Question about Western Digital 500GB ELEMENTS 500 GB USB 2.0 Hard Drive
No power on WDelements WD5000
The power LED on the AC adapter is on until you put the powerconnector to de external drive.
The LED goes out and nothing else is happening.
It's not a new hard drive casing that you need, rr_atl, it's a replacement power supply. Western Digital is well know for selling very poorly manufactured power supplies with this hard drive series. The problem you described is a bad power brick.
Posted on Dec 06, 2009
    Problem Solver:
  • 5 Answers
Same thing happened to me. Took it to Geek Squad and turns out that I need a new hard drive casing.
Posted on Aug 17, 2009
My laptop is not powering on help
1.Connect the Ac adapter to a known good power outlet. Check the Power LED indicator on AC adapter (without plugging into the Notebook). We are only checking the power AC adapter to see if that is working.
2.If LED on the AC adapter is not lit (when unplugged from notebook), reseat the AC adapter brick and cable. If still there is no light on AC Adapter replace AC adapter and Power cord.
3.If LED on the AC Adapter goes off only after connecting to Notebook, the issue is with the motherboard. Replace Motherboard, DC-In port (AC adapter connector).
4.If the AC Adapter LED is always ON, take a technician's help and reseat the Power Button Board. You can refer to the Service Manual for details on how to reseat the Power Button Board. (NOTE: Before the notebook chassis is opened ensure all the power connections including battery and external devices are disconnected)
Jun 07, 2014 | Dell Inspiron Laptop 1440
The wd elements 1023 not recognize by my windos 7 32
Will my elements WD5000 Co35-000 work i.e. compatible with Windows 7. Also where can I purchase an AC adapter for this model.
Nov 15, 2013 | Western Digital Elements powered by WD 320...
Acer 5920 aspire wont start
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter for laptop to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
I have a dell Inspirion 9400 and it won't start. When I press the power button, all that happens is the power light and the dvd player light comes on and about 3 seconds it turns off. Does it with and...
It shows no power on your laptop but it shows you the dvd player led comes on then off. I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well. 2. Make sure AC Adapter is not yet connected to the laptop. Press and hold on the laptop's power button for 10 seconds to drain the power flea. 3. Connect the AC Adapter to a known good power outlet, check AC Adapter power LED if it is on. Try to sense if AC Adapter is not making a bit of noise when it is plugin to the wall power outlet. 4. Connect now the AC Adapter to the laptop. Check if AC Adapter LED stays on when it is connected to the laptop. If the LED stays on means the AC Adapter is fine. If the AC Adapter LED turned off check the AC Adapter pin that goes to the laptop AC socket if it is loose. 5. If AC Adapter stays on after connecting to the laptop try to power on laptop. If no power LED comes on then this is motherboard problem. 6. Before replacing the motherboard there is one checking needs to do. If you can open your laptop bottom part then good, do this when laptop is not connected to any power source. Try to reseat the laptop CMOS battery then try to power on laptop after, if still fails then replace motherboard. I hope this helps.
Dec 12, 2009 | Dell Inspiron 9400 Notebook
Cannot get my computer to turn on
remove all external peripherals. remove laptop battery. remove ac adapter.
plug ac adapter to wall power socket without the laptop connected check if the ac adapter led will stays on. if yes then connect it to the laptop and check if the ac adapter led turns off. if yes motherboard laptop has problems and need to be replaced.
if ac adapter led stays off without connecting laptop, try different wall power socket, if still ac adapter led is off then replace the ac adapter.
if ac adapter has light stays on then connected to laptop but laptop cannot even power up even the ac adapter led is on then laptop motherboard needs to be replace.
Dec 09, 2009 | Dell Studio 15 Laptop
Dell precision m50 will not boot power light just flashes when I push the power on button. I have reseated all of the connection in the laptop. I have tried different batteries and different power...
remove external peripherals. remove battery. use ac adapter alone. check if ac adapter has sufficient power or check if ac adapter led is solid green or blue. if not then ac adapter might not giving laptop enough power to power up.
if ac adapter led stays on but some problem check the ac adapter - laptop pin socket if loose or damage. if not then replace mobo.
Dec 07, 2009 | Dell Precision M50 Notebook
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
My dell d600 wont come on even when i put the charger on
If the system shows no power indication when trying to power on or if you get only a momentary flash of the Power LED, then it goes off, the first point to check is the AC Adapter. If possible, try a known good adapter from another D-Series Dell. Check the LED on the AC adapter to see if it is ON before connecting it to the system. If it is and it goes out when you plug it to the system.
If the LED goes out and no other adapter is available, then I'd start with a new AC Adapter. (If you have no known good adapter available, you might try taking it to best buy and see if they can connect the system to a known good there to see if it powers on).
If replacing the AC Adapter does not resolve your issue, the motherboard is the next component to replace.
Feb 20, 2009 | Dell Latitude D600 Notebook
Inspiron 5160 screen is blank
It seems to me the LCD cable is either not properly unplugged or LCD ha gone bad.
Connect external monitor to the laptop and check if you have the Video on the external monior. If everything looks fine on external monitor then you can get the LCD replaced.
In case system does not power up and there are no indications of power.
Here are the steps:
Connect only the AC Adapter and take the battery out.
Check if you have a green led lit on the AC Adapter.
If AC Adapter does not has a green led please replace it with a known good AC Adapter.
If the AC Adapter has a green led but still no power it can be the system board which has gone bad.
Sep 25, 2008 | Dell Inspiron 5160 Notebook
Western Digital 500GB ELEMENTS 500 GB USB 2.0 Hard Drive Logo
1,263 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
