Question about Gorenje Refrigerators
I have a pacific refrigerator manufactured by Gerenje. While the freezer works fine the refrigerator doesn't seem to reach the proper cold temp even at the highest setting. What can I test to see if it is the thermostat or something else? The model is a pc21wh
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 37 Answers
Most likely a circuation fan. In most refrigerators the freezer actuall cools the fridge compartment, hence the need for the circulation fan.
Posted on Jul 31, 2009
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
My subzero 550 never stops running. everything is working fine, just had freezer compressor side charged. it just seems wrong to be always running??
try to adjust your thermostat normal setting maybe you set it to maximum setting thats why the temp. cannot reach even your comp.running long hours. or maybe your ref . is over loaded try to lessen the load or your door is have leakage of cold air try to fix gasket.
Mar 04, 2011 | Sub-Zero 700TC Bottom Freezer Refrigerator
I have just bought a new side by side westinghouse fridge, it is getting a bit cold, but nothing like a really wanted. How long does a new fridge take to get to the desired temp....the manufacture...
If you have the food frozen or water frozen in less than 2 hours with less opening of the doors then the fridge must be working fine. make sure there is sufficient voltage as required for the specified mains requirement.
Similarly once the freezer is working fine your bottles kept within should be chilled by this time.If so your fridge seems to work fine.
Since you have a new fridge you can always have the warranty/service cover which you must be aware of and taken consent for advice..
Dec 30, 2010 | Refrigerators
Freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Mar 28, 2009 | Frigidaire FRT21S6A Top Freezer...
Frezer does not seem to be working in the cold
s it should the ambient temperatures that you said are way to cold to expect the freezer to operate properly. move it indoors and or contact the manufacture and see if the have a kit to put on the unit to work properly.
Jan 10, 2009 | Freezers
Cake Display Freezer Compressor keeps freezer cold
Maybe the guy meant the compressor is going bad.
Jul 24, 2017 | Traulsen Reach in Freezer - G12010
Kenmore 73503 not cold enough
Is the fan in the freezer working?? Is there Ice on the rear panel in the freezer?
Dec 04, 2007 | Kenmore 73503 Stainless Steel Bottom...
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Open Questions:
Refrigerators Logo
357 people viewed this question
Top Gorenje Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Gorenje Refrigerator Expert? Answer questions, earn points and help others
