Question about GE Dishwashers
Makes a loud buzzing noise when running, think it is coming from the lower spray arm
  • 547 Answers
My dishwasher (very basic GE model) did this once. The buzzing only happened when it was washing the dishes, not during drain or fill parts of the cycle.
In my case, the issue turned out to be a bit of plastic (part of a drinking straw) that was stuck in the pump assembly. Whenever the pump was on, this bit of plastic was getting dragged over a metal filter plate, and sounded a lot like a kid with a card clipped in the spokes of a bike.
Good news was that I didn't need to buy any parts, simply disassemble the pump housing and pull out the plastic.
Bad news is that it took me a few hours to get the dishwasher out, apart, back together and re-installed.
Good luck with yours!
Posted on Jul 31, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Think I need an impeller for Asko 1355 - everything runs, but spray arms don't turn or spray water.
Does the motor run or just buzz. If buzzing occurs check for foreign object in food chopper or circulation pump impeller. water pressure makes em go. please let us know if that works.
Jul 23, 2012 | Dishwashers
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • Oct 07, 2011 | Frigidaire Professional Series 24 in....
    Lower spray arm seems to be off centre and makes thumping noise when running.
    The one side of the spray arm is probably clogged with food particles. Remove it and clear out the jets in the trailing edge of the arm. The arm is only being driven by the spray from one side and that is what makes it off balance. Check the top spray arm as well, it may be partially blocked as well.
    To prevent this happening in future, make sure that there are no solid particles of food etc. on your dishes before putting them in the machine.
    Mar 24, 2011 | Dishwashers
    Whirlpool cabrio-buzzing noise when water runs
    i think the problem that you have is one of the electric coils from the entrance valve from water. Check if there the vibration comes from there.
    Oct 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Spray arm light comes on also cycle comes to a hault
    Electronics module , time to replace. Vitally
    May 12, 2009 | Dishwashers
    Noise from dishwasher
    Dishwasher makes loud noise in begining. How do I remove lower spray arm to see if something is stuck? Whirlpool DU1055xtpb4.
    Jan 14, 2009 | Whirlpool Dishwashers
    Dishwasher making loud humming noise
    The most common cause of the hum/grinding sound, and often poor cleaning - is a blocked filter or debris stuck below that filter.
    Pretty easy fix: Get a phillips screwdriver near by. Pull out the lower rack (the upper rack can come out if you pull the little gray thingeys on the front of the upper rails.)
    Remove the lower spray arm -- just pull it straight up. Remove nine silver screws from the sump area that holds the filter down. Pull the filter up and out. Rinse the filter as best you can.
    While the filter removed, with a flash light inspect all over the sump area - looking for stuff that should not be there and clean it out. Watch out for broken glass!
    Replace the filter, screws and the spray arm. Fire it up and check your results!
    Good Luck!
    Oct 20, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
    Dishwashers Logo
    429 people viewed this question
    Top GE Dishwashers Experts
    Mike
    Oloyede Monsuru
    Are you a GE Dishwasher Expert? Answer questions, earn points and help others
