Question about Electrical Supplies
Why would my breaker trip 1to 2 times a day if when it does run everything is perfect
My control panel or board the part # is. 3107541.009! What breaker size should it run on?
    Top Expert:
  • 81,423 Answers
I would replace the breaker and then see if the problem goes away.
Posted on Mar 09, 2018
jessee007
  • 310 Answers
SOURCE: After self cleaning, Range trips circuit breaker when using convection
self cleaning ovens use super hot seting to bake the oven clean and it sounds like it melted a wire and it is shorting out the oven on that setting. look at the wires you can see or easy to remove panels
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 01, 2008
cactus bob
  • 267 Answers
SOURCE: Electric Furnace Trips Breakers
it is normal for a breaker that is run right on the edge (50 amp and your furnance to use 45) to get weak after a while . the first thing you should do is change the breaker with the same type and amp rateing . it should take care if it
Posted on Jan 16, 2009
thedayos
  • 57 Answers
SOURCE: My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Thanks.
Len
Posted on Feb 28, 2009
  • 125 Answers
SOURCE: Breaker keeps tripping
Hello. Here is what I think, not looking at the unit myself, I would start by checking the heaters, both of them, and the heating circuit for a short to ground through the water, here is a link to the manual,
http://www.bunnomatic.com/pdfs/commercial/manuals/41746.0000.pdf
and from page 34 on has the proper diagrams. An electrician should be able to handle a resistance check of this circuit, with a multimeter. If not you need a repair person that can, look in your phone book for Restaurant repair service.
The other thing I have seen with these, is the solenoid coils have shorted out, and cause intermittent problems, but these usually blow the main board, this would be evident by black scorching either on the front or back of the board.
Hope that helped, and thank you.
Ask me if you need more help.
Posted on Apr 13, 2009
TheMobilian
  • 8220 Answers
SOURCE: Ac Problems
You must have too many things running on that circuit. Check your connection to the power box.Loose connection on the receptacle can cause the breaker to trip or too many things running on the same circuit. If the breaker is old it might need to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 10, 2009
Kitchenaid superba double oven, stopped working everything dead, breakers not tripped. does not respond to any control.
Open the lower oven door and remove the 2 screws on the left and right trim pieces. Be careful not to drop the trim pieces and bend them. Locate and remove the screws on each side of the control panel and push up on the panel gently to get it off the hangers. Behind the control panel is an over heat fuse that has popped. It plugs into a harness on the back side of the panel. This trips/breaks it's connection from either the oven over heating the cleaning cycle or just from age.? Once fuse is replaced you're good to go. Hope this helps.
Aug 23, 2012 | Ovens
My hot tub has been running perfectly until a few nights ago when the GFCI breaker tripped and now it wont reset
Either you have a ground fault or the GFCI is toasted. Turn off the power to the GFCI, open the box the GFCI is in and disconnect the output wires, close up the box, re-energize, and try to reset it again. This will tell you which problem you have.
Jun 04, 2012 | Cutler Hammer CH250 2 pole 50 amp
Why is my Craftsman 1/2 hp garage door opener tripping breaker?
-If you can. Manually open roll up and down by hands
to see and feel the door. It's smooth or too tight and too heavy.
-If it' s too tight and too heavy then door rail and wheel need to be lubricate then try again.
-If it's not very heavy and smooth then the motor is worn out. So it'll drain a lot of amp to be able to handle the weight of the door. that's why it trip the breaker.
Good luck
Mai
Oct 25, 2017 | Home Security
What does it mean when I can't trip the fuse breaker back on
It normally means that you still have a short somewhere in that home run. SO something that the circuit breaker controls is drawing more amperage than what the circuit breaker is rated for. So you need to unplug everything on that line and then plug them in one at a time until it trips the breaker.
Jan 02, 2012 | Bryant Electrical Supplies
About 2 months ago my Main Breaker in my 100 amp service box began tripping when certain large appliances were running the same time my central air unit was running. Nothing has changed as far as...
Well breakers can weaken overtime if they are overloaded. A breaker is meant to have 80% of its capacity used, for example a 20 amp breaker should have only 16 amps of current on it. If something was changed six years ago that has loaded that breaker to its max it may have not affected it until now. Another thing would to be absolutely sure that everything running in your house is not exceeding 100 amps. Many houses these days have 200 amp panels because of how much amperage added appliance and the like will use. A licensed electrician will be needed to swap out the breaker, which will be a little expensive but shouldn't be outrageous as he will not be swapping out the whole panel, just the main breaker.
May 23, 2010 | Square D Qo 100 Amp Breaker Box Qo120m100...
Trips breaker and get "PF" on display even when not tripped
This error code indicates "power failure" was detected. This could be caused by a bad/loose connection at either the logic board, the relay board, or at one of the three main power connection terminals on the back of the dryer. The logic board is located inside the control panel. The relay board is located in the base of the dryer. You can unplug and reseat electrical connections at these locations and check the main power cord hook-up at the terminal block. Hope this helped and best wishes.
Sep 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
200AMP Breaker trips same time every night
Something doesn't sound right here. You indicate 2 200Amp breakers. With a single service entering the house, this is not possible. The "sub-panel" to the pool house is more likely a 100Amp setup, yes? If not, you have a bad setup and it should be corrected. I would suspect that you are attempting to pull too much current to the pool and that is what is tripping the breaker. Also, these breakers should not be run over about 80% of their capacity for the long haul. If they are, they tend to age and get either real sensitive causing tripping when it shouldn't or you can run 500Amps through it and it won't trip.
My suggestion is to revisit the setup. If the pool house is fed from the main panel, make sure that the breaker for it is not 200Amp. Second, try disabling the pool house breaker to see if that is the source of the problem and look more closely there.
Keep us posted.
Dan
Jun 29, 2009 | Electrical Supplies
Gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Mar 15, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Electrical Supplies Logo
87 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
