Question about Vizio Televison & Video
E550i-b2 Vizio TV. It has sound and picture. However the picture is very dark on the left side of the screen... approximately 1/3 to 1/2 of the screen. Tapping the frame seems to make the dark areas shift around a little or either make it temporary worse or better. Any help is much appreciated.
  • Vizio Master
  • 2,794 Answers
Are you tech savvy?...if so I can give you some things to test if not it will need to be taken in for service
Posted on Mar 09, 2018
  • buy init
    buy init Mar 09, 2018
    Yes, I am technical
  • Larry Mar 10, 2018
    If you haven't already done it remove the back...test the voltages at the LED driver power supply terminals and see if they are all the same, I think you will find one of them that is lower than the others, I didn't pull the manual on your set so I'm not sure how many outputs you have, could be as few as 2 or as many as 6 but I think this model has 2 of them. If you see a variation in the voltages try removing the connector and use some jumper leads and change the 2 around so the left one is on the right, right on the left and see if the darkness goes to the other side of the screen or stays, if it shifts then you have an issue with the power board if it stays and I think it will your going to have to replace some LED strips in the panel to fix it...Good luck
SOURCE:
tvtek
  • 1284 Answers
SOURCE: Dark screen at top of TV picture
If this is a projection set then a center channel speaker sitting on top would have no effect.
Posted on Feb 04, 2007
  • 187 Answers
SOURCE: Vizio P42hd approx. 1" red line on screen, picture shifted
You will need to replace the control board and your TV will be better that a new one.
Posted on May 27, 2009
budmrtn
  • 11361 Answers
SOURCE: VIZIO TV HISSING SOUND VX42L
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Dec 09, 2009
SOURCE: Line of distorion (or picture shift) on screen
Same thing happened to me but it was my cox hdtv/dvr box, I exchanged it and it resolved the problem.
Posted on Jan 15, 2010
  • 1527 Answers
SOURCE: ordered Vizio 056.04167.0001 Power Supply / LED Driver for E550I-B2 the sound worked before switching it out, but picture did not. Installed part & picture only stayed on for a few minutes & no sound.
hi the led in the panel may have shorted out thanks
shaun
Posted on Mar 27, 2017
My VIzio E550i-B2 TV has no picture and no sound. Do I need a new power supply board?
What does the power indicator on the front of the set do when the on button is pushed?
Nov 29, 2017 | Vizio Televison & Video
Vizio 55 inch TV "Vizio E550I-B2" is Darker on the left viewing side, replaced the Power Supply board. And the Screen is still dark on the left side. Any suggestions?
It is a common problem for this TV, it uses a Sharp LED display panel. The problem is the data buffer IC inside the panel ether shorted, or burned open.
Vizio offers a extended exchange warranty if you have the original sale slip.
For more information, you may contact Vizio directly.
Apr 24, 2017 | Vizio Televison & Video
Need a backlight for vizio model E550i-B2
Fixya does not sell replacement backlights.
Oct 08, 2016 | Vizio Televison & Video
Vizio E550i-b2 has no picture
Could be an open internal fuse or power supply failure
Aug 16, 2016 | Vizio Televison & Video
Screen went extremely dark. can't see the image, but the sound is on. Vizio e550i-b2
Hi there
Do you have a remote with this tv?
If you have try going into menu and picture and adjust from there. If you do not have your manual handy you can find it here. Free User Manuals and Owners Guides ManualsOnline com
Look in the. Troubleshooting section.
kolbrun
Sep 29, 2015 | Televison & Video
Televison & Video Logo
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
