Wiring diagram for a holly duo forced air furnace 80vf replacing melted wiring do to gas leak
    Top Expert:
  • Heating & Co... Master
  • 49,825 Answers
There may be a wiring diagram pasted inside the furnace housing. If not, request the wiring diagram directly from the manufacturer/distributor.
Posted on Mar 12, 2018
Testimonial: "TYVM yes wiring diagram was inside but unreadable.The company was Holly-General Co. division of the Siegler Corp. Pasadena Ca not in business anymo"
Gigatech
  • 259 Answers
SOURCE: REPLACED 10KW FAN/HEAT SEQUENCER AND LOST TRACK OF WIRING
Could not find the E1Eh-020HA but found the E2 series
http://www.nordyne.com/Literature/707716c.pdf
http://www.nordyne.com/Literature/901a.pdf
Hope this helps. :]
Posted on Dec 13, 2007
motor1258
  • 6674 Answers
SOURCE: duo therm air conditionning/furnace thermostat in RV
Checked all breakers & fuses in panel ?
Posted on Aug 14, 2008
  • 10 Answers
SOURCE: NEED A WIRING DIAGRAM FOR 2008 KLR 650
http://www.bigcee.com/faq/KLR650-color-wiring-diagram.jpg
Posted on Jun 14, 2009
  • 4 Answers
SOURCE: i need a wiring diagram for a magic chef furnace
There should bee a wiring diagram on the inside door of the unit, it will show fan speed connections
Posted on Nov 01, 2009
SOURCE: Water leaking out the bottom of my Furnace
I have a forced air gas furnace and water is leaking from just above the area where the hose is attached. I removed the cover but cannot figure this out. It only leaks (a lot of water) when the furnace is running. Please help asap!!! Tthanks so much, Dianne
Posted on Jan 03, 2010
WIRING DIAGRAM FOR BRYANT 127ANA036-A
The blue wire from the Ac goes to the y2 on the board for the furnace the yellow and brown goes to c on the board for the furnace and the last wire goes to y1 on the board for the furnace
Jun 16, 2014 | Bryant 462AJC021BA Air Conditioner
Was wondering if any one knows why my furnace won't heat up?
You need to get the wiring diagrams both for the actual gas furnace and for the thermostat and LABEL each wire so you know where to START!!! Go to the furnace manufacturer web site and request the wiring diagram and sequence chart. Go to the thermostat manufacturer on line and request an owner's manual...
Dec 21, 2012 | Heating & Cooling
The internal fan in front of the filter is blowing air into the panel where the wiring is and heating everything up and melting the wiring and limit switch
Think your talking about the inducer motor. If this is the case, make sure the exhaust pipe is attached correctly, and that there is nothing blocking the flue pipe.
Dec 14, 2012 | Coleman 7990-319p Evcon Gas Furnace...
Firepower furnace model 2242wiring diagram
some FURNACE has the diagram inside of COVERS , please to see behind the covers. However if do not appear please give the mark, model and type of furnace gas or electric
God bless you
Oct 08, 2012 | Heating & Cooling
HELP!! New install of GMUH75-E3A - Main blower starts immediately on power up/ thermostat turn on. Burner never turns on/ignites. AC power is wired correctly and gas supply is connected. Switch is in the...
You need to find out if the problem is in the T-stat, T-stat wire or in the furnace you can do this in a few easy steps
Step 1- Unwire the low voltage from the furnace. Then turn the power back on and see if the blower comes on if it does then the problem is in the furnace and you will need to troubleshoot the furnace (see bottom of page for troubleshooting furnace) if it does not then proceed to step 2
Step 2- Wire the low voltage back up to the furnace (follow the wiring diagram below). And unwire the T-stat, make sure that no wires are touching each other, then turn the power back on to the furnace, if the blower starts then you have a short in the T-stat wire and you will need to pull a new wire. If it does not then proceed to step 3
Step 3- Turn the power back off at the furnace and wire the T-stat back up (follow the wiring diagram below). Turn the T-stat to auto heat 90 if the heat does not start but the blower just runs then you need to replace the T-stat.
http://www.hvac-for-beginners.com/furnace-troubleshooting.html
wiring diagram
Nov 24, 2010 | Comfort-Aire Heating & Cooling
Air conditioner wiring diagrams
What brand of A/C is it? Are you looking for the thermostat wiring? Different Brands use different wiring, but the usual is as follows:
R terminal at furnace is 24 volt Hot
W is the control for the heating cycle
G is used to start the furnace blower
Y is used to start the outdoor A/C
B or X depending on Brand is the 24 volt common
Yellow and B or blue is the other wire that goes to the outdoor unit
If you want more info, I need Brand, and type of unit, gas furnace and A/C, electric furnace and A/C, or is it a heat pump for the outdoor unit?
Hope this helps./
Sincerely,
Paul Gibson
Mar 29, 2010 | LG LWHD1800R Wall/Window Air Conditioner
Heating & Cooling Logo
198 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
