Question about Compaq Presario 900 /1500 Series EVO n1015v 15. inch LCD Display -285520-001 (285520001) CD-ROM Drive
Power My Compaq laptop won't switch on. When I push the power switch, it won't boot up. When I plug it in, 3 lights light up, the power light, battery charging light and the power supply light. When I unplug it, only the power switch shows. It still emits a faint hum. This has happened before but usually last only a few hours. It's hasn't turned on for a week now and I'm really worried. Please help me.
  • 2 more comments
  • Anonymous Dec 10, 2007
    i plug in my Compaq Presario 1500 Series and nothing happens none of the lights come on and it will not power up
  • TonyBo Jan 21, 2008
    My wife has Coppaq Presario 900 (Series PP2140). For a couple of months it sometimes refuses to power up with the power button.
    My wife has been unplugging both the AC adapter and the battery for a minute, plugging them back and powering up. This procedure did not help today.
    What is the cause? I can fix almost anything electronic but I have to know what the problem is and where to look.
    Thanks in advance.
  • Anonymous Nov 28, 2008
    My laptop won't boot up from the battery only or adapter...
  • altasguy Jan 04, 2009
    I have the same problem with my 5 yeara old Presario 900 laptop. I have tried a version of the presented solution and it has worked a number of times of the last several months. I discovered it by trial and error as I am not a techie. I usually just leave the thing on so have procrastinated looking into the problem. On Christmas Day it turned itself off sometime during the day and now this procedure doesn't seem to be working. Is the timing an issue? I will try again. I would really like to trade up now but I want/need my data, and also want to wipe the hard drive before donating. There is a long thread on a similar problem in another forum but so far as I can tell they did were not successful. I thought about replacing the battery or the BIOS battery but the symptoms do not seem to call for it. Someone else called the 900 a disposable laptop.
It worked for me ty very much [ ben [[ ,,,,,,,,,,
Posted on Sep 06, 2009
    Problem Solver:
  • 6 Answers
Try this:
With the AC adapter and battery installed and it will not power up remove the adapter and the battery. Then plug in the
AC adapter after both have been removed for 30 seconds and let the laptop set for 30 seconds and then unplug the AC adapter and then slide in the batter within 15 seconds and try to start the laptop.
Posted on Jan 20, 2008
Compaq Presario V5000 does not come on
The solution to your problem lies in one of the following three areas:
1.) Your charger is faulty and is therefore not able to pass power to your laptops battery.
2.) The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
3.) Your battery is faulty.
I think possibility 2 is the most likely, although you will have to test possibility 3 by removing the battery and plugging in your charger and seeing if the laptop powers on.If it does power on then that rules out possibility 1 and 2 leaving a faulty battery.
Nov 20, 2012 | Compaq Computers & Internet
Laptop won't boot, power light comes on for a few seconds
take the battery out of the laptop and try it again with just the power supply. If it boots up its your battery. if it does nothing replace charger.
Apr 29, 2012 | Compaq Presario CQ61 Series Laptop Charger...
Compaq Compaq Presario CQ62 white screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 01, 2012 | Compaq Presario CQ62-112TU
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Nothing happens when you push the power button
i could be static build up . this is common. Try taking the battery out and unplug the power adapter. now with both removed press the power button on the laptop for approx 20 secs. then plug it in and see if it boots up.
Dec 02, 2009 | Compaq Presario 700 470024-192 Notebook
Will not boot ... q50. battery light flicker 3 times
This happened to me. In order to fix it, unplug the power source and take out the battery. Hold down the power button for 30 seconds. Then plug back in the power source and the battery and power up the laptop.
This is called resetting the power cycle and should fix it.
Oct 09, 2009 | Compaq Presario CQ60-220US PC Laptop
Compaq presario v4000 laptop won't power up, but battery charge indicator light flashes 3 times when power switch is depressed
I had a Hp or compaq tablet *with swivel screen. I have a hard time myself trying to get it to beam up. what a pesky switch. But I do know what happened to it before it started acting bad.... the spot where I plug in the power cord got extremely loose.. and i had to hold it just so with one leg of mine in the air one under me.. :D joke but you get the point. Just to try to get it to charge up. I didnt know if it was just the plug... I found out later with the help of a charging dock. That it was in fact the chargeing hole... After about 5 hrs playing with the cord in the charge dock to get it just right. It charged up for a measly hr or so. But since then when I use the charge dock the laptop will boot up...
Oct 02, 2009 | Compaq Computers & Internet
C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen. Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Sep 28, 2009 | Compaq Computers & Internet
Presario 2100US not powering up
remove power supplay
remove battery
press and hold power button for 1 min
release button
plug the power supplay
turn on laptop without battery
Feb 21, 2008 | Compaq Presario 2100U Notebook
Compaq Presario 900 /1500 Series EVO n1015v 15. inch LCD Display -285520-001 (285520001) CD-ROM Drive Logo
330 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
