Question about Golf
All new batteries but cart does not have a lot of power. What to check next
    Sergeant:
  • 203 Answers
Check for dirt & corrosion at the battery cable contacts.
Check for damaged power cables.
Check for loose contacts everywhere, but particularly around the main isolator switch.
Check that the drive motor is clean, dry & free from dirt, grease & gunk.
After that you're probably looking at issues within the control-module & that will most likely be a job for a golf-cart specialist.
Best of luck.
Posted on Mar 09, 2018
Yamaha G1 Golf cart...Engine does not crank when key is on and gas pedal is depressed... suggestion??.. I've heard that the CDI might be the issue...Discontinued part?
cranking is turning over which indicates that the battery and starter is doing the job
cranking but not firing indicates ignition or fuel problems
now that you have the correct terminology perhaps you can get an answer
first test is to pull a plug ground it out or use a spark plug tester crank it over to see if there is spark
Good spark forget CDI and coil so look at fuel
NO spark indicated , check for 12 volts from the ignition switch on the start circuit
Ignition switches have to power wires to the coil
on gives power when cranking and the other continues power when the starter is nor engaged
power in both positions move on to next check
no power from the switch to the coil when cranking --get new switch next check if both wires have 12 volts is the ignition circuit
check for safety micro switches not working right up to the CDI
power to the CDI but no spark --replace cdi
power from the cdi nut still no spark --replace the coil
AS to not available
check after marker as the units are generic and made by electronic companies not golf cart manufacturers so it is a distinct possibility that a cdi from some where else will fit
Feb 08, 2018 | Yamaha Motorcycles
Need help putting new batteries in 1980 club car can't figure out how to connect wiring to new batteries
https://www.golfcarcatalog.com/golf-cart-blog/golf-cart-battery-bank-wiring-in-series/
This should solve your problem.
Next time you want to take something apart, be sure to take a picture or 2, before you disconnect anything. That will help you put it back like it was.
Jun 16, 2017 | Cars & Trucks
I have a 2005 ezgo electric golf cart, I caused a power surge now cart won't run? What did I blow?
This could be really bad. Start by checking total voltage from battery pack. Next check voltage at small posts of solenoid when pressing pedal. No voltage? start tracing the wiring. Voltage yes? then test solenoid. If good then controller might be bad.
May 23, 2017 | Golf
Patterson elec golf cart . fully charged with new batteries After 8 holes power indicator flashes but cart still has power to complete 18 holes.Why does it flash
Did you use the correct amp hour high quality batteries or just the cheapest, this is a battery voltage issue having to do with amp hour rating of the new batteries.
Nov 30, 2016 | Golf
Ez go electric golf cart
Need to check to see if the cart has a "resistor" style speed control. Older models will possible have this. It could be a bad resistor. Remember the old slot car controllers. Look closely at the pedal assembly. If it has a plug, disconnect it and see if the resistance between pins varies with pedal position and if you hit a dead spot.
Be careful to unplug batteries. 36V- 48V battery packs have a lot of power.
Sep 02, 2014 | Cars & Trucks
I have a 2002 gas powered golf cart that won't start or run new battery it is a ez go txt
You definitely have an electrical problem hard to answer with little details here's a start check switch,all wiring connections for loose / broke wires and or rusty connections use a multimeter helps a lot of guess work good luck maybe there are fuses too
Aug 26, 2014 | Cars & Trucks
Golf cart electric charged but wont run
not enough info to even guess and I won't..
May 19, 2014 | Golf
Print head
Check that all, printhead and ink are seated and contacts are correct.
Power down the printer and allow for a complete power on and self test.
Dec 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
My MFC-210C always says replace ink.
Try this: Unplug machine from power. Wait 5 min.  Open scanner cover and take the carts out of the holder. Close cover. Plug machine to power. Machine will cycle and demands the carts. Use all NEW carts: Insert carts as demanded and answer question shown on display.
Always print until machine STOPPS printing because of EMPTY cart. Change cart then and machine will print the rest of job!
Plz, never change carts when it says NEAR EMPTY: This will cause a lot of trouble ;-)
Nov 18, 2007 | Brother MFC 210C All-In-One InkJet Printer
Golf Logo
121 people viewed this question
Top Golf Experts
ray gallant
Ronald Prier
Bill Boyd
Are you a Golf Expert? Answer questions, earn points and help others
