Sewing Machines Logo
Donna Moore Posted on Mar 11, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to zig zag on a janome sewing model 385.4052LX200 what numbers do I set the length dial and the stitch dial on
R.A. Ellis
Level 3:
  • Janome Master 12,731 Answers
  • Posted on Mar 13, 2018
R.A. Ellis
Janome Master
Level 3:
Answers
12731
Questions
Helped
2613531
Points
59176
It really depends on what you want your stitch to look like. A longer stitch length will put more space between the stitches. Shorter stitch length will close the gap between stitches. Stitch width determines how wide the stitch will be.
5 Related Answers
Anonymous
  • 87 Answers
  • Posted on Mar 21, 2009
SOURCE: Stitching Problem
adjust the stitch width to "0". If it still needs adjusting, somehting is sticking in the pattern mechanism
ken dourof
  • 980 Answers
  • Posted on Jul 14, 2010
SOURCE: MC4400 skips on the zig zag stitch when sewing
You must buse an anti static needle otherwise yoiu will miss stitches.
aeroseek
Michael Williams
  • 55 Answers
  • Posted on Dec 12, 2010
SOURCE: My machine sews straight when set to zig zag and
If your using a stretch fabric, youll need to sew in a stiffner tape. if the fabric "flags" i.e moves up and down with the needle it spoils the loop needed to form a stitch. If your having problems with a stiffer fabric it could be just a bad or too thin a needle. Check threading, needle condition and setting.
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on May 30, 2012
SOURCE: My singer sewing machine will not do zig zag stitch the special stitch dial is not working properly
it would probably be a good idea to take the machine in to see if there is any broken or worn parts, since it will not do a zig zag stitch
  • 7365 Answers
  • Posted on Oct 21, 2013
SOURCE: My elna 500 will only sew 2 of the 12 to 14
it sounds like the decorative cam or gear is damaged.. it would be a good idea to have the machine checked
2answers
Zig zag not working on Elna Carina seeing machine
If the zig zag function on your Elna Carina sewing machine is not working, there could be a few possible causes:
  1. Incorrect stitch selector: Make sure you have selected the correct stitch on your machine. Double check that you have selected the zig zag stitch, and not accidentally switched to another stitch.
  2. Incorrect stitch width: The stitch width knob on your machine controls the width of the zig zag stitch. Make sure that the stitch width is not set to zero, as this would prevent the zig zag function from working. Adjust the stitch width to the desired size.
  3. Tension issues: If the thread tension is too tight or too loose, it can affect the zig zag stitch. Check your thread tension to make sure it is set correctly.
  4. Clogged machine: Dust, lint, and debris can accumulate inside your sewing machine and affect its performance. Clean your machine thoroughly, including the bobbin area and the feed dogs.
If none of these solutions work, it may be necessary to have your machine serviced by a professional.
Does my kenmore sewing machine Model number 5151 do zig zag stitch?
I was able to find this photo on the internet. If your machine looks something like this
http://www.worthpoint.com/worthopedia/strong-vintage-kenmore-sewing-machine
Kenmore sewing machine in cabinet model 117 305 Collectors Weekly
Photo gallery Stitch in Time Must Liquidate EstateSales org
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=25&ved=0ahUKEwjXk5Gy3ZTMAhXhyIMKHaaSA_w4FBAWCEEwBA&url=http%3A%2F%2Fwww.searsarchives.com%2Fhistory%2Ffiles%2Fsewing_id.pdf&usg=AFQjCNEavJEwfhMVnix2pT0kwej_RSZ33A&cad=rja
then it most likely has zig-zag. There are a lot of dials and levers on this machine. Most straight stitch machines have only one or two. One dial/lever with numbers from 0-4 or 5 would be the stitch length. The other dial/lever with numbers from 0-4 or 5 would be stitch width, which would make a zig-zag stitch.
1helpful
How do i make the stitches bigger on a brother sewing machine, it is set at number 4 but the stitches are tiny
One dial if for the Width.
The other dial is for the Length.
Do you need a manual; what is the Model name and number?
Singer sewing machine
From the pattern selector (the bigger dial), select the zig-zag stitch. Then, using the stitch length dial (the smaller dial), adjust the stitch length. The closer your stitch length is to "0", the more dense will your zig-zag stitch be.
1helpful
TRADITION 2250 SINGER SEWING MACHINE HOW TO ZIG ZAG
1helpful
My machine will not zigzag. Width setting on on1 length setting on widest
You need to take the width setting up to 4 and length down to 2 or less if you want a close zig zag. You may not want it that wide but usually 4 is the maximum width.
There is probably also a stitch selector if your machine has several stitch patterns it can do. I've looked at an image at http://www.stevekraftrepair.com/uploads/resized-P9200750.JPG and it looks to me like the left hand knob on the front of the machine is the stitch selector and is colour coded in with the images on the front panel. I just can't make out which number is the zig zag, it could be the red number 4??? So you would put this dial onto the zig zag, then turn the other dial up to a wider stitch width and I am guessing that the little blue box lower down the case has the reversing button and the stitch length setting.
Usually it pays to turn the width to zero BEFORE you make changes to the stitch selector, most machines seem to like being treated this way, ie engaging cams inside the works.
Also, it is always a good idea to check what foot you have on before you start sewing a swing needle stitch just to make sure that you don't hit the foot with the needle. Some feet are designed for straight stitch only and have a little hole but obviously this is not going to work for a zigzag stitch.
I hope this is of help and that I have understood your problem.
Don't remember how to set it to do a zig-zag stitch
Generally on most machines you would set the stitch length dial to 2, and stitch width dial to 2. And the stitching selector to the zig zag icon.
If you give your make and model other experts may provide more specific info for your machine.
2answers
Bernette 75 won't Zig-Zag
Is there a stitch width setting and has to be set to a number greater than zero?
1helpful
2answers
What are the settings for regular sewing, I do not have a manual. It has 3 knobs on the front and 1 on top? This might have something to do with my problems.
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
1helpful
I have and Elna su sewing machine and i can't get it to zig zag. Please refresh my memory on the settings i should have it on.
Depends on which SU you have, but you need to move the stitch selector to Zig Zag, then set the stitch length to 2.5 and the stitch width to at least 2.
On the earlier models the stitch selector is a wheel inside the flap on the top of the machine, on the air electronics, it is a coloured dial.
If this doesn't help, check if you've inadvertently moved the needle position to the side setting.
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
