Question about Brother IntelliFax-2820 Laser Fax
Can't fax I can make call out and receive calls but can't send fax. I keep getting error poor line connection
  • 313 Answers
Check the cable has been put into the corect connector on the back it has to be put in the socket marked line.. if you have it in the other one for tel the fax cant hook up..Good Luck A
Posted on Jul 31, 2009
ECM error message
Noise in the phone line, or low signal strength during fax transmission can result in fax failures. Noise or poor signal strength can cause a partial or complete loss of fax information during transmission. When Error Correction Mode (ECM) is on, the receiving fax machine checks the fax information for errors during reception. If the receiving fax machine detects an error, the receiving fax requests that the sending fax resend the information. Resending all or part of the information can make transmission times longer, but helps improve the quality of the received fax.
If the phone line quality or signal strength is extremely poor, sending a fax can fail. Turning off ECM can improve the ability of the product to send a fax successfully when the phone line quality is poor. However, the image quality of the received fax might be poor.
If ECM must be off to send faxes successfully, have the telephone service provider check the phone line quality. For an HP Fax, turning off ECM from the control panel does not necessarily mean that fax transmission will not use ECM. Fax products use ECM as follows.
  • All faxes sent in color use ECM.
  • All faxes sent at the highest transmission speed use ECM.
  • The ECM setting affects only sent faxes, not received faxes.
Enabling or disabling Error correction mode (ECM)
  1. On the product control panel, press the Menu button (c01743394.gif ).
  2. Use the arrow buttons (c01073166.jpg ) to select Basic Fax , and then press the OK button (c01335940.jpg ).
  3. Use the arrow buttons (c01073166.jpg ) to select ECM Mode , and then press the OK button (c01335940.jpg ).
  4. Use the arrow buttons (c01073166.jpg ) to select On or Off , and then press the OK button (c01335940.jpg ) to confirm the setting.
  5. Press the Back button (c01496476.gif ) twice to return to the main screen.
Mar 06, 2014 | HEWLETT-PACKARD HP 2140 Fax
I have an HP 8500A printer/scanner/fax. Everything works but the fax. I can receive but I can't fax out. I get error 348, 321 & 358.
Hello and Welcome to FixYa!
Sir/Ma'am these error are basically due the Communication error of Receiving/Remote Machines. But each error shows different meaning.If during fax you receive the Error 348 then it may be because of several reasons like:-
  1. The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise,Other reasons can include power outages and other power-related problems.
  2. When The call-waiting service can cause this error or the remote user pressed the Stop key while the reception was in progress.
You can solve the Error 348 by the following
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
If during fax you receive the Error 321 then it is because of:-
  1. There was a communication error with the receiving fax machine due to poor telephone line conditions.
You can solve the Error 321 by the following:-
  • Set the receiving machine to receive at a slower transmission speed
  • If the session fails after sending several pages of a large document, resend the document as several smaller documents.
If during fax you receive the Error 358 then it is because of:-
  • The remote user pressed the Stop key, causing the session to be terminated.
  • The remote machine encountered a system problem such as no paper or a paper jam. This prevented the fax from receiving any more pages, and caused it to terminate the session prematurely.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote machine encountered an incompatible feature causing it to terminate the session.
You can solve the Error 358 by the following:-
  • Configure the remote machine for document reception by clearing any paper jams, loading sufficient paper, and clearing any other error messages.
  • Configure the local fax machine to use a slower reception speed.
  • Enable or disable the ECM setting.
I hope this solution helps you and you have clear picture in your mind.
Let me know if you have any confusion in your mind
Sir/Ma'am, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Dec 05, 2011 | HP Photosmart 2710 All-In-One InkJet...
Can't send fax. Getting transmission verification report stating NG: poor line condition/ out of memory. HELP!!
There are two possible reasons why your printer display the error message.
1. Poor Line Condition
- electrical interference on the line -Make sure electrical or electronic appliances do not interfere with the printer's phone line
- poor line connection - If you have a phone try connecting it directly to line outlet. Listen to the dial tone, if you hear noisy and static, then you will need to call your local telephone company cause there is a problem in your phone line. If dial tone is clear and stable then try checking the telephone line cord that you use to connect your printer from the line outlet, replace if broken.
- alarm system or another device on same line, these interferes with transmission / reception of the fax machine. Try connecting the printer all alone and then try sending a fax.
2. Memory Full
- There is no space to store incoming fax messages. Delete all stored fax messages.
Apr 09, 2011 | Brother MFC 6490CW InkJet Printer
My brother mfc-490cw I can't send or recieve faxes.
According to the User's Manual for the Brother MFC-490CW:
  • Poor Line Connection indicates an issue with your telephone line (Page 136). If you are sharing the fax line with any splitters or computers, try connecting the MFC-490CW directly to the phone jack and send a fax. If you are still getting a Poor Line Connection error message, call the telephone company and have a repair technician check your telephone line.
  • Out of Memory error message means the machine's memory is full (Page 138).
    Try pressing Stop/Exit and wait until all current operations finish and try again.
    Try clearing the data in memory. To gain extra memory space. turn off Memory Receive (See Page 48).
    Try printing the faxes that are in memory (See Page 49).
  • System Busy error message wasn't in the manual, but I suspect it means there's a current operation in progress and the machine needs time to finish before moving on to another job. Just wait for the current job to finish, then try again.
May 05, 2010 | Brother MFC 490cw Color Inkjet...
I need assistance with fax error codes # 322 and # 358. What do they mean?
Error code 322- There was a communication error with the receiving fax machine due to poor telephone line conditions.
Solution
Error code 358--
Try
Disable ECM mode on your machine.
Try sending a fax to another location.
Mar 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
Our MFC 7840 printer when faxing keeps saying
Depending on your location the line coulod well be poor quality for a sensitive fax. Any spurious sounds on a fax line will cause it to fault.
May I suggest you try the fax on the mainline first before assuming the unit is at fault.
Length of line from point a to b can also reduce the efficiency of signal. It may sound ok to the ear, but resistance may be the factor in reducing the level of the tone that the fax requires to hear and then activate send or receive.It reports poor line condition and even poor memory because it keeps loading to send.
If it does it on the mainline as well then I would be considering a technical call for help. There may be a fault in the unit.
please rwte my help++++Thanks for using FIXYA
Nov 24, 2009 | Brother MFC 7840W Printer
Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Solution
Please Click here and follow the instructions to resolve the issue.
May 21, 2009 | HP Officejet 6310 All-In-One InkJet...
Fax
344 Error can be caused by a few things. One of the following is occurring:
The sending fax has failed to respond to a fax command from the receiving fax due to poor line quality or fax interruption.
The sender has pressed cancel button while the reception was in progess.
In rare conditions, incompatibility has been encountered by two faxes and causes the sending fax to abandon the fax call.
Solutions:
Fax session was using ECM. Check your fax settings under the fax set-up menu on the printer. Disable the ECM (Error Correction Mode).
Fax at a different time to see if line quality improves.
Try relocating the fax to a differnt phone plug.
Replace the phone cord attached to the fax/printer.
Aug 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Brother 4750e
This problem could be Phone line problem, or hardware failure or receiver's (the machine of the person whom you are sending the fax) machine problem and so on. First, let's check the line, if you have another Phone line, please dial from the number to your number, also, connect the currently connected line to a receiver and call a Land-line number, if the outgoing or incoming is ok, the proceed forward, otherwise, you telephone operator should check the line.
Sometimes, sending fax to a particular number doesn't work, to make sure, try sending a fax to another number.
If the line which is connected to the machine is extended from another machine such as Receiver, Switch, etc... unplug them and connect the fax machine directly to the Line.
It's also important to adjust the compatibility mode, to do this, follow the steps below:
  • Press Menu.
  • Press the up or down arrow key to select Fax.
  • Press OK.
  • Press the up or down arrow key to select Miscellaneous.
  • Press OK.
  • Press the up or down arrow key to select Compatibility.
  • Press the left or right arrow key to select Basic (for VoIP).
  • Press OK.
  • Press Stop/Exit.
If you place the scanning document/file on the auto-sheet feeder, you can help it pulling inside the passage or you can use the glass (flatbed) instead. Sometimes, this small mistakes with the sheet-feeder creates this problem. You can also clean the rollers inside the ADF (auto document feeder) passage.
If all of the above measure don't help, I would suggest you to call brother and seek their help. The rest is with mechanical or we can say hardware or firmware related issue. (use this form to contact Brother)
I wish you good luck.
Thanks for using FixYa.
Jun 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
77 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
