Question about Konica Minolta magicolor 2430 DL Laser Printer
It prints offset I try to print something and it starts the page half way. then after a page or two, the colors are all wrong. cxan thsi be fixed
Hello sir , I have installed Datamax I class printer with my pc & now i want to take the printout by using the bartender software.
previously i used zebra printer so i have label format but now
Problem is :
after give the command to datamax printer
print format comming very small not as per define format.
Posted on Jul 31, 2009
Prints half page
Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
Hope that helps
Mar 09, 2016 | Brother MFC-490cw All-In-One Inkjet...
Some pages offset printing
You need the paper feed tires replaced.
Feb 17, 2014 | Xerox 5500/DT Laser Printer
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
May 24, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
Hp 4600 LaserJet: magenta and black exhausted after 3000 copies, but most of them were only text. Something must be wrong, at least the configuration. Are there any possibilities to save consumer material?
This depends largely on how much toner on the page there was.
Toner use is estimated at a 5% coverage per page so full page photos take a massive amount but is offset by some pages just having a chapter subject heading.
You can set the printer to print in eccono-mode (information menu - print menumap to see where everything is).
Or you could use the printer driver in windows to print in draft mode.
Are you sure there have only been 3000 copies? You can always print off a configuration page which will give you the total number of pages printed each time you put in a new toner and work out "your " average usage or even the average cost per page.
Aug 28, 2009 | HP LaserJet 4600dn Color Printer
Ricoh sp c410 yellow toner is offset in prints
Go into the menu that says maintence )I think) and do the color registration.
Jun 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
Canon imageclass MF8170c print problem
i have Image class MF 8170 c Just printing blank pages.no erro code
apear on display.
Jan 11, 2008 | Canon imageCLASS MF8170C All-In-One Laser...
Hp 7310
If the color cartridge doesn't print the color bars on the alignment page (either, redish pink, yellow or blue) then the alignment process will not finish. Same for the black. If the black cartridge is printing ok, then replace the color cartridge and try this again...
Jan 08, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Epson AcuLaser C1900 starts printing too low
I have a C1900 with an error "Service Req E021". I appreciate any help as to what this refers to please.
Jan 05, 2008 | Epson AcuLaser C1900 Printer
Oki c5100n printing yellow color offset
What is the stats % of drums if low under 50% change them, soon as you add non Gen you throw a spanner in any attempt to fault find, fix is possible toner more than likely drum/drums, do a print of each colour and change drums as indicated by failure in its colour to print, check transport belt is OK and led heads are clean
Nov 13, 2007 | OKI C5100n Laser Printer
Konica Minolta magicolor 2430 DL Laser Printer Logo
282 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
