Question about Zenith Televison & Video
Old Zenith DVB412 will not respond to anything except OPEN. Will not power down, close, anything. Was working fine before we got a new TV
SOURCE:
Paeroa
  • 457 Answers
SOURCE: DVD Tray won't stay closed
It can only be repaired by the repair shop I think your son broke a lug on the inside it may need a new tray?
Posted on Sep 13, 2007
Enquiry
  • 152 Answers
SOURCE: Can't Open a New File
the registry value for that particular software must have been corrupted.... better uninstall and then search and remove the adobe photoshop registries and then reinstall....
Posted on Jan 31, 2008
mie999s
  • 105 Answers
SOURCE: Old zenith sytem 3 tv not responding to dvd player
yes you need an RF modulator or vcr of cause
Posted on Jun 20, 2008
SOURCE: Programming remote for Zenith DVB412 DVD Player
Here is the response from LG/Zenith customer support:
Unfortunately, this remote has very limited programmability. The manual is correct.
INSTRUCTIONS: Controlling other TVs with the remote You can control the sound level, input source, and power switch of non-LG TVs as well. If your TV is listed in the table below, set the appropriate manufacturer code.
  1. While holding down TV POWER button, press the number buttons to select the manufacturer code for your TV (see the table).
  2. Release TV POWER button. Code numbers of controllable TVs If more than one code number is listed, try entering them one at a time until you find the one that works with your TV.
Manufacturer Code Number
LG/GoldStar 1 (Default), 2
Zenith 1, 3, 4
Samsung 6, 7
Sony 8, 9
Hitachi 4
For further information or troubleshooting, you may contact us at 800-243-0000 for LG Customer Service assistance. An agent will be glad to assist you. Please feel free to contact us with any additional questions or concerns. Thank you again for contacting LG Electronics.
Posted on Feb 17, 2009
SOURCE: zenith wont tune channels
How do I reset and get my channel without the box.
Posted on Oct 29, 2009
VERTICAL LINES ON OLDER ZENITH FLOOR MODEL TV
this was adjusted by the fine tune on the selector It is the picture not being held in place by being out of tune Same as if the picture goes sideways On the real old units there were 2 knobs to make these adjustments.
Jun 10, 2013 | Televison & Video
I have an old Zenith T.V. that works perfectly except that it can not be controlled by the brand new remote I bought. It appears that the T.V. does not respond to the remote. The remote has codes for...
If you have tried all the codes for the tv, and none of them work, the tv might be too old to respond to the newer remotes. Check that the batteries are inserted properly into the remote.
Some older tvs are just not compatible with todays systems.
May 27, 2011 | Televison & Video
Zenith DVD player DVB412 is requiring an entry for a Parental Control Limit on a brand new Across the Universe DVD. I've tried 0000, 3308 to reset the code, the reset button. It looks like others had...
Hello Hummer,
Please follow the instuctions below to reset the password and switch off the parental control on the Zenith DBV412.
1. Switch on the TV and DVD player
2. Switch the TV to the input for the DVD player
3. Remove any disc from the player
4. Press the SETUP key on the Zenith remote to open the on-screen menu
5. Press 2 1 0 4 9 9 using the numerical keys on the Zenith remote.
6. Press SETUP again to close the menu
This will clear any password that has been set. Now you need to switch off the parental control:
8. Press the SETUP key to open the on-screen menu again
9. Use the down arrow to highlight the PADLOCK for the parental control settings
10. Press the RIGHT arrow once to enter the parental control menu
11. Highlight RATING and press the RIGHT arrow once.
You will be asked to set a password. Enter something simple and easy to remember, e.g. 0000 then press ENTER. You will need to confirm the password by entering the same number again, then press enter again.
12. Use the UP/DOWN arrows to highlight UNLOCK then press ENTER
13. Press SETUP again to close the menu
You should now be able to insert your Across the Universe disc and play it. If you are still unable to watch the disc or you are unable to switch off the parental control feature, please let me know.
Regards,
BElectric
Apr 09, 2011 | Zenith DVB412 DVD Player
I inherited a Zenith DVB412 from a relative that passed away. I am trying set it up with my Magnavox TV/Dish network. I am struggling to find the manufacturer's code. I looked in the usefr's manual but...
Here is a link to our online troubleshooting there are codes and instructions here.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Daniel Busa
DISH Network Customer Service
Dec 02, 2010 | Zenith DVB412 DVD Player
My disc is jammed and won't come out.
hello,
the reason the disc is jammed is because the player did not sit the disc properly.
what you will have to do is;
get a screw driver, open the dvd player, you will find a mechanism that presses the cd down to the lens, you unscrew it too and remove the disc that is jammed in it.
press open to see if it would open up, if it does, then you can screw it back together, but if it does not open then there is a fault with the mechanism that open and closes the player. so you carefully check it out and put it back in order and it would start working.
goodluck
Feb 04, 2010 | Zenith DVB412 DVD Player
Jun 20, 2008 | Zenith C27A24T 27" TV
Disc error
when i press play on my dvd/cd player it says error
May 24, 2008 | Zenith DVB412 DVD Player
DVD Player will not play 20th Century FOX disks
The Panasonic is not "region restricted". This is a security safeguard by studios to keep people from region 1 from using region 3 content. Some material is released in other countries first and later in others. This keeps other regions from using the content from other parts of the world before it is relaesed by the studio there. Your Zenith is not a region free player and the Panasonic is. There is sometimes hacks on Videohelp.com for DVD players to be set to "region free" but not all DVD players are built with it. SONY is another non-hackable DVD player.
Jun 09, 2007 | Zenith DVB412 DVD Player
Zenith 1, 3, 4
Samsung 6, 7
Sony 8, 9
Hitachi 4
Jun 30, 2006 | Zenith DVB412 DVD Player
Televison & Video Logo
43 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
