Question about Gateway Computers & Internet
Recovery stalled at 99% Gateway recovery management (V8.3.2)
Cant reboot after failed Windows 10 update. Tried to restart with Gateway Recovery Mgt.program.
Try this:
Start the computer. As soon as the "Starting Windows" screen comes up (not the Gateway/eMachines screen), hold down the Power Button to shut off the computer. This might force the computer to go in to Windows recovery mode when you restart. Now, turn on the computer, and it should go to a "Windows Diagnostics and Recovery" page. Choose Diagnose the Problem or whatever it says, follow the instructions.
Good luck.
Jan 14, 2018 | Gateway Computers & Internet
Cd dvd player not seen
Check device manager see if driver is showing for cd/dvd
If you have a recovery partition on the laptop You can reinstall your drivers and software using your recovery option.
Recovery should be in START/ALL PROGRAMS/SYSTEM RECOVERY (you may need to click Gateway Utilities first).
Then select application& driver recovery
.Or you can download from gateway http://gateway.com/worldwide/ select country then supporrt then drivers download.
Apr 13, 2013 | Gateway NV5378u Notebook
My gateway laptop won't reboot after system recovery
I would put in a Windows disc and see if that prompts windows to start and/or reinstall. Actually, can you send me the recovery disc via download? I am trying to fix my old laptop and cannot find the discs. lilly.murphy@yahoo.com Thanks much!
Nov 30, 2012 | Gateway NV55S04u PC Notebook
Procedure for accessing the setup program on a Gateway M1634u
Gateway Support > Gateway M1634u > Main Support page,
http://support.gateway.com/us/en/s/Mobile/2008/MSeries/M-1634u/M-1634unv.shtml
User Guides
8513017 - Gateway Notebook Reference Guide with eRecovery R2
Hover your mouse cursor in the middle/bottom, to bring the ghosted out navigation guide up.
Go to the far right, and click on the Adobe PDF icon.
(When you hover your mouse cursor over it, - Show Adobe Reader Toolbar appears )
Go to the left in the Bookmarks menu, and click on the blue page marker icon. (Second icon down from Bookmarks heading)
Scroll the blue sidebar down to about halfway, and click on -
Recovering your system
Or go to Page 107 for the PDF reader, or Page 99 for the actual manual page.
1) AS SOON AS YOU PRESS the Power On button, start tapping on the F10 key. Tap in 2 second intervals.
If you hear beeps these are Stuck Key Error Code beeps.
Ignore. It is you making the beeps
That's to go to the BIOS Setup (Utility)
2) ALT + F10 to go to Gateway Recovery Management
Regards,
joecoolvette
Oct 07, 2012 | Gateway M1634U (L-LX.W090X.001) PC...
I want to know how to restore my DX4200-09 to factory settings?
· Click "Start" on your Windows desktop. Navigate through "All Programs" and "Gateway." Click on "Gateway Recovery Management."
· 2
Click "Restore" when the Gateway Recovery Management window pops up, which will take the system back to the default factory specifications. A box will pop up asking for confirmation, click "Yes" and then "Start." You may have to enter a password as well, but only if your particular Gateway had a password set.
· 3
Wait for the computer to restart. A "Restore from factory default" box will appear, requiring you to click "Next" twice in a row. Click "OK" in the box that appears next, and wait for the hard drive partition to be created. The factory default installation will then be moved over to the hard drive.
· 4
Click "OK" in the box that appears and wait for a second Gateway restart. Several minutes will pass as Windows "starts for the first time." When restarting finally finishes, a "Set Up Windows" dialog box will appear. Click "Next," followed by checking the license agreement box, and then "Next" again.
· 5
Enter a user name and picture, if desired, and a computer name. Also, customize the background wallpaper for your desktop, optionally. Click "Next."
· 6
Click "Use Recommended Settings" on the Protect Windows-based dialog box that pops up.
· 7
Set your correct date and time settings in the next box. Select your location in the following screen. Click "Next," followed by "Start" to finish.
· 8
Wait while Windows checks for your individual Gateway computer specifications and adjusts accordingly. This will likely take several minutes, so leaving your computer for a short time is fine. Windows will then prepare your hardware and finish your Gateway restoration process, including the installation of Gateway Recovery Management. Once completed, your Gateway is good to go and ready at factory settings.
hope this helps
Jun 25, 2012 | Gateway DX4200-09 PC Desktop
Do I need to purchase the service plan/pak from Gateway in order to buy a recovery disk
Wow, why not just make sure you have access to an Operating System Disc that is the same as your operating system. Then periodically copy your My Documents folder to a USB Flash Drive or to an external drive for backup purposes. Most times those Recovery Discs don't work. The only good recovery that works most times is when the manufacturer burns the partition on the hard drive.
May 02, 2012 | Gateway Computers & Internet
My Gateway GM5088 Desktop computer via Windows XP is not recognizing my audio device.
You can reinstall the sound drivers from the Gateway recovery management, to do so:
Start Menu> All Programs> Gateway recovery management> Restore> Restore Application & Drivers> Contents> Select Realtek and install it
OR
Visit http:\\support.gateway.com
Regards,
Jitha
Dec 23, 2010 | Computers & Internet
Trying to do a full factory recovery on an M Series gateway note
If you want to do the factory recovery, 3 ways to do the system recovery
First way
1 login to windows
2.click Start
3. click All programs
4. click Gateway
5. click gateway recovery manager
6. click restore
7. select systems recovery to factory defaults
Computer will restart itself and start doing the system recovery itself, All you need to do is follow the screen
Jun 07, 2009 | Gateway MX6447 Notebook
Gateway mx3560 wireless (yellow exclamation mark) on device manager
Obtain an ethernet cable and connect to the Gateway Support site using wired network temporarily to download and install the proper wireless driver.
May 29, 2008 | Gateway MX3560 Notebook
Computers & Internet Logo
53 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
