Question about Sherwood CDC-5090R 5-Disc CD Changer
Is there a way of connecting my ipod to my sherwood cd player?
I have a pair of 250w KAM speakers hooked up to a power amp which i would like to play my ipod through. The only thing i have linked to the amp though is a sherwood CDC - 5090R 5 disc cd player. Is there a way of playing my ipod through the cd player, as i cant see any aux output on it.
Thanks
    President:
  • 547 Answers
The answer isn't with the CD player, it's with the amp.
Does the amp have selectable inputs, or does it just have one input for each channel?
If it's a simple power amp, then you'll have to unplug the CD player and connect your iPod to the amp inputs. I'm guessing that the CD player connects to the amp with RCA (phono) connectors like these ones.
If that's the case, you can get a cable (like this one at Radio Shack, but any office supply store will have one too) to connect your iPod to the amp.
Posted on Jul 31, 2009
Reset sherwood amp
from the rear. if you have analog passive speakers use the black and red connector. if digital active speakers use the rca jack holes
Apr 18, 2014 | Audio Players & Recorders
Sherwood CDC-5506 5-Disc CD Player - does it need Amp ?
Yes you need and amp Look at the disc player there is no volume control or speaker outputs.
Nov 21, 2013 | Audio Players & Recorders
I have a sherwood RX 4109.....can i hook a pair of 6 ohm speakers and then a powered sub?
By design, yes for one pair of 6-ohm speakers used at a time; depends on the sub for the second BUT there is no way to control its volume at the Sherwood.
Mar 25, 2011 | Sherwood RX-4109
Car amplifier has been removed, it was obviously in the trunk hooked up to nine speakers, etc. I just bought the car and there is a pioneer cd player and a seperate cd/dvd player under the passenger side...
I will assume that none of those wires are marked, thus leaving you with the cumbersome task of tracing each wire to its place of origin and properly marking them.
I will also assume that you have a standard hardware configuration whereas the in-dash head unit serves as an input selector and pre-amp for your aux.CD/DVD unit.
A possible shortcut would be to first identify the two power leads( one is a constant 12+ volts & one is a switched 12+ volts that is a remote power lead from the head unit) and the ground that was ran to the missing amp, mark and separate those from the group. Then with a test speaker trial and error those remaining signal (speaker) wires with the in-dash CD player on and loaded so as to find that units signal outputs (there may be more then one pair) You will need to identify left and right output signal pairs by adjusting the head units L & R control and marking those wires accordingly. Next with a pair of signal leads with output, temporarily connect them to all of the other unidentified signal pairs as to determine its speaker and marking them accordingly. At this point you should be able to make your left and right speaker connections.
Note: it will be wise to have a DC voltage tester to check for the missing amp power leads and signal polarity especially if you plan to install a new amp.
I hope this sheds a little light on your problem.
Good luck
Aduz
Mar 14, 2009 | Pioneer DEH-2900MPB, MOSFET 4x50W Max WMA,...
Jensen VM9311TS wont play cd
you are probably mising to power on the factory amp from the vehicle
Nov 04, 2008 | Jensen VM9020TS Car DVD Player
Radio sound but NO cd or ipod sound
Radio is screwed.
But try these these steps:
Clean the eye of the head for reading CD. Must open up the radio.
IPod: check for good connections from Ipod to PCB.
Feb 23, 2008 | Alpine CDA-9856 CD Player
Sherwood 460 equalizer hook up
Connect the EQ to the Sherwood as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop.
The CD player should be connected to the receiver though the CD in's and out's (or if your Sherwood doesn't have a CD in/out, then use AUX or TAPE2).
To hear the EQed signal with all receiver sources (like the CD player) you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Jan 09, 2008 | Audio Players & Recorders
Amps wont stay on
try to look at the connection on the back of the cd player and make sure that the amp power wire is connected to the power wire on the wire harness on the back of the cd player and that should work but i only need one amp for a pair of 6by9s and subs try to bridge the speakers all to one amp that should cause it to sta on while in cd mode hope that helps
Dec 26, 2007 | Kenwood KDC-MP435U CD Player
My Cd and iPod doesn't have sound
Alright I fixed it. My stock Jeep stereo had a speaker amp that was wired in with the power ANT, the kenwood would turn the power ANT off when using other medias. So I had to hook up the BLUE power ANT wire up to the RED IGN wire so that when the car was on both the ANT and AMP would be on when the car was on. There are other ways of hooking this up I could have hooked the ANT wire up to the AMP wire coming out of the Kenwood so that the AMP and ANT would've only been on when the radio was on, but I'm happy with the way this turned out.
Dec 01, 2007 | Kenwood KDC-MP435U CD Player
Sherwood CDC-5090R 5-Disc CD Changer Logo
170 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Josh Whitehead
Josh Whitehead
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
