Question about Sony Ericsson W380i Cellular Phone
No sound on W380i
I have no sound on my W380i even on the highest ring volume
Sound when ringing
check the profile you are using. Make sure u select the General profile and go to personalize or edit of the profile. Scroll down and go to ringing volume and increase it to the highest. That should do
Dec 08, 2011 | Nokia N70 Cellular Phone
My phones ring style is set to loud detail and volume is at the highest being 7,when I recieve a call it is silent?
Hi There,
As per my understanding you have set your ring style profile to loud and highest volume 7 but still ur phone phone rings on silent when someone calls..
Please change the Profile setting once again as mentioned below:
How to change call alerts and styles?
1.From the general menu, select "Settings" > "Ring Styles" > "Style Detail"
2.If you select one of the styles, ie. "Loud" you can then highlight by scrolling down on the wheel & select "loud detail" & press on the "change" button (top right corner key).
3.Here you will be prompted to change any feature available to the "loud" style: volume, ringtone, alerts, voice mail, text messaging sounds, reminders beeps etc etc. All you need to do is to select the feature you need to change with the directional wheel and press the "change" button for each.
If you think my solution helped u to resolve ur issue please do vote for me..
Thanks
Enjoy!!!
Oct 28, 2010 | Motorola Mobility RAZR V3
My LG220C ringer volume starts at about 0 and slowly increases in volume as you wait. With the Speaker "on" it starts with a loud ring. What needs to be changed to start the ringer volume at my high...
i BELIEVE there is a setting I think in either your ringer volume or in your sounds or tones (sorry I cant be more specific but its been a ling time since I had a phone that even came with that option) that will give an option of ascending ring which it sounds like to me it is set to this you need to change that
Oct 18, 2010 | LG Cell Phones
Ring is too low for a phone and specially for a W series
change hinge FPC cable, work 100%. maincause of this problem is the audio circut in flex cable was broken.
Aug 02, 2009 | Sony Ericsson W380i Cellular Phone
Extremely low sound
had the same problem the hinge used in this model is causing this it get worn out quickly ,i had to replace it thrice within nine months......even pcb was replaced.now having problem with sys port ,i
Jul 13, 2009 | Sony Ericsson W380i Cellular Phone
Can't get speaker volume or audible ringtone
sir
dismantle your phone and clean the contacts of the speaker and buzzer or replace them... it will solve your problem
Feb 04, 2009 | Sony Ericsson W380i Cellular Phone
İPhone not ringing
you can actually move the button , on the top left hand side of your iphone, over the ringer volume, you will see a red or orange dot, this means the switch has you iphone in silent mode, I was stuck on this, until I found it is a actual switch, look at it closely, you can move it. So where you see the red dot, put your finger on it and move it the opposite way, and I do not mean press the button, I mean, flip the switch on it, then your phone will not be in silent mode anymore,,, this was very annoying, I hope it helps anyone that has the same problem.
cheers!
Nov 15, 2007 | Apple iPhone Smartphone
Volume too low
Download the latest driver from SMC corporation and update the phone as instructed.
Before, I couln't hear it ring from 5 feet away. Now I can hear it ring from the next room.
http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_USA&knowsPartNumber=false&productCategory=14&modelNumber=1564&partNumber=3564&downloadType=0&os=0
Sep 01, 2007 | SMC WSKP100 IP Wireless Phone
Sony Ericsson W380i Cellular Phone Logo
301 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
