Question about Garden
Have a poulan motor had pre-mix oil in it.put
Have poulan lawn mower.had pre mix oil in it. changed to proper oil changed plug.it's starts but sputters & has little power. father in law had run tool with wrong oil for awhile.
    President:
  • 1,486 Answers
Remove and clean the jets in the carburetor
Posted on Aug 01, 2009
I have recently bought a poluan pro mower. It has been spitting oil in filter and blowing out white smoke from muffler.
sounds like it is overfilled with oil remove oil fill to level line for motor but white smoke means its getting to much gas or is this two cycle engine wich would mean you mixed oil and gas wrong and to make another batch
Sep 22, 2013 | Poulan "Poulan" Push Mower
What kind of oil do i use to mix with gas for my Poulan gas trimmer. Can i use WD30 motor oil or does it have to specifically say its for 2stroke engines? the ratio on the trimmer says 40:1 so i assume...
DO NOT USE MOTOR OIL!!!
There is a special 2-stroke engine oil mix that you can purchase at various stores that have outdoor equipment or you can also find mix at Walmart. There are instructions for proper mixing on the bottle.
Remember not to put 2-stroke mixed fuel in your lawn mower unless it is also 2-stroke (rare). And the converse is also true, do not put your 4-stroke lawn mower fuel in your 2-stroke weed eater.
If this is really helpful, please rate.
Jul 10, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Does the poulan p4tn20sa take a gas/oil mix?
I cannot find any literature on your mower, but I'm guessing it has a 4 stroke Brigg's engine on it. If so, then there is no gas/oil mix requirement. The only engine's where you mix gas and oil are 2 stroke engines, which are not installed on most of today's mowers. There should be a separate place on your mower to put gas and oil in. If so, then you should probably run straight 30 weight oil in it and do not overfill it or you'll ruin your engine. I hope this helps. James.
Jun 26, 2011 | Poulan "" Push Mower
I just purchased a poulan lawn mower at Kents. Have not used yet. Can you add unleaded gas to the poulan lawn mower/do you have to mix the gas?
You do not mix gas in a 4 cycle engine. You have to mix gas and oil for a 2 cycle engine, such as in a weed whacker, chainsaw, or leaf blower. I do not know of any 2 cycle Poulan mowers (or any other brands for that matter). Unleaded gas is all you can buy in the United States and all current mowers will run on it, although they really don't like that new ethanol additive. If your mower is new then it should have come with an owner's manual which will explain what to do, as well. Hope this answers your question.
James
May 22, 2011 | Poulan "Poulan" Push Mower
Need to put oil in and don't know what kind of oil to put in or if it's gas oil mix????
ADD SAE 30 SMALL ENGINE OIL. 18oz TO 20oz
SEARS SALES A 20oz BOTTLE OF CRAFTSMAN SAE 30 OIL FOR $2.59
Oct 12, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
I have a poulan pro 550 Briggs and Stratton Lawn Mower. I need to find theOil Realease Button
tilt the mower down by the handle, and underneath on the bottom of the motor you will find a drain plug. it has a 3/8 square hole in it. This is the oil drain plug.
Sep 24, 2010 | Poulan "Poulan" Push Mower
I evidently put too much oil in the Proulan Pro Lawn Mower. Now I cannot get it started. It sputters at first but will not start. I have cleaned off the spark plug with a paper towel and sand papered the...
First thing is to remove the excess oil. Take out as much as you need to to get to the line on the dipstick. Next, you may want to use a little WD-40 or similar cleaner to spray into the spark plug hole to thin the oil in there. Replace the spark plug and start the machine a number of times until it runs correctly. Using WD-40, remember the term "little". Good luck...Lee
Jul 22, 2010 | Poulan Pro 22" Self Propelled High Wheel...
How do I change the oil on my poulan push mower?
First: Disconnect the plug wire from the spark plug. Safety first. Second, look under the mower deck where the crankshaft comes out of the mower (where blade attaches). Right next to the crank shaft should be a drain plug. Remove the plug, drain oil in a pan, replace plug, put mower back on level surface, and refill in the fill plug on the topside of the engine/deck. Don't forget to reattach the plug wire when you are done.
May 28, 2010 | Poulan "Poulan" Push Mower
How to change oil in poulan pro 650 series model hp-22 mower
Drain plug is under the motor. tip the hole machine back, (handle lying on ground) put something heavy on handle to hold it down, the plug usually is a 1/2 size wrench. Put a pan under machine to catch the oil. Take the drain plug out, drain oil, put drain plug back in, tighten it, and put machine back on all four wheels. Add oil. Take about 3/4 quarters of a quart. SAE 30 or 10w-30.
Apr 14, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
