Question about Husqvarna Viking 1
The foot pedal does not make the machine sew but it sounds like the motor is working. The machine does work when you manually turn the hand wheel. It was working before I put the cover on the machine.
You did not say the model or maker of machine but from my experience, their are some model from brother where the belt slips off the motor pulley, this could be your problem.
Posted on Aug 04, 2009
  • Husqvarna Master
  • 1,388 Answers
Is the belt broken ?
Unplug, remove the side panel at handwheel and check....use the old one as a sample to take with you to buy a new one...DO NOT adjust the belt too tight on installation, it will overburden the motor.....or have the repair shop do the job for a little investment in peace of mind
Posted on Aug 02, 2009
Brother sewing maching
On the hand wheel there is the lock that is used to stop and start the needle from being used. This is necessary for refilling the bobbin with thread. If the hand wheel doesn't make the needle work then you will need to do some minor adjustment.
1. On the hand wheel find a small screw and loosen it until it is just about ready to remove.
2. Now tighten the hand wheel.
3. Tighten the small screw again.
It should be ready to use now.
Aug 31, 2016 | Brother Sewing Machines
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
Is the motor in my kenmore sewing machine bad?
will the motor run if you turn it by hand when the power is on
Apr 02, 2014 | Sewing Machines
Bernina 830 Record foot pedal won't engage sewing unless I turn the hand wheel.
your motor is going out. time to replace or rebuild your motor. both are high skill and should be attempted by a professional. take it to your nearest bernina shop.
Feb 07, 2013 | Bernina Sewing Machines
My daughter's brand new, right out of the box Janome 2212 machine is not working. The foot pedal is not engaging the motor so the needle doesn't move up and down. The wheel is pushed in as it
Sorry, but gotta ask is it plugged in and turned on? Check before you answer. (I ask this because it happened to me, set up, ready to go, and no power. After an hour and the machine was in pieces, My son asked if i plugged it in and I snapped "YES, DUH" not seeing him twirling he plug in his hand...he informed me that you must be 10% smarter than anything you operate or eat....at which point he was happy to inform me, the machine was 11% smarter. If it is plugged in and turned on, is the plug to the foot pedal plugged all the way in? Is the machine on? If you get zero reaction, no movement or sound of any kind, the foot pedal my be faulty, it can happen. Take it back to the dealer and they should replace the entire machine or the foot pedal. Good luck and happy sewing.
Jan 10, 2013 | Janome 2212 Sewing Machine
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
The foot pedal makes noise, but won't turn bobbin.
only having the machine check at a sewing machine repair shop can say for sure
Mar 26, 2012 | Kenmore Sewing Machines
Sewing Machines Logo
208 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
