I have to put the tone arm way across to the middle to start the turntable and when I push the stop button,the arm does not return to it`s rest.
SOURCE: Kenwood KD 3070 turntable
There should be a set screw that you can tighten in order to adjust the height return. If you do not have anything like this, perhaps your record is raised too much. How thick is your rubber mat? Do you have any other mats sitting on top of this?
- OPTiC
DJ Pro Audio
www.1200s.com
www.repairnyc.com
SOURCE: Pioneer PL-670 record rejects continually
Are the record size tabs sticking up through the turntable platter cover? They sense the size of the record being played and adjust the run out distance for either 45 or 33 rpm records.
SOURCE: tonearm on turntable wont stay on record
Remove the motor assy and you will see the main nylon large gear, it had 2 metal cams under the one screw on top of it. One is the start cam and it must slide freely on top of the other one cam. Over time the grease binds up under the start cam and it doesnt move back in as the motor moves the nylon cogs around and so it start over gain and again. Degrease and lightly lube the metal cam so it moves freely by using your finger, reassemble and test.
