Question about Maytag Neptune MDE5500AY Electric Dryer
Dead display on Maytag dryer
Just installed dryer but display shows "18" and no buttons work. Cannot get it past this impasse. Receptacle/110 power is fine. Is there a RESET?
  • 447 Answers
Re: Dead display on Maytag dryer
No unfortunately the only reset it to power dowm. Sounds like either the tuouchpad or control board has failed. I can help with sourcing these parts or any other questions feel free.
Posted on Nov 24, 2007
0 characters
3 Points
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
Maytag Neptune dryer will not turn on...has at least 110 electris coming to it... shows a digital display .8.8 ...
you need 240volts for it to run and heat,the timer and motor are each on their one side of 110volts and the element needs 240volts to heat,so if the motor runs or the timer runs but not both and it doesnt heat your missing one of the 110 to 120volt phases,check the homes power panel it will have either a tandem pole 30 amp breaker or 2 30 amp fuses and one of them will be bad(open) the breaker may look like its not tripped,but sometimes one leg will open and not show,turn it off and back on then check for 240volts at the dryer
Jan 09, 2011 | Maytag MDE5500AYW Electric Dryer
Maytag Neptune Dryer purchased in 2001, Display shows 88, wont start . Can it be fixed?
There are 3 ways i know to make the machine work. Press and try all buttons to see if it clears up, Put a heating pad over the display for a few minutes. if these don't work. You will need a new display unit.
Hope this helps.
Dec 26, 2010 | Maytag Dryers
Maytag Neptune shows power but wont function
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
Apr 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Our maytag Neptune Dryer is showing 8.8 on the display. It has done this in the past and we have had it looked at and they could fine nothing wrong. Now it doesnt work again.
usually thats indicitive of a powerfailure
try unplugging the unit for several minutes
your trying to clear the e-prom
if you cannot clear it that way
more than likely you will neeed a new control
Oct 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag electrical dryer works but it will not heat. It was the top of the line dryer with a computerized panel. I checked all the fuses and element and connetions in and out of the dryer. I was...
check house breaker flip it on and off you if still problem you need voltage check to see if you are getting 110 volts to both legs of your dryer receptacle may need a ac volt meter or electrician
Sep 25, 2009 | Maytag Dryers
No power @ Dryer receptacle
Turn off breaker, Check and tighten lugs that feed dryer circuit at the breaker and at the receptacle, If that doesn't fix your problem you ll have to trace the wiring from breaker to dryer for broken wires.
Aug 03, 2009 | Whirlpool LER4634J Electric Dryer
The prong on the electricle from the dryer is shaped differently then the wall outlet
You need to get a matching dryer receptacle rated fro 220V and 30 Amps (in the US).
Make sure you have the power off before attempting to replace the old dryer receptacle.
I have seen many dryers connected to oven receptacles in the past. While incorrect this is not dangerous because the oven receptacles are usually 50-60 amp.
Paying a local licensed electrician $50/hr is a fair & safe way to make sure your dryer receptacle is installed correctly.
May 15, 2009 | Whirlpool Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
167 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
