Question about Sony Ericsson K550i Cellular Phone
Camera doesnt work: when i open the camera and lens cover no image is found only black and it is written that ANOTHER APPLICATION IS RUNNING. CLOSE IT, AND THEN START THE CAMERA.
Webcam doesnt work
Restart the computer and see if the blue light comes back on by itself. If you are still having problems visit the Toshiba support site for your country (or region). Download the webcam application compatible with your version of Windows (32 bits, 64 bits) and reinstall the application. Test it using the Start>Toshiba>Utilities>Webcam Application, or the Face recognition software. You close the running application by clicking the x at the top right corner of the application window
Oct 27, 2013 | Toshiba satellite c660
N86 camera issue
Here are the steps.
  • go to the camera application while the main camera lens is closed. (front camera will automatically be used)
  • Once camera application is up,open the camera lens. (application will switch to main camera)
  • go to video mode (you cant access image mode settings at it will crash the application)
  • go to the settings of the video mode and choose to reset the camera settings.
  • That should fix it
Feb 24, 2010 | Nokia N86 8MP Unlocked Dual-Slider 3G...
The shutters on my Fujifilm E900 wont open or close properly.
Do you mean the lens cover on the end of the lens Is not opening properly, or the shutter inside the lens?
Aug 24, 2009 | Fuji FinePix E900 Zoom Digital Camera
The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
Jul 13, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Cannon PowerShot S2 IS lens is stuck
I have the exact same problem, took it completely apart removed the zoom motor, physically turned the zoom gear and retracted the lens, reinstalled the motor, put it all back together, and found that I had the same problem and the lens wouldn't move out, so im pretty certain that the motor is bad, as the lens moves smoothly once the motor is not attached to it... looking for a replacement motor as i type...
May 29, 2009 | Canon PowerShot S2 IS Digital Camera
My Nikon Coolpix S5 has a broken lens; it son't fully close/ open. The message displayed on the screen says "Lens cover error". Is it something that can be repaired? How much would it cost to fix...
Hi , The lens cover error is because the stepper motor in the camera is unable to open the lens cover. I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. You have written that your lense is broken. In that case you can follow the procedure given in my doc to open the camera. You can replace the camera lens if broken.
Happy debugging Mukesh
Jul 01, 2008 | Nikon Coolpix S3 Digital Camera
My lens cover can't open and close completely.
Have you tried Canon customer support? If the camera is new[ish] you may get it fixed under warranty. A repair price will be high. You could just gently push it back. Or compose your picture to miss that side of the image
Jan 04, 2007 | Canon PowerShot A610 Digital Camera
NEF Image will not open - Macintosh
RAW NEF images from Nikon cameras are proprietary formatted raw data directly from the cameras's sensor. If the images are improperly transferred to the computer they will not be able to be opened and will give an "Unsupported File Format" warning. Macintosh OS X has an "Image Capture" application (found in: Hard Drive/Applications/)that can be used to transfer images. If "Image Capture" is used NEF files will be corrupted and will not be able to be read. Only Nikon View, or manually dragging images from the mounted card, should be used to transfer NEF's. To disable "Image Capture": Double-click to open the hard drive and then the "Applications" folder Double-click "Image Capture" From the "Image Capture" menu choose "Preferences..." In the "When a camera is connected" pop-up choose "No Application" Close the Preferences window and Quit Image Capture After disabling Image Capture, it will not launch when the camera is connected and you can use Nikon View to properly transfer NEF images.
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Sony Ericsson K550i Cellular Phone Logo
83 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
