Question about Navigon 2100 Portable GPS Receiver
Error Message on Navigon 2100 gps
Error Message: "Memory allocation failed! Line 5019 Error 8"
Unit will not respond. I hate to reset and lose all of my addresses.
jazzyboy11
  • 728 Answers
SOURCE: navigon 5100 gps
Try turning it off and turning it back on while it is still plugged in and see if that works.
Posted on Oct 23, 2008
johnny5846
  • 379 Answers
SOURCE: need a navigon 2100 user manual
http://www.navigonusa.com/_pdf/manual/Manual_2100_2120_English.pdf
this is your manual .
Posted on Dec 27, 2008
SOURCE: The MN6.exe fatal Application error is displayed
push the reset button on the side of the system (a paperclip works well for this). Also, remove the card and put in again. If this doesn't work go to Navigons website and make sure you've downloaded all the software updates. Make sure your unit is fully charged as well. Don't waste your time emailing Navigon's CS online help....I attempted to contact them on 3 separate occassions and never got a response. Good luck. Hope one of my work-arounds helps you.
Posted on Jan 26, 2010
PCTechOnline
  • 532 Answers
SOURCE: Navigon 2100 screen problem
When you changed your charger, did you get the right one?
I bought an iGo and thought I could use the standard min usb tip. However, tip number A53 does charge and show the map.
I hope this answers your question.
Posted on Mar 23, 2010
SOURCE: navigon 2100 text to speech not working
the same happened to my 2100 3.5 inch. any remediatons?
Posted on Aug 10, 2010
"Stack overflow at line 0"
b> A stack is a section of memory where a program stores its variables, calculations, option states and program parameters. When started, a program is allocated some memory to use for the stack; a stack overflow happens when a program exceeds its allocation. The offending program may attempt to write into adjacent memory sections, causing conflicts with other programs. Stack overflows are common with Java, C++, Perl and other runtime environments, which assist in running programs. A stack overflow at line 0 indicates that the offending program tripped up from the start; however, stack overflows can occur on any line number.
Click "Start," "Control Panel, then "Internet Options." Click on the "Advanced" tab. Check "Disable Script Debugging (IE)" and "Disable Script Debugging (Other)" under the "Browsing" options. Uncheck "Display a notification about every script error." Check "Enable Automatic Crash recovery." Click "OK." Download and install a Java update from the Java website. http://www.java.com/en/download/manual.jsp Download and install a Windows update. Hope this helps.
Dec 24, 2012 | Microsoft Windows XP Professional
Error message, out of memory
No would be my answer and then a phone call to customer service for this unit.
Dec 20, 2012 | GPS
Fs201
I would suggest going here and reading about your unit.
http://reviews.cnet.com/car-gps-navigation/navigon-2100/4505-3430_7-32744602.html#reviewPage1
Go through the 2 pages.
Good luck
Apr 10, 2012 | Navigon 2100 Portable GPS Receiver
How do i reset the casio te-2200-1 cash register till back to its manufacture settings
This is not advisable as you will lose a large amount of settings and data. If you are not familiar with memory allocation procedure, key allocation procedure, machine features settings and function settings, then it would pay to avoid a full RAM clear. It would be much easier to edit the existing programming to suit your business.
If you still want to RAM clear the machine and start again, you will need the tables from the Casio TE-2200 dealer manual:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
To program the basics such as Item names/ prices and receipt message, the user manual is what you need:http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_users_manual.html
Sep 30, 2011 | Casio Parts Cash Register PC Desktop
My Navigon 2100 GPS lights like it's charging, but it won't turn on
I HAVE A 2100 NAVIGON GPS SCREEN WONT COME ON TRYED CHARGEING IT THE ORANGE LITE COMES ON /WONT CHANGE TO GREEN ALSO TRYED TO RESET NOTHING DO YOU HAVE ANY IDEAS WHAT ISHOULD DO NEXT .
Jun 30, 2011 | Navigon 2100 Max Portable GPS System
Fat alloc error
> FAT ALLOC ERROR
FAT == File Allocation Table (like a 'Table of Contents' in a printed book)
ALLOC == Allocation
ERROR == ERROR
Some of the contents of that 'Table of Contents' are invalid.
So, copy all the files from the Memory Card onto your computer, to save a copy of those files.
Burn a CD/DVD disk with a copy of those files.
Then, "reformat" the Memory Card, to write a "new" and "empty" 'Table of Contents' onto the device.
Then, copy all the files back onto the Memory Card.
Jun 01, 2011 | SanDisk 2GB microSD Memory Card
My navigon 2100 doesnt work after the update. help
I own a navigon 2100 as well. Very nice device and you can install the 5100 software and the 7100 maps and points of interest. gpspassions.com is the best resource for 2100 help.
Try this:
Hard Reset Procedure - if the PNA is on, press the Power button until the unit goes off. Press again and hold the button down - the screen will come on and after a few seconds go off again. Press the Power button again and the screen will come back. If you get the opening "music", you know the Hard reset was successful.
If you leave the memory card out and keep the unit powered on, you will after a few 10's of seconds go into the Demo mode. When you reinsert the SD card a soft reset will occur (equivalent to pressing the recessed button on the left hand side) and the unit will initialize into whatever the SD card tells it to (see below).
source:
http://www.gpspassion.com/forumsen/topic.asp?TOPIC_ID=101685
Apr 13, 2011 | Navigon 2100 Portable GPS Receiver
Navigon 2100 mn6.exe fatal error message....going through update with card reader through navigon site didn't work...asme message. machine works. it seems to be card. how do I fix this or get a new...
I got mine back up and working by doing the following:
1st Icopied the files on the SD Card to my pc (for backup)
2nd I deleted all the files on the SD Card
3rd I went to the following link https://www.navigon.com/site/us/en/my_navigon/unauthorized/products_us
and download the update for Navigon 2100 and installed it.
Tested it and it no longer gives me the fatal error.
Jan 07, 2010 | GPS
The MN6.exe fatal Application error is displayed all the time and I am unable to use the Navigon 2100 GPS
Dec 20, 2009 | Navigon 2100 Portable GPS Receiver
Navigon 2100 Portable GPS Receiver Logo
131 people viewed this question
Top Navigon GPS Experts
Will Halftowaite
Are you a Navigon GPS Expert? Answer questions, earn points and help others
