IBM projector needs a fan replaced but can't find exact model
IBM projector needs a fan replaced but seems to be OEM version from Papst (Typ 512 F/39). From research, it seems that Papst 512 F/2 fan has a tachometer lead but have also heard about fans that have a ''Locked Rotor'' sensor instead. Anyone know how to tell the difference ?
  • 3,267 Answers
A locked rotor indication will stop the rotation of the fan completely, however if the fan is still rotating then it wont show "locked rotor signal". If the projector is still under warranty then locate their nearest service center and get it rectified..................sodeep
Posted on Aug 01, 2009
Fan fail in1110
You should check first the fw version. Tha last fw version is v 3.2.4. if the fw is updated it, replace de fan, if fan is ok, replace ECA controller. InFocus IN1100 Projector
Apr 01, 2014 | InFocus Corp. Open Box InFocus IN1110...
My benq MP 512 shuts down after a few minutes of use. when it shuts down all 3 light indicators are off, fan also goes off.
DONT WORRY THIS IS A REGULAR PROBLAM OF BENQ ,DELL,INFOCUS PROJECTORS UR MAIN POWER SENDER IC IS DAMEGED THROUGH UR PROJECTOR AND BUY EPSON,HITACHI,SANYO PROJECTORS
Mar 12, 2012 | BenQ MP512 SVGA 2200 ANSI 25001 22KG...
The display on my ibm thinkpad r40 is black after initial dim ibm screen. External monitor works fine though. This happened immediately after I used my ibm with a projector this morning? Fn F7 does not...
The problem youve discribed does seem to point to your back light has failed on the laptops lcd display, i dont know exactly how this would accure just using a projector though, go into bios again and try loading factory settings.
This problem could also be the inverter if you cant make out even a slight image on the screen.
let me know what happens. thanks
Jan 19, 2010 | IBM ThinkPad R40 2681
I have IBM 300pl. And it has strange fan problem.
A fan that no longer works will cause a heat problem. While it may not cause a complete failure, it can cause some strange things to start happening. Your best best is to shut the PC down and remove the cover. Restart the PC an determine which fan(s) has stopped working.
At this point, you can either 1) contact IBM for a replacement fan or 2) remove the fan yourself and google the name and model number of the fan to find a direct replacement and either order online or 3) visit a local PC repair shop to buy a replacement fan that matches the defective one.
Buying direct from IBM will probably cost the most, but will be the exact type needed for your PC. Buying locally will probably be cheaper and faster, but may not be an exact replacement unless it is the same model, etc.
When calling IBM you'll need the computer model, serial number and any other identifying numbers on it for them to help you out.
Sep 18, 2009 | IBM PC 300PL PC Desktop
IBM NetVista M41 PC Desktop Os Install Impossible
You probably need an OEM version of XP...not that IBM version. If you buy an OEM version, you can use it many computers. A real XP disc will partition, format, and delete partitions on any functioning Hard drive. Don't buy a recovery disc, please. That just sounds WRONG.
A cheaper solution might be a new Hard Drive...but I don't trust your IBM version of XP.
Apr 07, 2009 | IBM NetVista PC Desktop
Lamp does not glow
Sound pretty much like a dead lamp. Problem could be a fan problem or heat sensor or power ballast. We supply lamps internationally so can assist if required as we ship world wide. Regards Kevin Andreassend http://www.iceav.co.nz iceavtech@gmail.com
Mar 21, 2009 | Sanyo PLC SW15 Multimedia Projector
How to physically unlock an IBM iL1210 projector
unlock hole? where? there is usually just screws holding the top on.
Mar 12, 2009 | IBM MicroPortable IL1210 Multimedia...
3Com SuperStack II 1100 - need new fans
All yo need to know is the physical size, the voltage and current.
They are usually on the little round label. Voltage is probably DC 12v, and the current should be something like 0.5 amp or 500mA, or 215mA or something similar.
Then just you will know which one you need.
Mar 07, 2008 | Computers & Internet
I can't re install windows XP Pro on my IBM T30 2366-86u
its oem, you either need IBMs restore cd for your particular laptop (model) or an xp pro (any service pack will do) OEM disk.
You can not get the OEM disk at best buy, circuit city target etc those are retail versions and will not work. Newegg.com or frys electronics are your best bet, but by buying it from them you are getting another copy of xp pro, just use the cd with the keycode on your laptop and then you can install xp pro on another pc using the code that came with the disk. MAKE SURE YOU ARE GETTING AN OEM VERSION AND NOT A RETAIL VERSION.
Some technical stuff:
 For the xp pro disk you MUST have the COA product key available, this is usually on the bottom of your laptop, for IBMs disk you just have to have an IBM WITH an IBM motherboard as without the motherboard it will not work. For example, the motherboard goes out and you replace it with a non ibm board it will only boot for 3-5 times, the ideaa is that this gives you time to get your documents off. This is per Microsoft agreement with ibm and all other Original equipment manufactures this include hp, dell etc.
sorry if this is too technical for you please let me know.
Oct 30, 2007 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
