Question about Bosch Dishwashers
Fix f 37 beeper on Bosch wash machine
Tried doing the temp button, but doesn't help
    Sergeant:
  • 203 Answers
You could try unplugging the machine for an hour to try to reset it. The capacitors discharge & sometimes powering them up from empty resets things.
If that doesn't work you will probably need a new control board.?
That won't be cheap, so unless it's insured or under warranty, replacement of the machine might be the most cost-effective.?
Best of luck.
Posted on Mar 09, 2018
Testimonial: "Thank you" we did unplug it for a long time, it still kept doing it. I wondered about the control board. Thank you very much for your answer."
barkencoa
  • 3463 Answers
SOURCE: Not Draining or Spinning
Check to see if there is a removable lower plastic cover at bottom front of washer, if there is remove it ,and on the lower right hand side, you should find the pump filter.
Unscrew anti-clockwise, remove and clean.
Please rate my solution.
Thanks.
Posted on May 30, 2009
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
SOURCE: how do I turn off the beepers on my Bosch washer
To turn the beep off (or volume down) on the Exxcel 7 (BOSCH WAE24468GB you do the following:
1. Turn setting dial to off. 2. Turn dial one step clockwise (wait for panel to light) 3. Keep finger on 'RPM' button and turn dial another step clockwise and release finger. 4. The default setting of '2' should appear on the display, this represents the Button Signal Volume 5. Pressing 'Ready in' button cycles through the volume settings from 0 (off) to 4 (very loud!). 6. Turn dial another step clockwise to set the 'Information Signal Volume', which is also set to '2' by default. This is the one that annoys everyone at the end of the cycle!
All the manuals are on the Bosch website, if you know the model code.
Posted on Jan 13, 2010
SOURCE: Bosch Model WFB 1605 washing Machine
Hi
I have a user manual - swedish, Suomi, Norwidian and danish
Posted on Jan 21, 2010
Bosch classixx 1200 express lights flashing
Bosch 1200 classixx express washing machine. Upon switching on my machine, a little while later all of the lights on the control panel were flashing except the Start button. I tried to push the buttons but there was not the usual sound made upon depression of any of the buttons. They continued to flash. I switched the power off and cleaned out the pipes at the front of the machine to eliminate any obvious problems. Please help
Dec 05, 2011 | Bosch Washing Machines
Key symbol coming up cannot do washing cycle
Try and hold down the Start button for 10-15 seconds, or until the key goes away. If this doesn't work for your washing machine, or your machine is not a Bosch, let me know the make and model and I will help you out.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 14, 2011 | Washing Machines
The alarm goes off every time the wash is completed. How do I turn it off?
Select a wash cycle
Hold down the bleach button and the rinse plus button together til you hear a beep.
Jan 28, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?
Welcome to FixYa.
I think can answer your question..."How do you disable the cycle completion signal/beep on the Bosch SHU9915UC dishwasher?"
Follow these steps...
**How to Operate the Cycle Completion Signal**
1. Open door, hold down program button (see
Beeper Table below) and simultaneously turn the unit "ON".
MODEL Program BUTTON
SHU 9950 Delay Start Hours
**SHU 9910-9920 Delicate/Econo** should be yours
SHU 8800/8810 Quick Wash
SHV 6800 Delay Start Hours
SHV 4800 Delicate/Econo
SHV 4300 Delicate/Econo
2. Release program button.
a. For SHV 6803 and SHU9950 models:
The display will blink with a code of "0", "1" or
"2". You are in program mode.
• If the display blinks with a "0", you will hear
no signal (indicates OFF).
• If the display blinks with a "1", you will hear a
LOW volume signal.
• If the display blinks with a "2", you will hear a
HIGHER volume signal.
b. For all other models with the beeper
function:
• If the machine beeps, then the Cycle
Completion Signal has been enabled.
• When you push the button again and it does
not beep, it means that the Cycle Completion
Signal has been disabled.
3. To change the program, press the program
button until the desired setting is selected.
4. Turn the Dishwasher off to take it out of
program mode.
* At the end of a wash cycle, the beeper will sound
off two times, and again every 15 minutes until the
dishwasher is turned off.
Hope this answers your question and provides you with what you needed.
Thank you for choosing FixYa and good luck.
Please take a moment to rate the solution provided and a short testimony if you feel it's warranted, but also let me know if you require further assistance.
Regards,
Macmarkus :)
Oct 07, 2010 | Bosch SHU9915UC Dishwasher
Can't turn off my signal
Short of disconnecting the beeper device wires inside the machine there isn't a way to do it. The Dryers have a signal button that lets you turn it off, the Washer's don't.
May 10, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
How do you turn off the end of cycle beeper?
usually there is a button or knob somewhere but if not you can always take it apart and disconnect the buzzer, be sure to cover the wires so they dont short out when you plug it back in.
Dec 08, 2009 | Bosch Nexxt 300 Series WFMC2201UC
How do I turn off the beepers on my Bosch washer
Mar 07, 2009 | Bosch Washing Machines
Dishwashers Logo
119 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
