Question about Pyle PLA2180 Car Audio Amplifier
Pyle pla2170 if i connect the power cabel and amp rem cabel then the resistor burns down
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 33 Answers
The power cable and the rem cable need to have different power sources. The best thing to hook the rem. to is a power antenna wire, or if you don't have a power antenna, you'd need to hook it to the ign. or accessory wire.
Posted on Jul 31, 2009
I have a Pyle pldn73i that has been working great
Check to ensure you have 12v at the B+, and REM terminals. If it all lights up, id suspect a bad amp.
Sep 13, 2014 | Car Audio & Video
My Pyle amp cut off and will not turn on
  • Ensure the device's power switch is on
  • Make sure the device has power connected.
  • Contact Pyle -->
    1-888-318-PYLE / 718-535-1800
Oct 20, 2013 | Pyle Pro PTA1000 1000 Watt DJ Amplifier
Cannot get pyle driver 413 bridgable mosfet1000 watt amp to work with 800 watt subwoofer . followed instructions all the lights are lit but no sound need help
just wondering how you connected the amp . you should do the following steps
1 battery cable with right size fuse at battery
2 remote wire from radio
3 rca cable from audio out from radio
4 ground the amp to a good clean piece of metal
then make connection on the amp
1 battery or power cable to the 12volt connector on the amp
2 remote wire to b+ or rem on the amp
3 rca cabel should be pluged in the channels are using cause you tell me that the amp is 4 channel
from the model numbers
4 clean and scrape off paint on the metal surface you are going to install the ground cable from the amp . make sure your ground is no more than 12 inch max. and is the same gauge as the power cable
5 . run your speaker wires to the amp and make sure your ohm load for the subwoofer is 2 ohms or 4 ohms to make the amp work proper .
if need help on anything email me @ caraduioquestion@gmail.com
Oct 29, 2010 | Pyle Car Audio & Video
Pyle Academy 2300 watt amp not working =(
wrap a striped speaker wire around the back of the rca out put on your cd player and for the record that aint a 2300 watt amp its like a 300 watt amp
Mar 30, 2010 | Pyle PLAM2300 Car Amp
What size amplifier to I need to operate a Pyle Driver Pro 15 inch subwoofer? It is hooked to a 200 Watt amp and there is no sound coming from the speaker?
You may want to check ALL the connections and make sure you are connected properly. You SHOULD surely hear a lot of sound even with such a small wattage amp. Blown speaker? Blown amp? Have them tested. Also the REM or remote line on the amp is a overlooked wire.
Feb 22, 2010 | Pyle Car Audio & Video
Where do i can find the electrical diagram for pyle pla 2170
There isn't one. You will need to contact Pyle and I am almost certain you won't be able to get one for free. Expect to pay $20 for one
Jul 29, 2009 | Pyle PLA2170 Car Audio Amplifier
My amp was recently installed and when the car is turned off, the amp and fan are still running. I have to pull the fuses out. What do i do!? Thanks
you have tho instal a remote cabel from the back off the stereo (its a blue cabel) tho the rem outpout on the apm the remote tells the amp to start when the stereo starts and to turn off when the stereo turns off
Jun 11, 2009 | AudioBahn DUB5004 Car Audio Amplifier
Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
May 23, 2009 | Pyle PLMRA400 Car Amp
Powers isnt turning on but everythings hooked up?
Check the fuses. If the fuse is bad the amp's power supply is burnt. If the red light stays red and never goes green then your amp is in protect mode and the output section is burnt.To test for rem. problem just use a jumper wire (paper clip... or whatever)to jump from +12v power to rem. If rem. wire has no voltage when your radio is turned on that will make your amp come on. then look for the fuse in the rem. line. Good luck !
barneyluc
Oct 03, 2008 | Car Audio & Video
PLEASE HELP with PYLE PLUS GXA-280A
If the ground terminal is connected to a ground wire, the ground wire isn't connected to a good ground.
Sep 24, 2007 | Pyle PLA985R Car Audio Amplifier
Pyle PLA2180 Car Audio Amplifier Logo
105 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
