Question about Eclipse Audio Players & Recorders
How to put music on my eclipse flipclip - Eclipse Audio Players & Recorders
I try to sync my music and all my eclipse says is USB connected. what am I doing wrong/
Check if your files appear in computer as Removable Disk. Copy/pate or move your music to MUSIC folder of Eclipse
Apr 24, 2015 | Eclipse 180g2 4gb mp3 music/vid
How do I download songs on my eclipse mp3 player
Things You'll Need
Microsoft Windows 7 computer with an open USB port and iMesh installed
USB cable compatible with Eclipse MP3 players
Instructions
  • 1 Plug a USB cable into the Eclipse MP3 player. Plug the other end of the USB cable into an open port on the Windows 7 computericon1.png.
  • 2 Click the "Start" button on the Windows 7 desktop taskbar and click "Computer" in the menu that appears. Click the "Music" item located in the left pane of the "Computer" window that appears. Double-click on the "iMesh" folder. For Windows 7, XP and Vista. Recommended. Download Now.
  • 3 Click the "Start" button on the Windows 7 taskbar and click "Computer" and then double-click on the "Removable disk" icon that represents the Eclipse MP3 player device. A window will appear displaying the contents of the Eclipse MP3 player storageicon1.png area.
  • 4 Right-click on a music file in the "iMesh" directory that has the "mp3" suffix, and click "Copy" in the menu that appears.
  • 5 Right-click on empty space in the "Removable disk" window and click "Paste" to copy the music file to the Eclipse MP3 player device. Repeat for each file you wish to download to the Eclipse MP3 player.
    To copy multiple music files at one time to the Eclipse MP3 player, press and hold the "Shift" key on the keyboard. Click once on each file you wish to copy. Right-click on one of the highlighted MP3 music files and click "Copy" in the menu that appears. Right-click on empty space in the Eclipse "Removable disk" window and click "Paste."
Oct 21, 2014 | Audio Players & Recorders
What do I do to Eclipse fix mp3 when it diplays "Disk Error!" upon attempting to play music?
Presumably the error is caused by a hard disk drive? In which case the hard disk will need to be checked. If there are options to do this use them. Otherwise the drive might need to be replaced.
If you bypassed the normal way of putting music onto the drive, then it might have corrupted the drive.
If there is an option to reformat the drive that might work. Or if there is a factory reset, that might correct it.
If you have music stored on the drive, which is not found anywhere else, then I think it will have been lost for good.
May 27, 2017 | Eclipse Audio Players & Recorders
What should I do when Elcipse mp3 displays "Disk Error!" upon trying to play music?
The players laser reader has burned out, your best option is to replace the deck.
Apr 05, 2017 | Eclipse Audio Players & Recorders
How do i get my sd caerd to start holding information
wht??? Are you sure bout tht cause I want to make sure.My book says something different??:/ I want to make sure so tht when I put the sd card in the eclipse it wont have any problems...better be telling me the truth...>(
Apr 14, 2013 | Eclipse 180g2 4gb mp3 music/vid
Why do i get format error when i put songs from a cd on the eclipse?
1. Why do i get format error when i put songs from a cd on the eclipse?
= This is probably because the format that your songs are currently in is not supported by your device. Supported devices on the Mach Speed Eclipse 180 MP3 player are: mp3, wav, and wma. If your music is for example filename.cda, it won't be able to play because of the file format being .cda.
2. I also see the song on the eclipse but it says drm protected and will not play the song.
= When ripping your music, check your ripping options in whichever ripping software you are using that protecting music files is off, this may be the reason why your music cannot play - it may be protected to only play on the computer that ripped(recorded or duplicated) the song.
Sep 17, 2012 | Mach Speed Eclipse 180 MP3 Player
I dont know how to put videos on the eclipse
When you connect your Eclipse to your computer, it should show up as a removable drive, possibly appearing as drive "E" or "F" in windows explorer. You can open the folders inside the eclipse, for instance, music, movies, text, etc. Once you find those folders, you can find the video you want to load to your eclipse on your hard drive, possibly in you 'documents' folder. Then you highlight the video you want to put on your Eclipse, right click while placing the mouse pointer over the video file and select "copy".
Go to your "movies" folder on your Eclipse, double click the "movies" folder to open it, then right click on a white space inside the "movies" folder window and select "paste". This will place your video on your Eclipse.
If you have found this answer helpful, please remember to leave positive feedback. If you have any additional questions, please let me know.
Thank You,
Brian
Mar 02, 2011 | Mach Speed Eclipse 180SL 4GB MP4 ...
I just got an eclipse 8gb media player but I cant figure out how to put music from limewire or itunes on to it.
Dude, first of all putting music on any device straight from Limewire is completely illegal. Second, it only supports Windows Media Player version 10 or up.
Sep 16, 2010 | Eclipse CLD2 MP3 Player
37 people viewed this question
Top Eclipse Audio Players & Recorders Experts
Oloyede Monsuru
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
