Question about IBM ThinkPad T60 Notebook
Can't use Cisco VPN client with Paradyne 6211
I use Cisco VPN client to access my company network but the Modem prevent the access of the VPN , I need hepl
  • 32 Answers
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
Posted on Jul 31, 2009
I am unable to access my company's vpn server.
You may have some needed firewall ports blocked on your router. Turn off the firewall temporally and see if your able to connect. Your company IT folks should be able to tell you what ports they need open.
Oct 20, 2017 | Arris SURFboard SBG900 (49402201900) Modem
Have error 442 with cisco client vpn 5.07 on windows 7 - 32 bit - any ideas?
Error 442 - Failed to enable virtual adapter.
No fix yet from Cisco. Try this work around.
Run cmd as Administrator and execute the following command:
reg add HKLM\System\CurrentControlSet\Services\Tcpip\Parameters /v ArpRetryCount /t REG_DWORD /d 0 /f
Mar 24, 2011 | Cisco Systems Cisco VPN Client
I am trying to connect using Cisco VPN through my Motorola wireless router, but cannot connect. I check with my internet service provider and they do allow VPN. Our IT division has checked the...
The devices appear to be in functioning order. However, the connection network requires another computer on which signals are directed towards. The computer server on which network resources are acquirable is unavailable. For example, your devices can provide sevices to another computer if any were avialble. Usually an internet provider would allow acess to several computer with subscription. Consult an internet service provider, examples, at & t, T- mobile, Verizon, boost mobile, or consult any available at your local area. www.at&t.com, www.t-mobile.com, www.verizon.com, Goodluck
Jan 11, 2011 | Arris SURFboard SBG900 Wireless Router...
Client does all the handshacking with the router
forward these ports for your VPN client ip address on your router...
TCP&UDP 50
TCP&UDP 51
TCP&UDP 500
TCP&UDP 10000
TCP 1723
UDP 1701
also disable firewall...
Jul 25, 2010 | Linksys RVS4000 Router
I have an older Cisco PIX 506 with two VPN connections. One links two offices (PIX-PIX VPN) together, another is for staff to access email & files. The file server on the local LAN the PIX is on are...
It could be a missing route... are the file server and email server on the same subnet? If they are then it is possibly not a routing issue.
Also it would be worth checking the tunneling settings for the VPNs... if you have specifed either only the fileserver subnet or specifically the file server address, then this could be the reason they can get to nothing else.
Hope that this has helped a little :)
Apr 09, 2010 | Cisco PIX 506E 3DES/AES bundle (chassis,...
HOW TO CONFIGURE MODEM OF PARADYNE(ADSL 2+)
Basically if your Internet service is DSL or cable it's just a plug and play. Just plug the computer to the modem once the Internet access has been activated by your ISP and your computer should automatically get connection from the modem.
Aug 16, 2009 | Paradyne (6211-A2-200) Router
Cisco VPN Client Error
Hello
Try to switch off the Cisco VPN Stateful firewall.
Apr 19, 2009 | Computers & Internet
Exchange server access problem.
If your cisco vpn client is behind the natted device then you need to allow nat traversal in the head office firewall and if you connect the vpn client through data card it will connect,
Aug 01, 2008 | D-Link NetDefend DFL-700 Firewall
DLink DI-624s - can't get Cisco VPN Client to connect.
The "Virtual Server" setting is designed to give the general public access to a network resrouce (web/ftp/media server) on your internal network. If your the VPN concentrator is external to your network (meaning you'll have to use the internet to connect to it), then you won't need to define a virtual server on the DI-624.
You'll just need to enable the IPSEC and PPTP VPN Passthrough which it sounds like you've already done this. I've run into some ISP's that block VPN connections out of their network. If you have the ability, try to directly connect your laptop into your cable/DSL modem in place of your router and see if you can make a VPN connection, if not contact your ISP, if you can then verify you enabled the VPN passthroughs because your router is blocking them.
GIve it a shot and let us know your results.
Apr 26, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Vpn pass through problem with us robotics model 5461
login to the router and check these things
IPSec Passthrough: Enable Disable               PPTP Passthrough: Enable Disable               L2TP Passthrough: Enable Disable
Oct 29, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
IBM ThinkPad T60 Notebook Logo
162 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
