Question about Haier Dishwashers
No water coming when turned on - Haier Dishwashers
  • 547 Answers
This sounds like a stuck float.
Inside the dishwasher, usually on the left side and right by the front, there's a water level sensor, about the size of a bottle of advil.
When the dishwasher is full, this floats up and shuts off the water to keep it from overfilling and flooding your kitchen.
If it gets stuck in this raised position, then the dishwasher thinks it's always full and the water won't turn on.
Check to see if something has become stuck underneath, or if the float is hung up on something.
Posted on Jul 31, 2009
Water pumps turns on but o No water comes out of
Sounds like the pump needs priming. There must be a plug on top of pump. Remove this and fill the pump with water to top. Replace cap an turn on. If keeps loosing prime, you either have a fauly nrv, non return valve not opening or you dont have one at all. Essential bit of kit.
Aug 16, 2013 | Cars & Trucks
I have a Fisher Paykel washer that was leaking water into tub; repair people changed cold water valve but it is still leaking; although not as much. Could it be the nozzle spray holding droplets of...
Hi just read your posting.1st try turning the hot water tap off and see if the water continues to come into the tub.If the water continues to come into the tub then turn the cold tap off.If the water stops coming into the tub after the hot water tap is turned off then you need a hot water valve.If the water stops after the cold tap is turned off then the cold water valve is still faulty.Please reply on how you got on and I will help you further.Looking forward to your reply.
May 16, 2011 | Fisher and Paykel Washing Machines
Will the water only come on going thru the water solenoid only when it calls for water? Or is it suppose to come on at all times when furnace comes on?
The water should come thru the solenoid valve when the furnace's blower motor turns on, and turn off when the blower motor turns off.
Jan 04, 2011 | Aprilaire 600 Humidifier
The hot water will not come on intermitently. I
if your on a private well, it sounds as though your loosing enough water pressure to shut the heater off,.(which is right before the water pump comes on),....tankless heaters turn on by sensing water flow, and of course off when flo stops,......water pressure tanks often need to be re-charged with air for pressure to stay even,....does your water pressure fluctuate?
Jan 10, 2010 | Rheem EcoSense by 7.4 GPM Tankless Water...
No stop tap. cold water coming through cold taps in caravan but no hot water the carver cascade water heater is getting the water hot but it just wont come through the taps in the shower room or kitchen in...
your pipes are clogged, what if you were to not turn on the cold and turn on the hot does any water come out at all, with just the hot side turned on,, if not there could be a valve that has been turned off, or the pipes are clogged
Jun 17, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
No water coming into machine
you might have a clog, or maybe you didnt turn the water on. turn off the water and disconnect the hose get a bucket and turn the water on a little bit if watter comes out try inspecting the water hose in the washing machine and see if something is clogging it
May 08, 2009 | Indesit W 123 Front Load Washer
Dishwashers Logo
525 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Melissa Martin
Melissa Martin
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
