SOURCE: Replacement Sewing Machine Bobbin Case
Hi Jo,
Is there a way for you to email me a digital picture of your old bobbin case? I guarantee you we have one for your machine I just need to know what yours looks like!
- Jeremy
http://sewingpartsonline.com
SOURCE: bobbin case not fitting
541678 is the bobbin case you want.Most sewing machine dealers can get this part for you. The machine was made from 1978 to 1984. Before you spend a lot of money repairing this machine, check,or have someone else check, the cam drive gears in the top of the machine. They frequently crack and cause a lot of noise and some erratic stitching.
sewman7
SOURCE: I have been sewing bunting
Is this a top loading bobbin case? If so take the stitch plate off and look for burs or needle punckers on the bobbin case, if you find some polish them off(may need to be replaced.
Also did you use the exact same bobbin that you took out, just had a customer come it that was using the incorrect bobbin for her machine.
Also check your top threading, sounds like it could be that. Make sure to get it in the tension unit. Thread the machine all the way to the needle but not in the needle eye. Then lift and lower the presser foot, you should have tension when it is down and no tension when it is up. If not your machine needs adjusting.
hope this helps
Go to Singer. Com and type in your model number they provide a free manual download and it provides pictures of what you're after.
