Question about Clarion M275 CD Player
I installed the unit in my boat and it functioned properly until today. I get nothing when I turn it on. the fuse is good. any way to check this out
  • r_d_wiggins Jul 31, 2009
    it is a removable face. is there a way to check the connections to the face?
    President:
  • 1,615 Answers
If you have 12v at fuse and the ground is hooked up then the unit died. or if you have a removabe face its not contacting
Posted on Jul 31, 2009
  • Ernset ( Skip ) Bouvette
    I dont buy the theory that it was corroded by salt. I have a jeep. I keep the top off. I live at Pismo Beach. There is fog almost every day. I have a unit with a removable face. I have never had a issue in the five years it has been installed.. So with that in mind unplug the face and test the brass connectors inside on the stereo part . If you have power to anyone of them you will need a new stereo. If you dont and you have power at the fuse you will need a new stereo. Also the back of the stereo should have its own fuse, This is in addition to the inline one. Usually but not always.
    Dont assume it has power. You need to test for battery voltage. A voltage drop can occur with dirty connections. You need to test where the ground is hooked, then hook up to battery voltage. then do the same with the power. Test at the fuse and groundat the battery. If one test is different from the other you have a voltage drop. ( dirty connection somewhere)
  • 86 Answers
The air on the road compare to the air in you boat are much different. car stereos are not design to install in the boat, it can easily get corroded due to salt
  • wiznet2000
    wiznet2000 Aug 03, 2009
    I agree with your comment, thanks anyway. the bottom line is just poor connections somewhere in the system. it's just a matter of finding it.
I have a bass tracker 2010 Pro Team 175 with a 50 HP Mercury motor. Phenomenal boat. Fished this past weekend and boat would not start when I went to return home. Nothing, no turn over of ignition,
check battery condition with a load test. check charge rate from motor
clean battery terminals and posts to shiny clean
It has been known for batteries to deplete from electrolysis when stationary in the water so ensure that all cables are in good condition
fit a circuit breaker switch on a battery terminal to switch it off when stationary
May 30, 2016 | Boating
Engine blows fuse under cover almost every time I turn it off. Runs fine until I turn it off again.
Hi Bill:
Working from logic only, the reason a fuse blows is that it is getting excessive current. If the fuse blows when the motor is turned off, it would seem possible that the switch is not functioning properly.
I would try to isolate the switch and check it with a continuity meter to see if it is defective.
Jun 13, 2015 | Boating
Kenmore c970
I would suggest not operating it and turning off the main breaker or pull the fuse for the unit, this could be a fire hazzard I would get a service tec to check it out. It sounds like a broken neutral. I do not know the unit so this is just a guess.
Apr 08, 2014 | Kitchen Ranges
Troubleshooting bass tracker boat
kill switch possibly problem.
Jun 26, 2013 | Boating
I have a yamaha R-V703 receiver and it has worked well until today. It was turned up loud and all of a sudden kicked off. Now every time it is turned on and the volume knob is turned it turns the unit off....
Make sure the speakers are connected correctly. Something inside overloaded and could have blew a fuse or is in protection mode. Before taking the unit in for servicing or attempting to opening it, I suggest checking that the speaker wires are connected correctly to your receiver in the back. Even one loose strand of speaker wire touching the steel panel will shut your receiver off when the volume is turned up. If that isn't the problem, then try to unplug all the speakers and test it again to confirm that the speakers are not preventing the receiver from functioning properly. Lastly, if no success, wait a while until the unit cools then try again without speakers connected.
Oct 16, 2010 | Yamaha R-V703 Receiver
Installed this unit today and it won't turn on there's power to the back of the unit but it won't power up.
Check to make sure that the fuse is not blown and make sure that the unit is properly grounded
Jul 27, 2010 | Pioneer AVHP5200BT Car Video Player
Functional error SC548-00
SC548: Fusing unit installation error
- Definition -
The machine cannot detect the fusing unit when the front cover and right cover are closed.
- Possible causes -
• Fusing unit is not installed
• Poor fusing unit connection
Reinstall the fusing unit, ensure proper installation. You will need to enter the service mode in order to reset this error. Enter the service mode, then turn the machine off and then on via the MAIN power switch.
Dec 14, 2009 | Ricoh Aficio 450 Copier
JVC KD-LX333 car stereo turns on, but then shut off and wont...
TAKE IT OUT AND TRY IT ON A 12V BATERRY AND IF IT TURNS ON ITS GOOD AND IF IT DOESNT IS NOT GOOD. IF IT TURNS ON FOLLOW UR CONSTAN AND UR POWER WIRES AND SEE IF IT HAS A FUSE BOX IN THE BOAT/ CHECK THOSE FUSES. AND CHECK UR BOAT BATTERY TOO CAUSE IT COULD HAVE DIED WHEN TESTING THE STEREO TOO IT HAPPENS ALOT ON BOATS
Jul 04, 2009 | Sony CDX-GT210 CD Player
Clarion M5675 won't turn on
Take the stereo all the way out and hook the black wire to the negative terminal and the yellow and the red wire to the positive terminal on a charged car battey. If it still does not turn on you may have fuse in the back of the deck. If not it's probably fried.
Apr 19, 2009 | Clarion M5675-RET CD Player
No sound.
Disconnect speakers one by one and reset the unit each time. If the speaker is blown, or the wires are frayed, it will shut down the internal amp. Also check the fuse in the back of the radio first, it should be near the wire harness. Power cycle the unit as well, unplug it from the power source, plug it back in. Hope this helps.
Aug 16, 2007 | Clarion M475 CD Player
Clarion M275 CD Player Logo
167 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
