Question about SimpleTech Pininfarina 80GB External USB 2.0 SP-UE25/80 (SPUE2580) Hard Drive
Computer doesn't recognize drive anymore
About a week ago my laptop with my Pininfarina 80GB External HD locked up for no particular reason. Since then the External Drive F: will work, but both my laptop and desktops have issues recognizing it as a drive.
When connecting, it shows under the "Safely remove hardware" icon.
It shows in device manager as a working disk drive.
It does NOT show in My Computer.
I usually have to uninstall it from device manager and reboot to reinstall it, (The installation takes MUCH longer than when I first began to use it)
THEN it will show in My Computer, but will not be accessible.
THEN I have to Run chkdrive from the Command prompt and do a lengthy repair. All the data remains intact after I repair.
This happens every time I try to switch it between the laptop and desktop, which is pretty often. Before switching, I DO safely remove it.
This seems to be an issue in particular with the HD, as if it does not actually disconnect from the computers when it's supposed to. Any ideas?
  • robtbo Nov 26, 2007
    I do have a small home network set up, (had not tried sharing drives...that would definitely speed things up while at home) but I work away from home for extended periods and like to have the data available for my laptop.
    Now that you've mentioned it, though, I think sharing the drive from my laptop would be the best solution, it'll just take a little more time to copy the data onto my desktop for safekeeping through the network when I return home. Thank you :D
  • 4 Answers
I I had a similar problem with a SimpleTech 250g Pininfarina USB drive.
I went through the drivers, the power supply, the USB cables, and the various
computers, USB cards and Operating systems.
Finally I opened the case and found the disk drive was mounted too far
forward, causing the IDE connector to barely touch. I loosened the mount screws,
slid the drive back towards the connector, tightened everything down and it works.
Posted on Apr 22, 2008
    Scholar:
  • 116 Answers
Advice,
Sounds like you are swapping this external drive between two PC's. Why don't you do this! Get it connected to one of your PC's preferrably your desktop. Once you get it connected and it is able to be read and you can read files or acces it! Share it out, under Windows XP you can share out drives, files, printers etc.
Once you do this both PC's can share this device without you having to swap between PC's manually!
I can walk you through this if you need further help, but if this persists, it sounds like your files are corrupt on this drive you may need to reformat the drive.
Posted on Nov 26, 2007
Problem with the Mobile Disk External Data Storage Enclosure model HD-338-COMP for my 80gb Western Digital HD
just a suggestion but a few years ago is aeons in tech time maybe, just maybe the drivers for that ext drive were overlapped with OS X migration?
check apple site for more or ext drive site for latest drivers
Jun 02, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
I accidentally plugged my laptop cord (19v) into my Simpletech pininfarina 500gb external hard drive (12v). It was only plugged in for about 20 sec and the HD power light was slowly blinking. I...
Your hard drive is probably dead. However there are stillhopes for hard drive datarecovery.
Put the hard drive in a plastic bag to be compatible for the freezer. Freezingsometimes works to revive a dying hard drive, at least for a shorttime(Probable just about 20 minutes), but be sure that the bag is sealedtightly so that condensation and ice crystals don't form. Put it in yourfreezer for 24 hours that will do the trick. While it's still cold, plug itinto your computer. And you may be able to view it in 'my computer'. And youmay act quickly, because you may only have 20 minutes to recover your data offit and after that the hard drive is completely dead.
If it fails, you will have to go to a recovery office where supply datarecovery service but let's hope not because it will cost you a lot of money andwhether they can recover data is not guaranteed.
Here is a tutorial to guide you how torecover hard drive data.
Aug 31, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
My 80GB drive is not recognized anymore by any laptop, the blue and red lights are on and the drive turns, but nothing is seen in Explorer. It worked fine for 2 years. What can I do? I have 60GB of...
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty:
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these :devices are working:
:hope this helps:
Jul 05, 2011 | SimpleTech Pininfarina 80GB External USB...
just in case
:click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Computer dont recognize hard drive
you may need to change the jumpers settings on the hard drive...its a little black pin cover try moving it over if its (:) or try (..)
Jun 23, 2010 | SimpleTech Pininfarina 80GB External USB...
External no longer recognized
Right click My Computer, Properties, then click on Device Manager.
Select Disk Drives then on tab menu Action, Add legacy hardware. Go through the setup and use CD's that came with Hard Drive otherwise search company site for drivers.
Oct 05, 2009 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
USB not recognized
Sometimes it helps to reinstall the drivers for the USB hub/controller in the Device Manager.
For other ideas, have a look at these external HDD troublshooting tips.
Hope it helps.
Jules
Jun 13, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Simple Tech SP U25/60 external hard drive
Almost nothing is supported on Win 2000 because it had shuch a short life span. most new tech made in the last 2-3 years only runs onXP or Vista. Every once in a while some will work back to 98.
p.s. did it say it was compatable with 2000? look on the box
Feb 24, 2009 | SimpleTech Pininfarina 80GB External USB...
My laptop HP zd8000 doesn't recognize Seagate external hard drive
hi..the reason for your problem is your extenal
hard drive has been affected by viruses.The best
solution to this problem is scanning your hard drive.
once you scan it u will be free of viruses and your
laptop will be able to recognise your hard drive.
try it out..
thank u..
rate me..
Feb 10, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Computers & Internet Logo
458 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Ricky Ostrom
Ricky Ostrom
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
