Question about Makita Rotary Hammer 240 Rpm, 2150 Bpm, 15 Amp
I have bought a 2nd hand makita 1800 chisel hammer is it oil or grease you put into the reservoir on the top of the machine
  • 2,176 Answers
Grease, I would recommend going to Makitatools.com and typing in your model number so you can download an operators manual and it also discusses the lubrication for the tool. Let me know and if I have helped you with your request would you please rate this response accordingly and thank you.
Posted on Nov 05, 2009
What type of oil shall be used in makita hm1304 demolition hammer?
You require Hammer Grease, All good tool shops should have grease to suit. see link below:-
Hammer Grease 90582 for Makita Power Tool eReplacement Parts
Feb 11, 2016 | Makita Hammering
What kind of oil grease goes in a. Hm1301 makita
A-90582 2 tubes of grease 30cc http://www.acetoolonline.com/Makita-Tools-A-90582-Hammer-Grease-30Cc-p/mak-a-90582.htm
Sep 11, 2014 | Hammering
What type of oil
http://www.homedepot.com/p/Makita-Hammer-Bit-Grease-194683-7/205182387
For outside chisels
Inside its depend on the model but most time its a Makita 181490-7 or for the older types Hammer grease Makita P-08361
Feb 19, 2014 | Makita Hammering
Where do I ad oil to a makita hm1500 demolition hammer
Go to http://www.makitatools.com/en-us/Modules/Home/Default.aspx, put your model number in search box in the top right. Two models of the HM1500 will come up, select yours and open the owner's manual. Find the paragraph labeled 'Lubrication' and follow it precicely. Demo hammers are very picky about what type of grease they use and how much. Too thick and they won't work, too thin and they won't lubricate properly and the parts inside are very expensive to replace. Same applies to how much to use.
Jan 20, 2012 | Makita Hammering
WHAT TYPE OF OIL DO YOU PUT INTO A MAKITA 1810 BREAKER
this tool does not require daily maintenance, but if the grease needs to be refilled it takes 60g/2oz of hammer grease part number A-90582. This is packaged in 1oz tubes. They also show oil and that part number is 181118-7. If you go to their site "makitausa.com" you can download or look at the section on maintenance and it shows you how to fill the reservoir. Good luck.
Jun 24, 2011 | Makita HM1810X 70 lb. Breaker Hammer with...
What kind of oil does a makita 80 pound jack hammer use
Makita recommends using their brand of Makita Hammer Grease if you are doing the lubrication yourself.
You did not indicate a model number but all of their hammers have simliar instructions, 2 oz of grease, do not overfill which can cause faulty hammering or tool failure.
Dec 28, 2010 | Garden
What type of oil i will luricate to my makita HM demolition breaker
demolition hammers require hydraulic oil in most cases.
Any good tool shop should have hydraulic oil to suit.
Feb 25, 2010 | Makita Hm1500b 42-pound Demolition...
I need to look at a manual for Makita HR2510 Rotory hammer I think I need to add oil but Im not sure where to put it. Theres a sign on it, a red circle with line through, telling me not put in top port...
There should be a balck pastic cap on top of the metal housing, just infront of the handle. It has two small holes on it. Use a pin spanner or bent nose pliers in the holes to undo this cap (normal thread). this will give you acces to the top of the crank and con-rod only. This does take oil/light grease but it will not spread through to the reduction gearasa t the top of the motor.
What problems are you experiencing with your machine, if it is lack of hammer power it could also be down to worn o'rings or even hammer pipe if it is an older tool. Extra oil or slightly thicker grease will only delay the inevitable if this is the case and I would recomend a full service in this situation as once one ring starts to go the others will soon follow.
Nov 22, 2009 | Makita Drills
Makita 8406C Gearbox oil
It uses grease to lube the gearbox. makita supply their own grease so you should be able to get a small tube from your local dealer. You don't have to use Makita grease though, just general grease should be fine. Not too thick and heavy, or too oily and light. I know that sounds a bit vague. Do you have other machines that you have grease for? SDS hammer drills, saws, any small power tool like that will use a similar type of grease.
Nov 01, 2008 | Drills
Makita Rotary Hammer 240 Rpm, 2150 Bpm, 15 Amp Logo
195 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
