Question about Gateway FPD1530 15" Flat Panel LCD Monitor
When i turn the computer on the screen has a auto/set and at times it can turns on or see windows and it turns off why?
    President:
  • 2,185 Answers
Do you mean the screensaver? You can remove it by Rightclicking on the Desktop, and then click Properties. On the screensaver tab, Click on the drop-down and choose None. Click Apply and then OK.
Hope this helps.
Posted on Jul 31, 2009
Auto shut off of monitor
Instructions for Windows XP
  1. Go to your desktop. Remember to minimize all applications or show only your desktop by pressing the "Win Key + D" combination on your keyboard.
  2. Right-click on your desktop.
  3. Choose the "Properties" option.
  4. Switch to the "Screen Saver" tab.
  5. Click on the "Power" button, and switch to the "Power Schemas" tab.
  6. The default is the "Home/Office" schema. Leave it like this.
  7. In the "Turn Off Monitor" dropdown, choose the desired time and click the "OK" button.
Instructions for Windows Vista and Windows
  3. Choose "Personalize."
  4. Click on the "Screen Saver" icon.
  5. Click on the "Change power settings" link.
  6. Click on "Choose when to turn off the display" in the left pane.
  7. In the "Turn off the display" dropdown, choose the desired time and click the "Save changes" button.
  8. Close the window.
Oct 18, 2013 | HP Pavilion Computers & Internet
When i start my computer booting will start and my monitor or LCD will ON as do in normal times but after a few seconds the screen goes OFF and again i have to switch ON the ON/OFF button of monitor to...
Hi vijayiitkgp0,
The problem could be that your monitor settings have been kept to auto turn off ,
What you can do is check the power settings from the control panel and check for the 'turn of monitor after' settings, which can have 10 minutes of 15 minutes time.
Set this option to 'never' and this problem would go away.
In case the problem persists then check the OSD settings of the monitor by using the buttons which are there on the monitor for any possible setting that could be the problem.
Hope this helps, in case you have any queries , do let me know.
Sep 04, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
I have LCD monitor screen & windows xp as operating system.i cannot remove auto adjusting message box. it flashes on screen after every 2-3 seconds & due to this my screen will auto adjust at every...
The message is being created by the monitor not Windows. The only thing you can do is look for the option to disable it on the monitor's menu options. NEC-brand monitors will have something call "Onscreen Notification" which you can disable. Hopefully your BenQ will have a similar option.
Mar 20, 2011 | BenQ FP71G+ 17" LCD Monitor
Pop up auto adjust in prograss
I had the same problem with my HP LCD. I'll turn on the monitor and it will run auto adjust and set everything to the max making the screen very bright. What I did was remove the button panel board and put it back. Everything works fine since then.
Jan 09, 2009 | Dell E173FP 17" LCD Monitor
LG 710s monitor problem screen turns green
Your AUTO settings button is stuck in! Try tapping on it a few times. Otherwise you may have to take the frame apart so you can get at the button.
Dec 28, 2008 | Amptron AMV 17V5 17" LCD Flat Panel...
My psp has no image but it has sound
Dude, I had the same problem, the screen everything works fine when I use the TV out,
Check it out and tell me. I already call Sony and they will replace it with a new one, I recommend you call them if you still your warranty and your receipt.
or'
If the LCD screen suddenly turns dark
  • Check the Backlight Auto-Off setting
    If the Backlight Auto-Off setting is turned ON, the backlight will turn off after a set period of time. Press any button to turn the screen back on.
    To check the Backlight Auto-Off setting:
    1. From the XMB™ menu, go to icn_settings.gif (Settings) > [Power Settings] and press the icn_btnx_color.gif button.
    2. Highlight [Backlight Auto-Off] and press the icn_btnx_color.gif button.
    3. Select a time interval and press the icn_btnx_color.gif button to save. Select OFF if you wish to disable this feature.
  • Check the Auto Sleep setting
    If the Auto Sleep setting is turned ON, the screen will turn dark after a set period of time. Press any button to turn the screen back on.
    To check the Auto Sleep setting:
    2. Highlight [Auto Sleep] and press the icn_btnx_color.gif button.
  • Check the Display Button
    Check the Display button on the front of the PSP system. Pressing the Display button (located to the right of the PSP logo on the bottom front) will cycle through the brightness settings of the LCD screen.
    The brightness setting can only be used when the PSP system is plugged into an electrical outlet with an AC adaptor.
Aug 15, 2008 | Video Game Consoles & Games
MTP Mode Doesnt Work
Try uninstalling MTP Mode in the Windows Device Manager, and replugging the player - set the menu setting in the Sansa itself to "auto" for USB Mode before replugging. Let me know how it works.
Jun 13, 2008 | SanDisk Sansa e260 MP3 Player
Disabling auto restart in windows xp
JUST FOLLOW THESE METHODS
Right-click My Computer, and then click Properties.
2.
Click the Advanced tab.
3.
Under Startup and Recovery, click Settings to open the Startup and Recovery dialog box.
4.
Clear the Automatically restart check box, and click OK the necessary number of times.
5.
Restart your computer for the settings to take effect.
HOPE SO YOUR PROBLEM SOLVES BY THIS SOLUTION
May 09, 2008 | Microsoft Windows XP Home Edition
Auto Adjust
I have found a way to stop flickering of auto adjust - press the menu key on your monitor -factory reset-menu button-all settings. That has solved my problem and hope it helps you.
Sep 04, 2007 | ASUS VW192S Monitor
Gateway FPD1530 15" Flat Panel LCD Monitor Logo
95 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
