Question about RIM BlackBerry Pearl 8100
I have just moved to Vista and when i try and connect my blackberry to my laptop via a usb cable to use desktop manager i get a message 'handheld not found'
Hi you should setup driver of your blackberry at the begining.after then you must restart your computer. and plug in usb cable again. i think if you do these items. you can fix it.. thx
Posted on Jul 31, 2009
How can i receive multimedia messages on my rim blackberry 7100g. is it possible
It is possible if you have a current data plan with your carrier. You should also you handheld software to the latest support version.
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
Dec 06, 2009 | RIM BlackBerry 7290
RIM Blackberry 7290 have problems making calls, the phone will not ring and will drop and produce a call failed. then the signal meter will x out, also if connection is possible will not last more than 3...
This should help: First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Oct 16, 2009 | RIM BlackBerry 7290
M not able 2 make or recive calls on my blackberry 7100 rim handheld all other features r woking properly plz help me out
Try this: First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Oct 09, 2009 | RIM BlackBerry 7100v Handheld
RIM BlackBerry 7100v Handheld(vodafone)
You need to download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Aug 03, 2009 | RIM BlackBerry 7100v Handheld
Screen saying uncaught exception:DSSMA invalid state(5); 23
Perform a hard reset of the BlackBerry smartphone.
1. Remove the Battery and Sim Card from your Handset and Re insert it.
If it's still the same problem.
Perform these steps : -
Take a Back Up of your Blackberry Smartphone
  1. Connect the BlackBerry device to the computer using a USB cable, and open the BlackBerry Desktop Manager.
  2. Ensure that the BlackBerry device is connected correctly. The word Connected should be displayed at the bottom of the BlackBerry Desktop Manager screen.
  3. Double-click on the Backup and Restore icon.
  4. In the Backup and Restore screen, click Backup.
  5. Choose a location where you wish to save your backup file.
  6. Give the backup file a new name or leave the default name in the File Name field.
  7. Click Save.
  8. The BlackBerry device has now been fully backed up.
  9. Back up will be in .ipd file format.
Then in your Handset perform these steps :-
1. Press Menu Key,
2.Select Option Icon in the Menu screen
3.Go to Security Options.
4.then Goto General settings
4.Press Menu key, you will get an option Wipe Handheld select it.
5.Type the password if you get a prompt, default Password "Blackberry"
6.you will get a confirmation message,Data will be Erased.
7.Click Continue.
8.It will start Wiping your Handheld.
9. Once Data is Erased,Handset will Automatically Restart.
To Restore the Data to your B Handheld
  3. Double-click on the Restore Tab.
  4. Navigate to the backup file you want to restore to your BlackBerry smartphone.
  5. Double-click the backup (.ipd) file.
Jul 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry Desktop and Vista
Jun 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
Where can I get the RIM usb driver so that my 8310 can
Solution: First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Jun 10, 2009 | RIM BlackBerry Curve 8310 Smartphone
My Blackberry Curve 8320 does NOT have Blackberry Messenger
If you want to install Blackberry Messenger on handheld do the following steps :
  1. Download the latest BlackBerry Device Software from your service provider's web site.
  2. Install the BlackBerry Device Software onto a computer that has BlackBerry Desktop Manager installed on it.
  3. Connect your BlackBerry device to the computer.
  4. From BlackBerry Desktop Manager, double-click Application Loader and follow the instructions in the Application Loader Wizard to install the BlackBerry Messenger application.
May 20, 2009 | RIM BlackBerry Bold 9000 Smartphone
Cannot browse from laptop with my bblackberry 7100
Try Solution - First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Feb 11, 2009 | RIM BlackBerry Pearl 8100
Blackberry Device Software 8300, Version 4.5
Try this one: First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Dec 24, 2008 | AT&T Blackberry Curve 8300 Smartphone
RIM BlackBerry  Pearl  8100 Logo
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
