Question about Conair Dry 'N Straight Hair Dryer and Straightener
My iron powers on but don't get hot.
I have a emerson iron model no.83191. It powers on but don't get hot. It also makes a beeping noise when laid flat. What does this mean?
  • 27 Answers
First of all check the male ac adaptor cord, maybe an open wire only cause by pulling and pushing it. if the ac cord is good then the filament may checked maybe it burn--out already
Posted on Jul 31, 2009
U maay want to get a new iron, this one isnt all to expensive and it seemed that its burned out. as a safety procaution you should throw it out as it may get a sudden surge of power and start a fire or exploson. I wouldnt throw it out at my home, iwould ask a garbage man what to do with it as it maybe a safety hazard.
Hope i helped
~firefaerie22~
Posted on Sep 10, 2009
Should the cable from the machine to iron get hot
If the iron is a steam-iron with a steam tank in the base-unit, then steam is carried up the connecting pipe & it will get hot in normal use.
If you put water into the iron itself, then there is only an electric cable connecting the base & it should never, ever get hot. A little bit warm maybe, but never hot.
Best of luck.
Mar 09, 2018 | Irons
Tip
Electric Iron not Heating Up or not Working Right
If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
The first thing to check is to make sure that you actually have electric power getting to the steam iron. Many times the problem is simply caused by a tripped circuit breaker, a faulty outlet, a worn or broken plug on the end of the cord, or in some cases, a fuse that is in the plug. Another common problem is for the cord of the clothing iron to break at the point where it enters the handle of the iron. By checking that you have power actually getting to the internal parts of the electric iron, you eliminate one set of common problems.
Next you need to check that the power is getting to the heating element. For the power to get to the heating elements of the iron it needs to go through the power switch and the thermostat. On some irons the power switch will be included in the iron thermostat and on others the on/off switch will be a separate switch. In either case you will need to make sure that there is continuity, or the ability for the power to flow through the switch and thermostat to get to the heating part of the iron. The thermostat is just an on/off switch that works on the temperature of the base of the iron. So whenever the iron is cold the thermostat should be closed, allowing the power to flow through it.
If the power can get to the heating element of the iron, then it should get hot. If it is not, then the heating part has failed. Sometimes, when this happens it will short out and cause the fuse to blow or the circuit breaker to trip. Many times though, the element will just simply burn out or break so that the circuit is open and the electricity cannot flow through to make the element produce heat.
If your iron is getting too hot or not hot enough then the problem will almost always be in the thermostat. Sometimes it may be a simple thermostat calibration problem, but it also can be that the thermostat simply will not work properly anymore.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter.
on Jul 14, 2010 | Irons
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Apr 12, 2016 | Rowenta Irons
Need help with Kenneth Bernard Hair FLAT IRON, not a clothes iron!! Model # is KB2010.
The Kenneth Bernard Vibe Flat Iron - YouTube
? 2:15
www.youtube.com/watch?v=lQklW8kNO90
Apr 7, 2015 - Uploaded by Chatters Salon
The Kenneth Bernard Vibe Flat Iron ... How I curl my hair using aflat iron, extensions and bump its ...
Sep 15, 2015 | Irons
Steam generator iron making a noise but no light is coming on and it is not getting hot
the thermocouple is probably bad. Not usually a customer serviceable item unless you know how to solder.
Jan 28, 2015 | Irons
Philips steam iron no steam and red tap light is flashing even when filled up with water it's still getting hot and water is boiling but steam fiction not working as red light will not go out
It sounds like the flow holes are CLOGGED with scale inside. To clean it out:
1. Drain the water/steam out the pour-in shoot at the top of the handle, over the sink. Is any crap coming out?
2. Take some VINEGAR and pour it straight into the fill pour-in shoot. Don\'t dilute it. Fill up the IRON to full line. Let the vinegar SOAK the inside of the COLD iron for 15-20 minutes, by placing it FACE DOWN on an old bath towel, on a heat-resistant surface, such as a granite counter top, or metal cookie sheet. Don\'t put the towel on the ironing board!!! It may get stained badly. Let it sit, COLD for 20 minutes. You can swirell the vinegar around by shaking the iron.
Stand it up on its flat end, with the vinegar inside, still. Take some fresh vinegar and dip Q-tips into the vinegar and clean the slots and holes on the bottom plate. Any burn streaks or soil can be removed with wiping the plate with vinegar. After you clean all the holes and slots with vinegar from the outside, TURN ON THE IRON with the vinegar inside. The vinegar will heat up and should come out the holes. If any holes are not blowing vinegar/steam, clean them with q-tips again. Don\'t let all of the vinegar inside steam out!! Just heat it enough to make sure all of the holes are clean. Some white film may come out of the holes on to the face plate--it is calcium build-up from using tap water in the iron.
Now DUMP out vinegar inside the iron and reservoir through the pour-shoot You may see crud and crap coming out. Repeat the process of filling it up, steaming through the holes etc. until the vinegar comes out clear!!!
DON\'T use tap water in any IRON. Use distilled water, or even bottled drinking water (without flavoring, additives, of course). This will prevent corrosion and calcium build up in the iron.
ALWAYS completely drain the iron from the pour-in spout each time you are finished using it!! After pouring out the tank\'s water, you can set the iron to STEAM HIGH, and force any water inside to boil off and out of iron.! Never keep water in the reservoir or iron.
I set my iron, when hot, and done using it, with the pointed side DOWN in the sink drain to make sure it is dry.
So clean it with vinegar often, use bottled drinking water or better, distilled water and it will prevent this.
Oct 24, 2013 | Irons
I have a 4045 model iron, extremely happy with it. Recently, when I plug in the iron the light goes on but it does not heat up at all. Any way to fix it or is it busted. Suggestions would be appreciated.
Heatman101 posted this on the site......
"If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter."
Sounds like either power isn't getting to the heating element, or the element is bad.
Good Luck
--HomeGrown
Dec 29, 2010 | Sunbeam Euro Press 4045 Iron
Boiler on the iron was empty,used by someone that didn't know this type iron.Turned iron on and later heard this awful noise and husband tried to release pressure and cap blew off but no water was in...
I do not use this model, but it would appear the iron is not affected, just the boiler - like setting an empty tea pot on a hot burner.
Is there any warning that the tank is empty before turning the iron on?
I would refer to the manual for cleaning before using the iron and would not loan anything more valuable than a cup of sugar to anyone.
Mar 19, 2010 | Rowenta DG5030 Iron
Do i need that stand to make this iron work? nothings happening. lights are the only thing that works!
Does the owner's manual specify? It should. Usually those stands just give you a place to put the iron out of the way so you don't have to lay it flat on the ironing board while it's hot.
Jan 29, 2010 | Oreck Cordless Speed JP8100CA Iron
It gets hot but there is no steam or noise from it also the red standby button is flashing
i have a tesco steam generator iron, model no. sgc2 it has no steam or noise but red stand by light is flashing
Jul 11, 2009 | Irons
Conair Dry 'N Straight Hair Dryer and Straightener Logo
224 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
