Question about Hotpoint Ultima WF860 Front Load Washer
My washer is flashing f-10 - Hotpoint Ultima WF860 Front Load Washer
    Scholar:
  • 51 Answers
This means the thermostat has tripped. It's a common fault with these tumble dryers - ours has failed on at least 4 occasions now. I've discovered that it may be possible to fix it by resetting the thermostat:
Unplug the machine!
Remove the heater assembly (rear of the machine - two screws to remove the spindle cover then another half dozen screws and the heater assembly comes away).
Take out the heater - two screws hold it in.
At the top are two thermostats - a white one and a black one. The black one has a small hole in it and can be reset by pushing a pin into the hole until a 'click' noise is heard.
Reassemble, plug back in and test.
Note that even if this fixes the problem the unit will probably show F10 a few weeks later; I think it's just the way these machines are - a design fault.
If the above doesn't solve the problem then it may be worth buying replacement thermostat.
Thank you for contacting www.Fixya.com
Posted on Jul 31, 2009
The start button keeps blinking, WONT LET ME DO ANYTHING
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitIf this pin breaks off, the washer will not recognize that the door has be. ... Whatever cycle I choose, the light just flashes and holding the start button does nothing. ... I don't seem to have a black pin....the normal wash button just keeps flashing ...
GE Washer Start button flashing - DoItYourself.com Community Forums
www.doityourself.com/.../386041-ge-washer-start-button-flashing.html
Apr 6, 2009 - GE Washer Start Button flashing will not start Model WPRB8050D1WW, tried holding start button in for 5-10 seconds, did the unplug for 30 ...
Oct 29, 2015 | Washing Machines
Washer not drianing the on light is flashing 5 times then stops for 10 seconds then flashes 5 times again
Troubleshooting Why the Washer Won't Drain ' PartSelect ...
? 4:19
www.youtube.com/watch?v=PMrqIkM35HM
Nov 25, 2011 - Uploaded by PartSelect In this video you'll learn what causes washers not to drain. Remember, parts are specific to your model and ...
Aug 06, 2015 | Washing Machines
E 10 flashing
The fill time in the unit has been signaled as being too long. This typically indicates the control board is not functioning properly and need a professional service call.
Dec 24, 2012 | Frigidaire Affinity ATF6000F Front Load...
Beko wma765s washer error code 1L and flashing 1200 spin light washer completed wash but when went to load up again refused to start and 1200 spi n light flashing as well as flashing 1L in time remaining...
Main board fault.engineer says not worth fixing.sourced board and replaced myself cost me £50 but have seen it priced at £63 and £86 .got mine by phoning Beko spares. took 10 days tho.as not in stock
May 17, 2009 | Washing Machines
Whirlpool duet washer flashing f- 20.
not enough water coming in washer press pause/cancel twice to clear the codes the check water flow from valves look for dirt clogging the screens at the inlets at the valves kinked hoses make sure valves are full on or water pressure less than 10 psi
Feb 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer control panel flashing and won't restart
I don't know if this is a real solution but it wokred for me. I just unplugged it for about 10 minutes and then plugged it back in. The flashing stopped and I was then able to resume normal function.
Feb 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Soak/prewash led flashing after about 10 seconds...
It is a pressure sensor fault, call in an expert to fix, these machines are far too complex for anyone else to repair Good luck
Feb 21, 2007 | Miele W310 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
120 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
