Change TX Start Speed Setting The message [START AGAIN] will appear if phone line conditions are less than perfect. Decrease the transmission (TX or send) speed if this message appears frequently on the LCD.
  3. Press [Set].
  5. Press [Set].
  6. Press the right arrow repeatedly until [TX SETTINGS] appears.
  7. Press [Set].
  8. Press the right arrow repeatedly until [TX START SPEED] appears.
  9. Press [Set].
    1. The factory default TX (send) Speed is 33600 bps.
    2. You can select from the following TX Speeds:
      14400 bps
      9600 bps
      7200 bps
      4800 bps
      2400 bps
  10. Press the right arrow to display the applicable TX Speed.
You can download a copy of the user manual for the F80 at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=7175
Please make sure to rate this solution. Thanks.
  1. Press <Set>.
Apr 29, 2010 | Canon MultiPASS F80 All-In-One InkJet...
Cannot send or receive a fax. I can hear a click when I hit tone and that?s it. It worked before but after I fixed error 6502 nothing.
(2) Service error codes
on.
- Logic board
#001 TX Document jam
#003 TX / RX Document is too long, or page time-over
#005 TX / RX Initial identification (T0 / T1) time-over
#009 RX Recording paper jam, or no recording paper
#012 TX No recording paper at the receiving machine
#017 TX Redial time-over, but no DT detected
#018 TX Auto dialing transmission error, or redial time-over
#022 TX Call failed (no dial registration)
#037 RX Memory overflow at reception of an image
#085 TX No color fax function supported in the receiving machine
#099 TX / RX Transmission terminated mid-way by pressing the Stop/Reset button
#995 TX / RX During TX (sending): Memory transmission reservation cancelled
During RX (receiving): Image data received in the memory cleared
Error code TX / RX Meaning
##100 TX Re-transmission of the procedure signal has been attempted the specified number of times, but failed.
##101 TX / RX Sender's modem speed does not match the receiving machine.
##102 TX Fallback is not available.
##103 RX EOL has not been detected for 5 seconds (or 15 seconds in CBT).
##104 TX RTN or PIN has been received.
##106 RX The procedure signal has been expected for 6 seconds, but not received.
##107 RX Fallback is not available at the sending machine.
##109 TX After DCS transmission, a signal other than DIS, DTC, FTT, CFR, or CRP has been received, and re-transmission of the
procedure signal has been attempted the specified number of times but failed.
##111 TX / RX Memory error
##114 RX RTN has been received.
##200 RX A carrier has not been detected for 5 seconds during image reception.
##201 TX / RX DCN has been received in a method other than the binary procedure.
##204 TX DTC has been received even when there is no sending data.
##220 TX / RX System error (main program hang-up)
##224 TX / RX An error has occurred in the procedure signal in G3 transmission.
##226 TX / RX The stack pointer has shifted from the RAM area.
##229 RX The recording area has been locked for 1 minute.
##232 TX The encoder control unit has malfunctioned.
##237 RX The decoder control unit has malfunctioned.
##238 RX The print control unit has malfunctioned.
##261 TX / RX A system error has occurred between the modem and the system control board.
1-7
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
on.
- Logic board
Tx Cancelled: Rx Fax Info Mismatch
Can you tell me how you resolved it? Please Email me at:
PalpatineX@comcast.net
Sep 24, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN  All-In-One InkJet Printer Logo
4,062 people viewed this question
old marine
old marine
