Question about Philips 42PF7320A 42 in. Plasma HDTV
No image when switching on after overnight off
What are "caps in the power supply" and how can you replace them?
  • 2,237 Answers
Capacitors. they look like small cans on the power supply. if you do in fact know which ones are bad, you need to replace them with the exact same size, type, voltage and microferads. and a soldering iron. not recomended if you have never done it before. but if it's not on the power supply, the caps are a little bigger than the head of a pin, so do not try to replace them.
Posted on Jul 31, 2009
Rca tv won't power on, red display light blinks on and off
Its more than likley a power supply issue bad caps or bad regulator etc. Replacing the power supply board may solve the issue for you. You can get replacement power supply board from www.tvcircuitboards.com
Jan 12, 2013 | RCA L42WD22 42 in. LCD Television
Akai 32 inch LCD TV, unpredictable powering-up issue
The TV has some defects on the board such as leaky/dry capacitors and/or dry solder. This may need attention by a qualified service technician.
Jul 16, 2012 | Televison & Video
Power switch doesn.t turn on tv.
Either the power switch on the remote or on the TV do not work? Any indicator light on the front at all?
If all of the above are true, then you will have to open it up and inspect the power supply main AC fuse, caps, connectors, etc.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 23, 2011 | Digital Lifestyle FA1B32Z 32 in. LCD...
Red power light blinks when tv is turned on and theres no image what so ever
When you remove the back of the set. You will fined a couple of caps on the power supply board that are bulged and they need to be replaced, or you can buy a new power supply at www.partstore.com. If you want to just purchase the caps, you can get them at www.mcmelectronics.com
Oct 16, 2010 | Samsung LN52A650A LCD TV
My tv shut off by itself and will not come back on. I left it off overnight and tried to turn it on but still will not work
you will more than likely need someone to physically troubleshoot it. i have replaced many power supplies under warranty due to bad caps, transistors, and diodes. if there are bulged caps on the power supply it might be a diy thing if you have tools and expertise working with electronics
Jun 28, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Power cord issue? Black Screen with image issue?
The powere cord you are using is fine (the cord is made to handle the 10A load, you are only drawing 1.5A). The monitor uses switching mode power supply that can handle any voltage INPUT between 100v up to 240v. More likely to be bad caps in the power supply. See example of failed Westinghouse due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 01, 2010 | Westinghouse LCM-19v5 Monitor
My TV has been taking about 3 minutes to come on. Every now and then it it has pixels that freeze at a certain color and will clear up when i cycle the power. Is this possibly a power supply problem?
Samsung caps
http://www.avforums.com/forums/attachments/lcd-televisions/128595d1247354171-samsung-40-lcd-one-year-old-beyond-repair-caps.jpg
Above should be a link to a picture of the caps if not google " Samsung power supply caps" and look for other images.
Hope this helps
Once the back cover is removed the caps are obvious to spot (especially with that picture I forwarded) you need to label and remove all the plugs - unscrew the board from the chassis so you can get to the solder side of the board.
Once there all that is required is to observe how the caps are placed in - and + side of caps and unsolder the old caps 10V 1000Uf and replace with new ones of higher value 16V 1000Uf
If your feeling adventurous do it yourself otherwise get quote from a reputable shop.
Also google "Samsung power supply capacitor replacement" and there may be step-by-step instructions with pix.
Oct 22, 2009 | Samsung LN-T4665F 46 in. LCD Television
The problem is when you switch it off, especially using the button it will not come back on. You have to leave it disconnected from the mains for at least an hour, sometimes overnight.
Replace all electrolytic caps on small upright boads on the power supply board.
Be aware of high voltages on power supply leave set unpluged for at least one hour befor working on the power supply to let the main electrolytics discharge.
Ken
Sep 21, 2009 | Dell W2600 26 in. LCD Television
Had a power outage, acer monitor will not power up
Normally there is a fuse that can be replaced inside on the power supply board. The are usually "slow blow" fuses and need to be replaced by an equivalent fuse. Many monitors have a soft switch which is controlled by the main board that tells the relays to supply power from the power supply. The CMOS devices on these boards are very suceptible to static so ground your hand to the chassis before touching any boards. If the backlight is out but there is a faint image on the screen when you look at it closely then the inverter board or CFT tubes are suspect. BTW: watch the Power supply and inverter boards as the caps stay charged and could result in electrical shock. Good luck. Hope this helps.
Jan 03, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Vizio P50 screen refresh
power supply.Definately will need to be replaced. Im actually looking for one to replace myself.TV repairs charge 1200 to repair.
Nov 01, 2007 | Vizio P50HDTV10A 50 in. Plasma HDTV
Philips 42PF7320A 42 in. Plasma HDTV Logo
157 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
