Question about OKI C5500n Printer
541: M toner sensor error - this is the message I'm getting. I've replace the toner that does not work. How do I fix the toner sensor?
  • 748 Answers
As the toner cartridge sits in the drum unit, the toner sensor outputs signal to drum unit which in turn conveys it to the printer via electrical contacts.
Try cleaning the contacts that are located on both sides of the corresponding drum unit, and also the contacts protruding from the sides of the drum socket inside the printer. Also reseat the toner in the drum.
If this doesn't solve the problem, try swapping two drum units - if the error now moves to the other color, than there's something wrong with the toner cartridge or the drum, and you have to find out if it's a contact problem between the toner and the drum, or perhaps the toner cartridge is defective - happened to me once.
If the error doesn't move to the other color, it means that something's wrong with the printer contacts - either they are dirty or dead, because of static electricity or something, and the printer needs servicing.
Posted on Oct 27, 2009
    Problem Solver:
  • 5 Answers
"Try cleaning the contacts that are located on both sides of the corresponding drum unit"
By all means, these contacts should be periodically cleaned (toner dust can coat them because they are charged), but these are for the drum unit. The toner sensor is actually magnetic... there's a small rare-earth magnet on a rocker switch under the hood that comes in contact with a similar (polar aligned) magnet on a rod in the toner cartridge. The rocker blocks an opto-electrical switch on the "Sensor Panel" PCB.
Between the LED rasterizers (four of them, one for each of CMY & K), there are rockers with a small but powerful magnet. When the lid is closed, the magnet will touch the top of the toner cartridge, which in turn, has a magnet on a rod that goes up and down with the rollers when the toner is churned in the cartridge. If the toner magnet is not in the position it is supposed to be (you can check it's position with a hand held magnet), the sensor will falsely interpret that no cartridge is present. You may need to replace the toner cartridge, or if you have more time than money, empty the toner cartridge into a clean vessel, disassemble the cartridge, fix the magnet-on-a-wire assembly, reassemble the cartridge, and replace the toner from the holding vessel. Or, just buy a new cartridge.
On the other hand, I've noticed the rocker switches get sticky in lower temperatures (I keep my 2135 in the garage). Maybe a shot of WD40 on the rocker would help, but to do that, you'll need to remove the lid. It's not too hard, there's only about 9 screws, after removing the back panel (another 4 or 5 screws), After a few more screws around the toner sensor panel (a PCB), you disconnect some quick-disconnect switches, and then you can see the rockers (the actual switches are opto-electrical components on the PCB, you might clean them with alcohol, but they are discrete packages that can't be repaired).
This is a major flaw in the Xerox 2135 (probably persists in the 7300 series as well) and the OKI 9200/9300 series upon which the 2135 is based. There's way too much that can go wrong, but the killer is that nothing except the sensor is failing. Very frustrating!
Posted on Nov 18, 2011
We have a Kyocera Mita KM 1510 and I am getting an error code C710 and the add toner light is on. I put in a new toner cartridge but the error message and the light are still on. Any suggestions?
C 710 is a Toner Sensor Problem
Defective toner sensor - Replace toner sensor
Poor contact of the toner sensor connector terminals - Reinsert the connector. Also check for continuity within the connector cable. If none, repair or replace cable.
Developer problem - Replace developer.
Apr 07, 2011 | Kyocera Mita KM 1510 Laser Printer
I have toner sensor error , the screen reads check toner cartridge 541:MToner Sensor Error
In most cases you need to use a can of air and blow out all around your toner and drum area. Then used it inside the printer to clean out the toner inside of the machine. If this doesnt work take out all 4 anc clean everything very well.
Jan 21, 2010 | OKI C5500n Printer
My Oki C3200 has the following error message 541:m Toner Sensor Error
There are several reasons for this message... we will start with the easiest to solve. Here is a link:
http://www.katun.com/downloads/oki-c5100tnrcartiis.pdf
Jun 03, 2009 | OKI C3200n Led Printer
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Error message after installing new tonner
Check the little switch/door on the left hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Oct 30, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
Toner problems
I've had this problem several time. Usually I fix it with a q-tip!
Open the top of the printer and locate the correct toner cartridge. Pull the (blue) lever on the right side of the cartridge toward you to disengage it from the drum. Gently life the toner cartridge out of the printer.
On the right end (the end with the blue lever) there's a small slot. You should see some white plastic in there. Use the qtip to clean off any dirt or toner.
Now replace your toner cartridge and slide the blue lever back to the original position. Close the top.
This USUALLY fixes the problem. (I must stress "usually" because I'm having the problem right now and this procedure won't fix it, but I've fixed it with this method a dozen times before.)
Jul 28, 2008 | OKI C5150n Led Printer
Magenta cartridge empty
When you take the toner cartridge off the imaging unit, is there magenta toner in the open slot of the IU? Assuming that there is nothing wrong with the toner cartridge, you are possibly looking at a bad engine control board.
Jun 11, 2008 | Xerox Phaser 7300DN Laser Printer
Phaser 7300 error message...
The problem is a crazy design in the printer itself! I've now found a reliable fix for this problem which is relatively easy to carry out. You will find the details of how to do it here :
www.michelsplace
Jan 24, 2008 | Xerox Phaser 7300DN Laser Printer
543k toner sensor error
Your indication regarding the 100% does not necessarily indicate a damaged chip (sensor).
Many chips do not work by actually sensing the toner but by usage or other tricks.
We cannot be sure about what happened but replacing the drum and affected items
should solve the problem. Needed parts may be found at
http://www.inkfilling.com/toner-refill-OkiData--C5800Ldn.html
Jan 21, 2008 | OKI C5800dn Laser Printer
"cartridge memory error"
To identify the misbehaving cartridge just replace them one by one with another new, preferably HP cartridge. As far as why, HP makes lots of money by ?encouraging? users to buy genuine HP consumables. While HP?s cartridges are uniformly the best available they are are outrageously priced, thus the refill market. In an attempt to kill the remanufacturing market HP now embeds ?chips? in each of their LaserJet cartridges, unfortunately for HP refillers can replace them too. I?ve found several references to this error message and they are always linked it the printer discovering a remanufactured cartridge. In most of the other cases this automatically disables ?economy mode? printing but you can typically bypass the error message by hitting the enter (check) button on the printer.
Nov 28, 2006 | HP Color LaserJet 3500 Printer
OKI C5500n Printer Logo
1,320 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
