SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
SOURCE: stripped bar stud
Many Sthil chainsaws have replaceable bar studs. The stud threads into the case. Go here: http://www.baileysonline.com/itemdetail.asp?item=QA+0000+953+6605&catID=407
look for part by model number, usually no more than a few dollars. Enjoy
SOURCE: stihl 180 chainsaw,lack of oil to chain and bar
hi there i had this problem check bar studs make sure there tight bar must be flush on chainsaw body not on stud flange if bar is on stud flange there is a gap so oil leaks out near sprocket and not in bar oil channel
SOURCE: stihl saw bar oil pump not working
The first step should not be to replace the pump, there are less drastic things you can look at first. Begin by draining the oil out of the tank and then fishing out the feed line, see that little filter on the end? Make sure it is clean. That alone will fix most of them. Also, on many models of Stihl saws the oil flow rate is adjustable. Flip the saw on its back and look for a little half-circle arrow with a representation of a drop of oil at one end. Using a small straight blade screwdriver go in the hole and turn the adjuster fully clockwise. The last thing only applies if you have had the chain off and removed the clutch drum. If you've lost your retaining clip and had the drum slide out it will disengage the oil pump too. There is a little slot on the edge of the drum that engages the drive wire for the oil pump, so remove your drum and reinstall it making sure you get them lined up.
If those things fail go ahead and replace the pump. They can be had used in good shape for about $25~$45 and you shouldn't have any problem replacing it yourself, I believe dealers get over two hundred to do the replacement. There are also internal parts of the pump that can be replaced but someone else will ahve to tell you about them.
SOURCE: I need a repair manual for stihl ms192t chain saw for down load
Stihl considers ALL IPLs and shop manuals proprietary.
Every time Stihl becomes aware of an on line source they force its removal.
Rules here prohibit any expert from providing you an e-mail address, if I had what you seek I cannot provide a link where you can get it.
You can go here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
A large international collection of chainsaw enthusiasts, sellers and mechanics. Not only can you find what you seek you can find someone that has already done it, experienced the pitfalls you will meet, and overcome them. Please do a few searches before posting any question. Joining an existing thread is almost always more fruitful than posting the 4th, 5th, 6th question all asking the same question. HTH
Lou
There are many threads pertaining to Stihl, many also discuss overhaul of different Stihl models. Good Luck
Testimonial: "I THANK YOU FOR THE EXCELENT ANSWER. I WILL TRY YOUR SUGGESTION TO SEE WHAT HAPPENS SEEMS LIKE A POOR WAY TO RUN A BUSSINES. GEORGE"
