SOURCE: Hi. I am trying to
Goto settings date and time and tell ps3 you are on daylight savings time. Then delete Netflix and reinstall.
SOURCE: we're unable to connect you
Where unable to connect you to netflix.please try again or visit www.netflix.com/ps3 help for guidance
SOURCE: I was given Netflix (stream-in) for a gift, but can not get it to come onto our tv. Please help.
Your TV must be a 'smart' TV i.e. it should have software enabling it to connect to the internet and access features such as Netflix. If you don't have a 'smart' TV then you can purchase a set top box which can be connected to your TV and will allow you to access on-line services such as Netflix. If you have a 'smart' TV then you still need to connect it to your internet router, either with an Ethernet cable or via WiFi if the TV has WiFi built in (or you can buy a WiFi adapter for the TV). If you connect with an Ethernet cable then the TV will connect to your router (and internet) with no further setup. If you use WiFi then you will need to access the WiFi settings menu on the TV and configure the settings for your router.
go to netflix and amazon to register it,it is different from apple tv
SOURCE: How do I connect my new smart TV to Netflix, it keeps telling me that ther is no internet connection
The TV Needs to be connected to an Internet Connection!
Either Wirelessly, connected to a Hotspot - most likely your WiFi from either your modem or router, depending on how you get online?
Or... Your TV can be hard wired, with a cat cable directly from your Modem/Router to the TV.
If hard wired, double check in the settings page of your TV (Navigate there with your remote) and confirm this.
If wireless, again navigate to settings and scroll to Network Connections, or something similar, (can't be specific since you didn't provide make and model) choose wireless, locate your home network name, enter your Password, and your TV should now connect to Netflix, among other platforms.
Good Luck
