Question about LG WM-2277HW Front Load Washer
Error "SE" on LG WD-14381FBB
Hello i have a washingmachine LG WD-14381FBB and every time i want to start it appears the letters "SE" and it refuses to work what can i do?
  • 22 Answers
That is a system error code. Try to unplug the machine for 20 minutes to reset the program module.
Posted on Jul 31, 2009
Have WD1295fb model with error SE , tries to start but fails ?
Check the door lock motor and switch assembly to ensure that the switch works correctly. Check with Ohm meter to ensure continuity when operated.
Nov 30, 2013 | LG WD-1295FB Front Load Washer
SE is appearing on the screen of LG washing machine
LG washing machine error code SE indicates a "motor fault" although the error code also says it could be a main PCB fault. They recommend to, "try the motor first". It's vague and you really need an engineer to try and sort this one. You can't possibly justify "trying the motor first" if you are a DIYer unless you at least know how to test a motor for faults and check its connections and carbon brushes (if fitted).
Aug 29, 2011 | LG WD-80130F 7.2kg Washing machine
LG WD-14401TB SE error code
the motor position sensor or the hall sensor part number is
6501KW2002A
May 05, 2017 | LG Washing Machines
Message CL has appeared whch is child lcok. How
hold down the rinse and prewash buttons at the same time for 3 seconds , do the same to start it also.
Nov 12, 2009 | LG WD-1045FH Front Load Washer
ERROR CODE ''SE''
sensor error The connector (5-pin, male, white) in the wire harness is not connected to the connector (5-pin, female) of hall sensor in the MOTOR. ' Reconnect or repair the contact in the connector.
Jun 26, 2009 | Washing Machines
Error code SE on LG washing machine means what?
SE is a sensor problem as per LG support. I will post a follow up after I have recieved the technician in 2 days
Oct 19, 2008 | Washing Machines
SE ERROR ON THE WD-12235FB
Error SE is a sensor problem as per LG support.
you need to change the senser of your machine...
Good Luck!!
Thanks for using FixYa!
Sep 08, 2008 | LG WD-1280FHD Front Load Washer
LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Aug 02, 2008 | LG WD-1280FHD Front Load Washer
It probably means System Error. Have you tried a simple reset. Pull the machine away from the wall carefully, make sure you do not have wet hands or feet, etc and unplug it from the wall. Leave it unplugged for 20 minutes. (Also check to see if it is plugged into an outlet with a little red button on it? is the button pushed in? It should be? ) After the wait, plug the washer back in and see what you have. I hope this helps.
May 22, 2008 | LG Washing Machines
Error Code t
In my LG manual "t" does not say what the problem is but the solution says "unplug the power and call for service"
Jan 13, 2008 | LG WD-1295FB Front Load Washer
LG WM-2277HW Front Load Washer Logo
818 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
