Question about Philips 27PT543S 27" TV
Tv does not turn on
I have a philips tv model# 27pt563s37a, when i try to turn on my tv i have to push the power button 20 times its been getting worse over the last month or so.each time you push the power button it stays on a litte longer as if its warming up or somthing.the tv is just over 4 years old.any idea what my might be wrong with my tv?
kirk,in ottawa
  • 2 more comments
  • sammyvel83 Dec 05, 2007
    I have exact same problem no power but I do hear a constant clicking noise from somwhere on the main board
  • himess Apr 21, 2008
    I have a 27PT543S37A, it tries to turn on with a fuzzy picture and then shuts off. Aftern about 10 to 20 times it finally works. Now it wont turn on at all but, I do hear a lot of clicking when I try to turn it on.
  • nk_hp May 24, 2008
    When turning on the TV it would have a distorted picture for few seconds then turn off. This would happen over and over again, especially when changing channels before it was working properly. After several months it would not work at all. Clicking would go on as if it was trying to turn on. Then I found this site, changed capacitor 2455 with one from Radio Shack at $1.19 + tax. It was 47 uf and 35 V. TV works fine now - at least for awile. Best picture I remember. Thank you.
  • AviKouzi Jun 08, 2008
    I had the same exact problem, but now today on the 23rd try (and what I thought was the one), all I got was a chirping sound with no picture and what seems like no effort on my tv's end.  I am so mad at Phillips, what a POS.  Any chance of a repair, or do you think its time to toss it to the curb (heavy SOB too)?  Help anyone please please?? Thanks
  • 4 Answers
Replace C2455 47uf 25V
Posted on Dec 22, 2007
URC20 D1F codes for philips tv
Not sure which Philips TV model you have. But you can use the remote to scan the code by itself.
Try these steps::
1. Manually turn on your TV. Hold down the "Code Search" button on your remote, then press and release the device button you want to set up until it flashes.
2. Push the power button repeatedly until the TV turns off, then hit "Enter."
3. Press any other button while the TV is on to see if it responds. If it does, you don't need to do any other programming. If it doesn't, repeat steps
Aug 17, 2014 | Televison & Video
Will not turn on with remot and turn on button is
Is there a way you can power it on, by pressing hard on the button? The get a new Universal remote and program the TV.
Otherwise, it might be time to get a new TV.
Feb 03, 2010 | Philips Magnavox 20MC4304 20 in....
I do not have a manual and need to know how to set it up and the code for a vizio tv.
On your remote you will find a setup botton and what i want you to do is hit set up then hit the tv botton and hit channal up and do that untell it turns off your tv are the channal if that works it tv botton again and your remote will work other wise in the back of your remote it well tell you a code number and go on line to philips and they will give your your codes for you.
Dec 09, 2009 | Philips Magnavox Learning Universal Remote
Trying to program my guesTVision CL034 remote to control a Mitsubishi tv.
Turn on tv. On the remote, hold down 'Code Search' button until red light comes on remote. Press 'Chan +' button (on remote) repeatedly until the channel changes. Be patient, this could take lots of pushes. Once the channel changes on the tv, push the 'mute' button on the remote. You're set!
Apr 18, 2009 | Philips Televison & Video
Rca Universal remote RCR311W
Try with the philips this method:
Manually turn on the tv or the device to be controlled.
Push and hold the code search button until the red lights stand.Now release the button push and release the tv button,then you got to push and release the on off button until the device turn off stop push and release the enter button.
You might need to push the on off button 1 to 150 times.
Good luck
Aug 22, 2008 | Televison & Video
Tv does not turn on
Kindly check the powersupply area for a burn fuse & also check for the bad solder on the board...
Thank you
May 29, 2008 | Philips 27PT543S 27" TV
Codes for Philips 4 Device Universal Remote, Model US2-PM435S
Try this:
turn on the tv manually,then push and hold CODE SEARCH button until the red light stand still now release the button push and release the device button TV after that you got to push and release the ON/OFF button until the tv goes off stop.Now push the enter button to memorize the code check if the tv turn on with the remote.
You have to get some patience because you need to push the power button between 1 to 110 times.Good luck
Apr 17, 2008 | Philips 5-Device Universal Learning Remote...
TV turns on at odd hours by itself
Hi, I had the "Ghost In The Machine". I tried out what I descibed in my original posting.
#1. I unplugged The Set.
#2. I pushed in and held in the power button in for about 5 minutes before bedtime. ( The PC trick I learned) I gave it 5 minutes because a tv set has much more power inside it.
#3. I again pushed in and held the power button in again for 3 minutes the next morning.
#4. I plugged the tv in again. The red standby light was lit. The set did not immeadiatly come on when I tried to power it up.
#5. 5 Minutes later I returned and hit the power button on the remote and it came on like nothing ever was wrong.
#6. It has been fine now for 3 days!!! Powers up when commanded and shuts down like normal. It has yet to come back on or act up as it was doing.
I will keep a watch on it and if it starts up acting again I will repost. I hope this information will be of use to anyone who experienced the same problem. It didn't cost a dime, just some patience. Thanks for a forum that people can exchange information and save trouble and money unless all options are exhausted. Bill
Mar 09, 2008 | Philips Magnavox 20MS3442 20" TV
Philips tv demo
Try holding the volume up and channel down buttons on the set at the same time. Give me the model # if that doesn't work.
Jan 17, 2008 | Philips 32PT6441/37 32" TV
Maganavox model#19PRC1 0121
Push the volume down and channel down buttons(on the tv)at the same time.
Sep 07, 2007 | Philips Magnavox 20MT4405 20" TV
Philips 27PT543S 27" TV Logo
247 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
