SOURCE: new battery will not charge, shuts down
have you tried connecting it up, leave it for say 8 hours and don't use, try it then?
SOURCE: How can I remove the battery from Nextbook with windows 8.1 Tablet?
Hi
I have had a look at this problem and the best I can find is a webpage here:
http://www.freaktab.com/showthread.php?1303-NextBook-Next7S-Premium-Taken-Apart-with-Pictures!
which does tell you how to get at the battery. However, with its comments about breaking tabs which hold the case together when you take it apart, I'm not sure that I would attempt this. In any case, before you try this, plug the charger into the mains and see if you get a voltage at the tablet end of the charger, using a suitable multimeter, set to a suitable range. If you don't get a voltage here, you need to replace the charger.
I hope this all helps, and just in case you haven't got a manual, you can download one here and save it for future reference:
http://www.nextbookusa.com/pdfs/NEXT5_Manual.pdf
Cheers
Mike
SOURCE: How can I get my Samsung Galaxy Tablet to turn on. The battery is fully charged.
There is usually a method such as holding the on button for a longer period of time. If it is easy to do the other thing that I've found with all sorts of "smart" devices which turn "not-so-smart" is to remove the battery for a minute or so, then put it back in. Many times the unit will turn on as soon as the battery is reinstalled and work correctly again after that. Last ditch effort, unless someone knows about the Galaxy, is a hard reset, there may be a reset button somewhere on the unit, I don't think the Galaxy has a reset button. If the unit still does not turn on it may need servicing.
1. Try the on button for 15 - 20 seconds if you know it is charged
2. Try charging for an hour or two then the 15-20 second hold on button, #1 above.
3. Removed battery (I'd measure the battery voltage while I have it out) wait ~1 - 2 minutes & reinstall the battery. If it doesn't turn on by itself try #1.
4. Nothing works start a service ticket with Samsung, URL:
http://support-us.samsung.com
You might try searching there as well for an answer to see if there's anything I missed.
SOURCE: my nextbook wont hold a charge what do i do
if you have a volt ohm meter check to make sure the charger is working, might be a short in the cable or plug end, its very common
