Question about NEC MultiSync LCD2090UXi-BK (Black) 20.1" LCD Monitor
NEC Multisync LCD 2090 UXi Monitor display becomes yellowish
I have NEC Multisync LCD 2090 UXi Monitor,some time the whole display color becomes yellowish ,so not possible to view the color properly.
  • 11 Answers
SOURCE: Power on Green but no display (blank screen)
In the LCD1830 the inverter for the backlight always burns out. They are fairly easy to replace when you remove the back to get inside. A new one is available from MoniServ for $69.99. http://www.lcdpart.com/Products/uhp061104mss.html
Posted on Apr 07, 2007
informatica
  • 1114 Answers
SOURCE: mounting a NEC MultiSync LCD 1560
You need a VESA mounting plate. The VESA Standard defines mounting interfaces, hole patterns and associated cable/power supply locations for LCD/TFT monitors. The monitor you have has a 75mm x 75mm hole pattern as per the spec sheet below: http://www.nec-display-solutions.co.uk/coremedia/download/62980/LCD1560VM-Datasheet-english.pdf There are many types of bracket depending whether you want the panel flat on the wall or to be able to swivel it. You can see some example on the page below: http://www.rs100.co.uk/product_info.php?cPath=30_55&products_id=580&osCsid=15qvrvji4vn4uk49pcidd38q83 You need to search your location for a supplier. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 22, 2007
  • 40 Answers
SOURCE: monitor power shuts off without warning
You might check the filter capacitor on the power supply and see if it is swelling or shorted.
srich
Posted on May 27, 2008
jerryg50
  • 1689 Answers
SOURCE: Problem with an NEC MultiSync 1550V 15" LCD
The power supply section may be failed, or there may be a short on one of the boards causing the monitor to cycle through the protect mode.
Jerry G.
Posted on Jun 03, 2008
Rifaa
  • 99 Answers
SOURCE: nec multisync lcd 2080ux no raster no power indicator light.
If u a tech, try checking the PSU of the monitor for blown fuse or dead driver element ( typically a FET, Power transistor or an Hybrid chip) . U need to take the monitor apart, if unfamiliar, get it to a service tech.
Posted on Nov 08, 2008
Xbox360 to NEC Display NEC MultiSync PA271W
You need a DVI to HDMI connector. You will need to connect the audio separately to your sound system as DVI does not support audio.
Dec 02, 2013 | Nec Display NEC MultiSync PA271W-BK - LCD...
My monitor screen is pink, both the background & the letters/graphics.
Go to control panel then settings then Display and it will give you options to change it, the color is also changed by buttons on the bottom of your monitor.
Mar 12, 2011 | NEC MultiSync LCD1970GX 19" LCD Monitor
I want to use a NEC Multisync 1700V monitor as an external display for my Thinkpad T400. However I get no image when I hook up the laptop and change the display scheme to display on my laptop screen +...
The only I can think of is the resolution setting that your T400 is putting out that your NEC does not like andcannot display, look at the T42 resolution when the NEC is hooked up to it and try to set it to be the same in the T400.
Mar 25, 2010 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Nec Multisync LCD 195VXM+ black screen after turning on computer
I'm thinking your video card is sending a signal the monitor doesn't recognize.
You'll need to start the computer and hit F8 until you get the black and white menu. Choose the VGA mode and it should work well enough for you to adjust the refresh rate or the resolution to get the monitor to work
Aug 28, 2009 | Computers & Internet
NEC Multisync 1770gx lcd monitor goes blank when I move the unit
HI
you must to check the volt at pin 1 of the lcd slot screen you'll get about 3.3 volts if not it can be the problem.
Gilson
flipflopme@gmail.com
Jun 15, 2009 | Computers & Internet
Touch system not working NEC multisync 1550v
You have to install the nec driver for this monitor. I have the same monitor. Im looking for the driver now. There are 2 versions of this monitor with the same model # . You will need to find the driver to the touchscreen model.
May 03, 2009 | NEC MultiSync 1550V 15" LCD Monitor
NEC LCD1980SX - displaying colored blocks not synchro
Have tried NEC technical Support? This looks like a circuit boatd problem
May 31, 2007 | NEC MultiSync LCD1980SX-BK 19" LCD Monitor
NEC MultiSync LCD2090UXi-BK (Black) 20.1" LCD Monitor Logo
81 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
